Navigation
    • Search
    UNSOLVED 24" touch not working in horizontal
    Troubleshooting
      soylant last edited by
      Hi all
      I have connected a 24" Viewsonic with touch to my PI where I have installed MagicMirror.
      The screen and touch is working, but when I turn the screen to horizontal the touch is not following and is still in landscape mode, is there any way to flip the touch so it is working in horizontal?
      • F
        FreelanceMKE @soylant last edited by
        @soylant a lot of people who use the official raspberry pi touchscreen talk about this. Because the display is upside when you put it in many cases. You need to go into /boot/config.txt and add a line lcd_rotate=2 as an example for 180 degrees. not display rotate display will rotate the image but not touch input.
        I have not been able to get a touchscreen to work in a portrait mode because I’ve read that there’s not enough memory or something to support it.
          Hi
          I already tried the rotate LCD and rotate dispaly but haven’t had any luck with it
          • broberg
            broberg Project Sponsor last edited by
            Instead of rotating the display in the OS, just rotate the magicmirror webpage with css.
            https://forum.magicmirror.builders/topic/9707/save-performance-when-rotating-screen-e-g-on-raspberry-pi/11
            That way you don’t change the screens rotation and thus don’t need to rotate the touch interface.
            • C
              cyberphox @soylant last edited by
              @soylant Still need help?
