    mail module problem
    13 Posts 4 Posters 4.6k Views 4 Watching
    • P Offline
      papinel
      Hello
      I just installed MagicMirror and all the native modules works fine, I have to change the language,
      I adapted weatherforecast, currentweather, newsfeed, for calendar I stopped it because it’s american, I put pictures that turn in loop,
      but when I want to install my mailbox with a terminal I have a problem!
      I open a terminal I start with
      cd ~ / MagicMirror / modules
      then
      git clone https://github.com/ronny3050/email-mirror.git
      then
      cd email
      npm install
      i will then go to config.js where i install
      module: ‘email’,
      position: ‘top_left’,
      user: “xxxxx@gmail.com”,
      password: “xxxxx”,
        host: “imap.gmail.com”,
      port: 993,
      tls: true,
      authTimeout: 10000,
        numberOfEmails: 5,
        fade: true
      of course I put my personal details
      and when I restart MagicMirror
      with the command … pm2 start mm … in a terminal I returned a black page with an error message
      here you can help me
      Thank you papinel
      • mumblebajM Offline
        mumblebaj Module Developer @papinel
        @papinel Hi. Your config looks wrong. Can you try changing it to match the below?
        module: 'email',
        position: 'top_left',
        header: 'Email'
        	accounts: [
        	user: 'xxxxx@gmail.com',
        	password: 'xxxxx',
          host: 'imap.gmail.com',
          port: 993,
          tls: true,
          authTimeout: 10000,
          numberOfEmails: 5,
          fade: true
        • P Offline
          papinel @mumblebaj
          Hello sir
          could you tell me if I use the right orders? with the terminal
          cd email
          npm install
          because when i install your answer in my config.js
          I have my black page with the error message
          please create config file
          if you this message is ready for your config file probaly contains an error
          this message only happens when I install
          in the config.js
          Thank you very much for your help
          papinel
          strawberry 3.141S mumblebajM 2 Replies Last reply Reply Quote 0
          • strawberry 3.141S Offline
            strawberry 3.141 Project Sponsor Module Developer @papinel
            @papinel you didnt install it properly, the instructions say git clone https://github.com/ronny3050/email-mirror.git email, either start from scratch or rename the directory email-mirror to email and install the dependencies again.
              @papinel I just installed the module and set it up and it works perfect with the setings that I gave you above. As @strawberry-3-141 mentioned, you may want to start from scratch with the module installation.
              • git clone https://github.com/ronny3050/email-mirror.git email
              • cd email
              • npm install
              • P Offline
                papinel
                Hello,
                I’m sorry, but really sorry I still did not pay the email module for my magicmirror I did everything you told me
                first the 3 orders by the terminal
                cd email
                npm install
                return by image
                pi @ raspberrypi: ~ $ git clone https://github.com/ronny3050/email-mirror.git emailCloning in ‘email’ …
                remote: Enumerating objects: 3, done.
                remote: Counting objects: 100% (3/3), done.
                remote: Compressing objects: 100% (3/3), done.
                remote: Total 63 (delta 0), reused 0 (delta 0), pack-reused 60
                Unpacking objects: 100% (63/63), done.
                pi @ raspberrypi: ~ $ cd email
                pi @ raspberrypi: ~ / email $ npm install
                (node: 2831) [DEP0022] DeprecationWarning: os.tmpDir () is deprecated. Use os.tmpdir () instead.
                npm WARN package.json email@0.0.1 No repository field.
                npm WARN package.json email@0.0.1 No license field.
                npm WARN deprecated mailparser@0.6.2: Mailparser versions older than v2.3.0 are deprecated
                npm WARN deprecated mimelib@0.3.1: This project is unmaintained
                underscore@1.9.1 node_modules / underscore
                debug@2.6.9 node_modules / debug
                └── ms@2.0.0
                imap@0.8.19 node_modules / imap
                ├── utf7@1.0.2 (semver@5.3.0)
                └── readable-stream@1.1.14 (string_decoder@0.10.31, isarray@0.0.1, inherits@2.0.4, core-util-is@1.0.2)
                mailparser@0.6.2 node_modules / mailparser
                ├── mime@1.6.0
                ├── mimelib@0.3.1 (addressparser@1.0.1)
                ├── uue@3.1.2 (escape-string-regexp@1.0.5, extend@3.0.2)
                └── encoding@0.1.12 (iconv-lite@0.4.24)
                as indicate by
                 mumblebaj
                then I copy in config.js
                module: ‘email’,
                header: ‘Email’
                accounts: [
                user: ‘xxxxx@gmail.com’,
                password: ‘xxxxx’,
                  host: ‘imap.gmail.com’,
                  port: 993,
                  tls: true,
                  authTimeout: 10000,
                  numberOfEmails: 5,
                  fade: true
                as indicated by
                mumblebaj
                in my home / pi I have an email folder, but when I run pm2 start mm, I find my page that marks me errors, I really do not know or I make a mistake I am to the letter your advice
                I really do not know where I am making a mistake I am on the letter your advice
                I will stop bothering you with my problem, I will not use the clone mail
                I pass you all this through a .odt file
                thank you so much
                papinel
                  sdetweil @papinel
                  @papinel ALWAYS git clone ONLY with the MagicMirror/modules folder as the current folder, u have them all over the place…
                  • P Offline
                    papinel
                    Hello
                    thank you for your answer, but could develop a little more because I have trouble understanding to execute this module
                    thank you so much
                    papinel
                      sdetweil @papinel
                      @papinel when someone tells u to install a module on MagicMirror
                      you do
                      cd ~/MagicMirror
                      cd modules
                      git clone .....
                      cd ../config
                      nano config.js
                      ... add the config info for this module
                      ... save the updated config (ctrl-o to write, ctrl-x to exit nano)
                      cd ..
                      either use pm2 to  start MagicMirror again or the installers/mm.sh
                      in general, you should not need to change anything IN the module folder itself
                      • P Offline
                        papinel @sdetweil
                          sdetweil @papinel
                          @papinel yes?
                          • P Offline
                            papinel
                            the answer I want to make is enterdite it goes into spam
                            bad luck for the helpers
                            papinel
                            • P Offline
                              papinel
                              hello
                              je tiens avous remercier pour votre aide
                              mon module fonctionne a 99 pour cent
                              il me dit '…no read mail … j’ai configurer comme ca
                              port: 993,
                              dans gmail j’ai active imap mais mes mails n’apparaisse pas sur l’ecran de magic m
                              une petite idee pour cloturer ma demande
                              merci beaucoup
                              papinel
                              343/5000
                              Hello
                              I want to thank you for your help
                              my module works at 99 percent
                              he told me '… no read mail … I set it up
                              port: 993,
                              in gmail i have active imap but my mails do not appear on the screen magic m
                              a little idea to close my request
                              thank you so much
                              papinel
