    Screen switching to blank
    13 Posts 4 Posters 4.4k Views 5 Watching
      micksel
      Hi everyone,
      I have a problem with my setup seems that the raspberry goes into some blank mode, I tried every setting i can find about disabling the screen saver but I can get inte to work. if i enable the screensaver then it would go blank.
      any suggestions?
      • qu1queQ Offline
        qu1que Project Sponsor
        @micksel said in Screen switching to blank:
        med
        What means med setup?
          sdetweil @qu1que
          @qu1que I think he meant ‘my’
          • qu1queQ Offline
            thanks @sdetweil
            @micksel
            Did you try this?
            https://github.com/MichMich/MagicMirror/wiki/Configuring-the-Raspberry-Pi#disabling-the-screensaver
              micksel @qu1que
              @qu1que yes but no success :(
                sdetweil
                try my new screensaver script
                see
                https://forum.magicmirror.builders/topic/11052/new-script-for-screensaver-disable
                Mykle1M M 2 Replies Last reply Reply Quote 1
                  @sdetweil said in Screen switching to blank:
                  Is there no end to your wizardry? :thumbsup:
                    micksel @sdetweil
                    I run your script file,
                    Got the following output in the logfile:
                    xscreensaver running
                    xscreensaver already disabled
                    and the screen is still blank
                      sdetweil @micksel
                      @micksel does the screen go blank when not running MagicMirror?
                        micksel @sdetweil
                        @sdetweil I don’t now MagicMirror is set to start auto…
                          sdetweil @micksel
                          @micksel if u wiggle the mouse, or hit enter on a keyboard, does the screen come back?
                          If not, hit alt-spacebar, n
                          To minimize mm.
                          The pm2 logs
                            micksel @sdetweil
                            @sdetweil No it don’t come back seems that it the magicmirror it self that goes blank
                            I can see one intresting error:
                            0|MagicMir | [935:0828/010903.621134:FATAL:memory_linux.cc(36)] Out of memory.
                            0|MagicMir | ATTENTION: default value of option force_s3tc_enable overridden by environment.
                            0|MagicMir | [938:0829/035113.722064:FATAL:memory_linux.cc(36)] Out of memory.
                              sdetweil @micksel
                              @micksel ok, run
                              pm2 stop 0
                              then
                              cd ~/MagicMirror
                              npm start
                              now you might see the full errors
