    Almost done need to active my mirror by Phrase
    phrase
    24 Posts 4 Posters 12.6k Views 4 Watching
    • O Offline
      otto
      I am now Almost done with my magic mirror.
      But one more thing I what.
      I what the mirror just to be a mirror, but if I say mirror mirror on wall. all module Should pop right up.
      So I guess I need google assistance hide but still active some way. And need to get hot word to do the think.
      So what is the answer to my question?
      • O Offline
        otto
        my best guess is @Sean do u have any ide?
          sdetweil @otto
          @otto I think MMM-Hotword has enough capability to wake up from sleeping hotword detection
          • O Offline
            otto @sdetweil
            @sdetweil said in Almost done need to active my mirror by Phrase:
            The question is how… I have found one that are using Alexa, but not google.
            And to be honest I don’t rely know where to start.
              sdetweil @otto
              @otto MMM-Hotword listens for the starter word (alexa, mirror, smart-mirrot…) and then signals assistant started, so the assistant can take over. MMM-AssistantMk2 is for google assistant…
              but the latest hotword can do wakeup i think… @Sean has done a good job…
              i use this combo on one of my mirror setups… (mostly to tell it to go to sleep!, vs wait til the no motion timeout)…
              but i can ask anything i can ask GA. my home automation goes thru insteon smarthome devices which I have connected thru Alexa. i haven’t tried GA for that
              • O Offline
                otto
                @sdetweil i have been doing som googleing… and found some intresseting post in the forum:
                https://forum.magicmirror.builders/topic/5003/mmm-glance-glance-focus-specific-module-s
                https://forum.magicmirror.builders/topic/8444/wake-mirror-with-voice/14?
                page=2
                https://forum.magicmirror.builders/topic/653/voice-controlled-wake-sleep-function
                • O Offline
                  otto
                  i think i will needing this:
                  MMM-Glance will be use as hiding the modules
                  MMM-Hotword for for the comand mirror mirror on the wall to active it
                  MMM-NotificationTrigger that will do the hard work and start/stop it all
                  if i can combien them some way it can work, dont know if there is a more faster way
                  and not sure how
                    sdetweil @otto
                    @otto hotword hears the phrase, and sends the notification you configure.
                    Some other module listens for that notification and does what you configure. No reason to send ANOTHER notification (notification trigger)… send what glance needs
                    • O Offline
                      otto @sdetweil
                      @sdetweil okej so u think i just need hotword and glance?
                      i did install MMM-glance i have no ide what i am doing right now. SO i guess this is as wrong at it can be:/
                        module: 'MMM-Glance',
                          defaultGlancingTime: 10000,
                          alias: {
                            "news" : "newsfeed",
                      			module: "alert", "MMM-NowPlayingOnSpotify", "updatenotification", "calendar","compliments","currentweather","weatherforecast","newsfeed","MMM-Hotword","MMM-AssistantMk2",
                            "party mode"  : ["clock", "helloworld", "MMM-Something"],
                        sdetweil
                        hotword config doc
                        https://github.com/eouia/MMM-Hotword/blob/master/documents/usage.md
                        glance only displays the info for some period of time… (default 10 seconds)… how long do you want the info to stay on screen?
                        the README.md file for each module tells how to use it
                        • O Offline
                          otto @sdetweil
                          hotword config doc
                          thanks for link i have been redning and reding it a coupel of time, and i notis the "This is a real example of recipe file"
                          is what i am looking for, that is a code for show all/hide all, the “only” thing i need figuer out, is how to get it to work, i need to record some new audio files, and change the “show all” to my phrase that i whant.
                          and creat trainer for it:D
                          looks like i maybe can solve this.
                          The qustine is if i need to anything more?
                          will that code hide all of my modules?
                          or do i need to typ all the namn of them,
                          dont rely know how to explain, i hoop u understand, if not let me know
                          var recipe = {
                            models: [
                                hotwords    : "hideall",
                                file        : "hideall.pmdl",
                                sensitivity : "0.5",
                                hotwords    : "showall",
                                file        : "showall.pmdl",
                            commands: {
                              "hideall": {
                                moduleExec: {
                                  module: [],
                                  exec: (module) => { module.hide()}
                              "showall": {
                                moduleExec: {
                                  module: [],
                                  exec: (module) => { module.show()}
                          exports.recipe = recipe // Don't remove this line.````
                          • ? Offline
                            [[global:former-user]] @otto
                            @otto I think your code is enough.(at least logically). evenif there be a problem, it would not be serious to solve.
                            • O Offline
                              otto @Guest
                              @Sean thanks for reply
                                commands: {
                                  "hideall": {
                                    moduleExec: {
                                      **module: [],**
                                      exec: (module) => { module.hide()}````
                              Do i need write all of the module namn? or is that module [], inculude all of my module?
                              if so i "just need to"
                              1. record audio file using tranier
                              2  add the file to models directory
                              2. add the recipe file to  recipes directory
                              3. add config js : recipes: ["hide_show_all"]
                              any it that right?
                              • ? Offline
                                @otto
                                module: [] will point all modules.
                                if you want, you can add specific module names in it. like module:["clock", "calendar"]
                                Your attempt is right. Wish you good luck.
                                If you have trouble, contact me via these;
                                • mail : eouia0819@gmail.com
                                • Telegram : @eouia
                                  Or github issue board.
                                  smassy
                                  @otto
                                  The way I did it is by using MMM-Assistantmk2, hotword and google voice reco. There is an already build ‘recipe’ in Assistantmk2 that do what you want.
                                  The module is hide_and_show_all_modules.js
                                  var recipe = {
                                    transcriptionHook: {
                                      "HIDE_ALL_MODULES": {
                                        pattern: "Go to sleep",
                                        command: "HIDEMODULES"
                                      "SHOW_ALL_MODULES": {
                                        pattern: "Wake up",
                                        command: "SHOWMODULES"
                                    command: {
                                      "HIDEMODULES": {
                                        moduleExec: {
                                          module:()=>{
                                            return []
                                          exec: (module, params, key) => {
                                            module.hide(1000, null, {lockString:"AMK2"})
                                      "SHOWMODULES": {
                                        moduleExec: {
                                          module:()=>{
                                            return []
                                            module.show(1000, null, {lockString:"AMK2"})
                                  In your config.js file , within the MMM-AssistantMk2 section, there is a line where you have to put all your ‘recipes’
                                  recipes: ["hide_and_show_all_modules.js","playlist.js","volume.js"],
                                  When I say ‘Jarvis Go to sleep’ my screen goes black and then when I say ‘Jarvis Wake up’ all my modules appear.
                                  For the record I’m french :smiling_face: so the phrases there are not the one I’m using, it may need some test so you don’t use google reserved words.
                                  O 2 Replies Last reply Reply Quote 0
                                  • O Offline
                                    otto @smassy
                                    yes i am doing almost the same, i found the hide_and show all… i did make new hotword, and have edit the recipes… so all i have left now, was to start it and see it work but, cant some error in the config…
                                    • O Offline
                                      otto
                                      i cant post my code, the forum is saying its spam:/
                                                             recipes: ["hiden_show_all.js",]
                                      		       chimeOnFinish: null,
                                      		       mic: {
                                      			recordProgram: "arecord",
                                      			device: "plughw:1"
                                      		models: [
                                      				hotwords    : "smart_mirror",
                                      				file        : "smart_mirror.umdl",
                                      		commands: {
                                      			"smart_mirror": {
                                      				notificationExec: {
                                      					notification: "ASSISTANT_ACTIVATE",
                                      					payload: (detected, afterRecord) => {
                                      						return {profile:"default"}
                                      				restart:false,
                                      				afterRecordLimit:0 ```
                                      i am geting error on **chimeOnFinish: null,**
                                      • ? Offline
                                        @otto
                                        First, you should confirm how it works; With MMM-Hotword itself? or With MMM-AssistantMk2? both are slightly different. I think you have some confusing at this moment.
                                        • O Offline
                                          otto @Guest
                                          @Sean dont relly understand you post. and dont rely know what i sholde do next, this is the first boot up afteri have create hotword, recipes, dont know if its wrong in my config or in my files,
                                          this is my config:
                                          https://pastebin.com/bw4QpXnL
                                          it feels like my config is a bit messy?
                                          • O Offline
                                            otto @smassy
                                            @smassy can u post your config, whant to see whear u add the recipes line,
