    Maximizing Screen Use with MMM-CalendarExt2 and Custom.css
    9 Posts 2 Posters 3.1k Views 2 Watching
    • C Offline
      CliffordW
      I am a complete noob with css, so please be kind. I am trying to move the calendar entries up to possibly show a fourth row. What I have so far is this:
      https://imgur.com/qAjF4D6
      My custom.css file looks like:
      • Magic Mirror *
      • Custom CSS *
      • By Michael Teeuw http://michaelteeuw.nl *
      • MIT Licensed. *
      • Add any custom CSS below. *
      • Changes to this files will be ignored by GIT. *
      body {
      margin: 40px;
      height: calc(100% - 100px);
      width: calc(100% - 30px);
      Any changes I make to height/width don’t seem to affect the calendar display. Can someone give me some guidance how I maximize the screen usage?
      • ? Offline
        A Former User @CliffordW
        @CliffordW
        use fullscreen_below or above.
        C 1 Reply Last reply Reply Quote 1
        • C Offline
          CliffordW @Guest
          @Sean Thanks for your reply Sean. I’ve tried both fullscreen_below and fullscreen_above and both have an identical look. Any other suggestions how to remove the blank margin at the top?
          If I change slotcount from 3 to 4, the first couple of lines from the top are chopped off.
          		module: 'MMM-CalendarExt2',
          			calendars : [
          				name: "BNC Rentals",
          				// url: "https://calendar.google.com/calendar/ical/en.canadian%23holiday%40group.v.calendar.google.com/public/basic.ics",
          				url: "https://calendar.google.com/calendar/ical/rentalsthebnc%40gmail.com/private-xxxxxxxxxxxxx/basic.ics"
          			views: [
          				title: "BNC Rentals",
          				mode: "week",
          				position: "fullscreen_below",
          				calendars: ["BNC Rentals"],
          				useEventTimeRelative: true,
          				slotCount: 3,
          				slotTitle: "",
          				slotMaxHeight: "150px",
          				slotSubTitle: "",
          				slotTitleFormat: "MMM:DD",
          				slotSubTitleFormat: "MMM:DD",
          				subslotTitleFormat: "MMM:DD",
          				maxItems: 200,
          				hideOverflow: false,
          				relativeFormat: {
          					passed: "ended %ENDFROMNOW%",
          					current: "ends %ENDFROMNOW%",
          					future: "starts %STARTFROMNOW% (%DURATION%)"
          			scenes: [
          				views: [],
          • ? Offline
            @CliffordW
            week and month views are somewhat huge. You can adjust size by CSS or set slotMaxHeight to smaller values.
            • C Offline
              CliffordW @Guest
              @Sean I’ve been looking at custom.css, and I admit it’s very new to me. Which value should I try changing to reduce the upper margin?
              ? 2 Replies Last reply Reply Quote 0
              • ? Offline
                @CliffordW
                By default, in fullscreen position, month and week view will be positioned to the bottom of the screen.
                MMM-CalendarExt2.css
                .fullscreen .CX2 { /* when the view is located on `fullscreen_below` or `fullscreen_above` */
                  position:fixed;
                  bottom: 10px;
                  margin: 20px;
                  width:calc(100vw - 40px);
                So you can redefine this section in your css/custom.css but not recommended.
                • ? Offline
                  @CliffordW
                  If what you want is just enlarge the height, set slotMaxHeight to bigger value.
                  • C Offline
                    CliffordW @Guest
                    @Sean I’d like to be able show 4 rows instead of 3. There is a considerable amount of unused space at the top of the monitor, so I’d like to reduce (remove) this margin at the top.
                    I hope I’m making sense.
                    • C Offline
                      CliffordW @Guest
                      @Sean Thanks for the guidance. I missed it the first time. Considering this pi is a single function, I might just give this a shot.
