    Majority of my emoji not showing on RPB3+
    10 Posts 4 Posters 4.8k Views 3 Watching
    • L Offline
      lilpkstud Module Developer
      I dont fully understand why my emojis are black/white or a giant box while I can clearly see it on my macbook in dev mode?
      Any help of properly downloading an emoji file or how I can show all my emojis?
      • lavolp3L Offline
        lavolp3 Module Developer @lilpkstud
        @lilpkstud Seems to be a browser issue.
        Do you have an example?
        Where do the emojis come from?
        I remember someone else has had the same issue some time ago, and my first suspicion would be that apple uses a certain code for emojis that is not understood by others.
        How to troubleshoot modules
        MMM-soccer v2, MMM-AVStock
        • L Offline
          lilpkstud Module Developer @lavolp3
          @lavolp3 I copied and pasted from https://emojipedia.org.
          An example is the fire emoji 🔥🔥🔥 https://emojipedia.org/fire/
          This specific example will come out as a white box while all my other emoji are in black and white not colored
            If they are unicode I have seen that different browsers have very different support for symbols and smileys. I think the Electron version that MM is using lacks a lot of code points (symbols).
            • L Offline
              lilpkstud Module Developer @retroflex
              @retroflex
              So theres no way to display colored emojis or even the fire emoji?
              Also would this be an Electron problem or a Raspberry/Raspbian problem?
              • brobergB Offline
                broberg Project Sponsor @lilpkstud
                @lilpkstud
                At first glance it looks like a chromium/linux problem,
                https://www.google.com/search?client=firefox-b-d&q=chromium+emoji+support
                • L Offline
                  lilpkstud Module Developer @broberg
                  @broberg Thanks for the fast replies!
                  I will look into the smart mirror this weekend
                    I’ve seen some colored symbols, but don’t know if you can get an overview of those that are working on MM.
                    • L Offline
                      @broberg @retroflex
                      FIXED!!!
                      For anyone that has the same issue I was able to fix it by doing the following steps:
                      1. Follow this article’s step to download and create font-config
                        https://www.omgubuntu.co.uk/2016/08/enable-color-emoji-linux-google-chrome-noto
                      2. Unzip folder from Raspberry Pi’s Download Folder
                      3. Open Terminal and type the following:
                        cp *.ttf ~/.fonts/
                        fc-cache -v -f
                      4. Reboot Raspberry Pi
                      5. Verify that you can see emoji (https://eosrei.github.io/emojione-color-font/full-demo.html)
                      1 Reply Last reply Reply Quote 5
                      • L Offline
                        These were the articles that helped me the most
                        https://raspberrytips.com/install-fonts-raspberry-pi/
                        • karsten13K karsten13 referenced this topic on
