    MM-Navbar - Navigation Bar for Touchscreens to hide/show modules
    47 Posts 11 Posters 51.4k Views 15 Watching
    • T Offline
      tosti007 Module Developer @in_a_days
      @in_a_days put the names you want in an array, like so:
      var exceptClasses = ["clock", "weather", "calendar"]; //The list of modules you want to keep.
      MM.getModules().exceptModule(this).exceptWithClass(exceptClasses).enumerate(
          // Here the other code
      If there is anything don’t hesitate to contact me!
      ProfileSwitcher, TouchNotifications
        shashank @tosti007
        @tosti007 hi, i tested using var exceptClasses as mentioned by you, it works perfectly as required for me. Thanks a lot for your suggestion.
        • C Offline
          chrisyy
          As mentioned from @tosti007 he wrote a module that uses the ProfileSwitcher.
          I will also continue on this project when i got the time for it.
          I plan on adding some configurable variables, like which modules should be included as a button and a config-section where u can define an icon from Font-Awesome. That should handle a few problems with which u came up here.
          But this will take me some time. So keep patient, i’m working.
          • T Offline
            tosti007 Module Developer @shashank
            @shashank You’re welcome!
            @chrisyy you can use front awsome by setting the class of the symbol’s container to fa fa-symbolname. Something like this (where symbolName can be any icon name):
            var symbolName = "paper-plane";
            var symbolContainer = document.createElement("span");
            symbolContainer.className = "fa fa-" + symbolName;
            • C Offline
              chrisyy @tosti007
              @tosti007 Something like this is what i’m thinking about
              • SnilleS Offline
                Snille Module Developer
                Hi! I made a similar module for the same purpurs. You can always copy some code if you want…
                You can find it here in the forums. :)
                Or on github.
                If you cant find it, make it and share it
                MMM-homeassistant-sensors,MMM-Modulebar,MMM-Profilepicture,MMM-Videoplayer,MMM-TautulliLatest
                • C Offline
                  Cetax @Snille
                  @Snille
                  Hi, I’m using your MMM module bar to switch my modules on and off.
                  What I don’t understand is how I switch between 2 modules.
                  So if I press a button, I want to switch off one module and another ON. Both are in the same position (‘middle_center’).
                  Or do I need another module?
                  Thank you for your help.
                  greeting
                  Stefan
                  • 3 / 3
