    PIR Sensor
    7 Posts 3 Posters 2.5k Views 2 Watching
    • T Offline
      tinsebayacc
      Hi, i have recently started building a smart mirror. Its taken me a while (software side) but i am getting there. My only issue is the PIR sensor. I have followed a tutorial and have it working great. It switches off my tv and turns it back on again. The problem is the no signal back ground i have when it switches off. I have a lg tv and its got an annoying cube that bounces around the screen. My question is how do i turn my screen black and not off. I have read some articles but i have not found any that work for me. I am using a PIR.py script and two on/off shell scripts. The shell scripts are as follows
      monitor_on.sh
      vcgencmd display_power 1
      monitor_off.sh
      vcgencmd display_power 0
      This works perfectly for turning my tv/hdmi off and back on again.
      I have read that the following shell scripts should turn the screen black but ive had no luck so far
      export DISPLAY=:0
      xset dpms force on
      export DISPLAY=:0
      xset dpms force off
      Any help would be appreciated as im a beginner and have run out of ideas. Thanks
      • brobergB Offline
        broberg Project Sponsor
        Do you have xscreensaver installed? that should do exactly what you are asking
        https://www.jwz.org/xscreensaver/man3.html
        Or maybe a wifi- wall plug could work better? (i.e cut the power to the tv completly)
        • T Offline
          tinsebayacc @broberg
          @broberg
          Thanks for your response. No I haven’t got that installed. My question is how would I add that into my pir script so that the screen saver came on after a set time and to go off when the pir is activated? Many thanks
          • brobergB Offline
            broberg Project Sponsor @tinsebayacc
            @tinsebayacc
            Just replace your screen on and off commands with the xscreensaver commands. Should work.
            like
            for black screen :
            xscreensaver-command -activate
            and to deactivate black screen :
            xscreensaver-command -deactivate
            • T Offline
              tinsebayacc
              Thanks again, i have just tried the following but nothing happens. If i run “xscreensaver-command -activate” from the terminal i get
              “xscreensaver-command: warning: $DISPLAY is not set: defaulting to “:0.0”.
              xscreensaver-command: activating”
              It then works and goes into a black screen, same thing for when i deactivate it. But nothing happens when i add it to my sh monitor on/off commands for my pir.py script.
                sdetweil @tinsebayacc
                @tinsebayacc U need to add
                DISPLAY=:0
                in front of your command
                See the installers/mm.sh for an example
                • T Offline
                  tinsebayacc
                  Thank you, that got rid of that error. Still no joy with the PIR sensor though unfortunately.
                  The strange thing is if i change my monitor_on and monitor_off sh files to
                  the pir works fine and shuts off / turns on my monitor.
                  these are my scrips
                  #!/usr/bin/env python
                  import sys
                  import time
                  import RPi.GPIO as io
                  import subprocess
                  io.setmode(io.BCM)
                  SHUTOFF_DELAY = 30 # in seconds, how long the monitor will be on until next button press or PIR detection
                  PIR_PIN = 22 # 15 on the board (this needn’t to be a PIR. Can be a button also)
                  LED_PIN = 16 # optional, don’t use as Relay-PIN. It just shows detection time of the PIR without delay time
                  def main():
                  io.setup(PIR_PIN, io.IN)
                  io.setup(LED_PIN, io.OUT)
                  turned_off = False
                  last_motion_time = time.time()
                  while True:
                      if io.input(PIR_PIN):
                          io.output(LED_PIN, io.LOW)
                          print ".",
                          sys.stdout.flush()
                          if turned_off:
                              turned_off = False
                              turn_on()
                      else:
                          if not turned_off and time.time() > (last_motion_time +
                                                               SHUTOFF_DELAY):
                              turned_off = True
                              turn_off()
                          if not turned_off and time.time() > (last_motion_time + 1):
                              io.output(LED_PIN, io.HIGH)
                      time.sleep(.1)
                  def turn_on():
                  subprocess.call(“sh /home/pi/monitor_on.sh”, shell=True)
                  def turn_off():
                  subprocess.call(“sh /home/pi/monitor_off.sh”, shell=True)
                  if name == ‘main’:
                  try:
                  main()
                  except KeyboardInterrupt:
                  io.cleanup()
                  monitor on script
                  DISPLAY=:0 xscreensaver-command -deactivate
                  monitor off script
                  DISPLAY=:0 xscreensaver-command -activate
