    Take in the weather and write.
    2 Posts 2 Posters 956 Views 2 Watching
    • Y Offline
      yeonju
      I want to use the weather as api.
      I’d like to mark the weather with compliments and use the right words.
      For example, take your coat with a temperature of 3 degrees. Like
      Help me what to do. TT
      • strawberry 3.141S Offline
        strawberry 3.141 Project Sponsor Module Developer @yeonju
        @yeonju the default compliments module has already the possibility to show compliments based on weather https://github.com/MichMich/MagicMirror/tree/master/modules/default/compliments#compliment-configuration
        However, it doesn’t support the temperature, only the weather type.
        If you want to create your own module take a look on this parts of the code:
        • Weather module sending the weather data to other modules https://github.com/MichMich/MagicMirror/blob/master/modules/default/currentweather/currentweather.js#L492
        • Compliments module processing the information https://github.com/MichMich/MagicMirror/blob/master/modules/default/compliments/compliments.js#L168-L198
