    Error when trying to run MMM-AssistantMk2
    10 Posts 5 Posters 4.1k Views 5 Watching
    • I Offline
      INMD1
      [AMK2] assistant ready
      /home/pi/MagicMirror/node_modules/electron/dist/electron js/electron.js: symbol lookup error: /home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/node/extension_binary/electron-v3.0-linux-arm-glibc/grpc_node.node: undefined symbol: __atomic_store_8
      npm ERR! code ELIFECYCLE
      npm ERR! syscall spawn
      npm ERR! file sh
      npm ERR! errno ENOENT
      npm ERR! magicmirror@2.9.0 start: `sh run-start.sh`
      npm ERR! spawn ENOENT
      npm ERR!
      npm ERR! Failed at the magicmirror@2.9.0 start script.
      npm ERR!     /home/pi/.npm/_logs/2019-10-24T05_25_04_096Z-debug.log
      I am trying to install mmm-hotword, MMM-AssistantMk2 to make Magic Mirror today, but I am having an error. What’s the cause?
        sdetweil @INMD1
        @INMD1 you need to follow the rest of the installation steps, which cover errors like this,
        • W Offline
          waseemghaly
          @sdetweil I have followed all the steps in the installation guide and still getting the same error as @INMD1 please let me know if there is a certain set of instructions that needs to be followed. Thank you
            sdetweil @waseemghaly
            @waseemghaly @INMD1 we will neeed to wait for @Sean to help, he is the module author
            • ? Offline
              A Former User
              Well. I’m not sure because, someone still has this issue despite my instruction in github. But I tested and got success today. So I hope this working for you.
              Reason
              • grpc(which is an essential program to use Google Assistant SDK) installed by npm install in the shell is not compatible with electron of MagicMirror on runtime. Because electron has its own JS engine and it is different with your global level environments. That is why rebuild of grpc for electron is needed.
              • Unfortunately, some last newgrpc versions might have some bug on rebuilding for specific electron. As far as I know, grpc@1.24.0 has one, and grpc@1.24.1 has also (grpc team says it was fixed, but I found another bug on 1.24.1)
              Solution
              In Raspbian Buster / RPI 4B+ I’ve tested.
              1. Check your gcc version. If > = 8, downgrade it to 7.
              sudo apt-get install gcc-7
              gcc -v
              It should say gcc version 7.3.0 (Raspbian 7.30-19) or something similar ( < = 7 )
              If not done well, google it how to downgrade your gcc.
              1. then do this; (I’ll assume you’ve already tried npm install on your previous installation step)
              cd ~/MagicMirror/modules/MMM-AssistantMk2
              npm install grpc@1.23.4
              npm install --save-dev electron-rebuild
              ./node_modules/.bin/electron-rebuild
              It will take 30 minutes ~ 1 hour. Don’t power off or stop it.
              If not done well… Sorry, I cannot help.
              At this moment, this is one and only way to work properly.
              In my RPI4B+(Raspbian) / Mac (Catalina) / Jetson Nano (Ubuntu 18.04) / Khadas Edge-V (Armbian Buster) / Asus Tinkerboard (TinkerOS), worked today.
              • W Offline
                waseemghaly
                Issue solved here: https://github.com/eouia/MMM-AssistantMk2/issues/231
                • C Offline
                  Chethan @Guest
                  @sean please help me still am getting this error i hope you will give the solution
                  npm ERR! errno 255
                  npm ERR! @bugsounet/snowboy@2.0.5 install: bash scripts/installer.sh
                  npm ERR! Exit status 255
                  npm ERR!
                  npm ERR! Failed at the @bugsounet/snowboy@2.0.5 install script.
                  npm ERR!     /home/pi/.npm/_logs/2021-02-10T11_13_15_758Z-debug.log
                    sdetweil @Chethan
                    @chethan snowboy 2.5 is very old. this module (mk2) has been abandonded, and replaced by MMM-GoogleAssistant, whos author has left the forum.
                    • C Offline
                      Chethan @sdetweil
                      @sdetweil @sdetweil can you please tell me which one should I install or use give me a link plz and I use last time in the 2020-08-20 on that time i use raspberry pi that time it’s working now it’s not working
                        sdetweil @Chethan
                        @chethan i do not have an answer
                        mk2 will not work
                        mmm-googleassistant may not work due to snowboy issues. snowboy has also been abandonded
                        https://github.com/Kitt-AI/snowboy/
