    MMM-Sunrise-Sunset
    44 Posts 9 Posters 24.0k Views 10 Watching
    • vblokeV Offline
      vbloke Module Developer
      I’ve created a module that displays the local sunrise, sunset and solar noon times. maybe it’ll be useful for people.
      alt text
      alt text
      Any offers to make it better are gratefully received!
      [card:prydonian/MMM-Sunrise-Sunset]
      • buzzkcB Offline
        buzzkc
        Looks nice. I may add that to my bedside touch screen…Thanks!
        Darren
        My Build: https://forum.magicmirror.builders/topic/11153/new-non-mirror
          mrdenmark
          just added it,thanks for your work, a couple of issues i found-
          it doesn’t seem to account for southern hemisphere or timezones or something as i get sunrise at 5.36 pm sunset at 7.23 am and solar noon at 12.30 am,also,in my config inline or list makes no difference,-its always inline.
          heres my config-{
          module: “MMM-Sunrise-Sunset”,
          position: “top_left”,
          latitude: “-44.57”,
          longitude: “168.50”,
          Layout: “list”,
          vblokeV 1 Reply Last reply Reply Quote 0
          • vblokeV Offline
            vbloke Module Developer @mrdenmark
            @mrdenmark it appears that the API doesn’t like the Southern Hemisphere…
            http://api.sunrise-sunset.org/json?lat=-44.57&lng=168.50&date=today
            Is that config exactly as it appears in your config file? layout should be all lowercase.
              mrdenmark @vbloke
              @vbloke i changed the config file to lowercase,that fixed the layout
              as for the api?not sure what the options are,i’ll see if i can an alternative,
              thanks for your help
              • vblokeV Offline
                @mrdenmark the API returns all dates in UTC, so I may look at putting a time zone offset option in the config, or if you feel confident doing that yourself, feel free to try.
                  mrdenmark
                  would it be possible to add a line with the day length?i’m not sure how to go about adding a time offset,i’ll do some research
                  • vblokeV Offline
                    @mrdenmark if you update the module now, it should account for the timezone if you set it in your config. From your latitude/longitude, yours (I think) would be “Pacific/Auckland”.
                    Try this:
                      module: "MMM-Sunrise-Sunset",
                    	latitude: "-44.57",
                    	longitude: "168.50",
                    	timezone: "Pacific/Auckland",
                    	layout: "list"
                      mrdenmark
                      worked,cheers!
                        sdetweil @vbloke
                        @vbloke you can get the timezone from the lat/lng
                        http://www.geonames.org/export/web-services.html#timezone
                        https://stackoverflow.com/questions/16086962/how-to-get-a-time-zone-from-a-location-using-latitude-and-longitude-coordinates
                        • vblokeV Offline
                          https://github.com/prydonian/MMM-Sunrise-Sunset
                          Made a fairly big update using a different API that needs a free key.
                          https://ipgeolocation.io/signup.html
                          It now gives you moonrise and moonset times and day length.
                          • H Offline
                            henry2man
                            I tried this module but activating this causes my MM to show nothing. I had no error messages on MM logs (in my case, a docker server-only instance) and nor on my Chrome console.
                            In other words it looks that the IPGeo free key expires in 1 day…
                            vblokeV pugslyP 2 Replies Last reply Reply Quote 0
                            • vblokeV Offline
                              vbloke Module Developer @henry2man
                              @henry2man the API is limited to 1000 calls per day. It doesn’t appear to expire after a day.
                              Can you post the config for the module?
                              it should look like this:
                                    position: "bottom_bar",
                              		apiKey: "API_KEY",
                              		latitude: "123.123",
                              		longitude: "23.456",
                              		layout: "inline"
                              • H Offline
                                henry2man
                                I removed the config but seemed like yours. I followed the README from master. I’ll try again later, but also I’ve reviewed this API
                                https://api.sunrise-sunset.org/json?lat=36.7201600&lng=-4.4203400&formatted=0
                                It has enough information and seems to be free.
                                What do you think?
                                • vblokeV Offline
                                  @henry2man that’s the one I was using before, but it required a lot of work to get the time in your local time zone as all times were returned as UTC.
                                  The new API uses your location to format the time automatically.
                                  H Mykle1M 2 Replies Last reply Reply Quote 0
                                  • H Offline
                                    henry2man @vbloke
                                    @vbloke In this link there is a simple way to get a ISO 8601 into your local timezone --> https://stackoverflow.com/a/31453408
                                    var utcDate = '2011-06-29T16:52:48.000Z';  // ISO-8601 formatted date returned from server
                                    var localDate = new Date(utcDate);
                                    api.sunrise-sunset.org can return ISO 8601 dates using
                                    formatted=0
                                    parameter…
                                    If date parsing is the major issue & this solution works I think this approach is simpler. Even you can default the URL and simply configure lat/long & style (inline/list)
                                    Just my 2 cents…
                                      Mykle1 Project Sponsor Module Developer @vbloke
                                      @vbloke
                                      This is right out of my MMM-SunRiseSet module.
                                      Feel free to use it if you like. :thumbsup:
                                      // sunrise set to local time using moment
                                         var sunrise = document.createElement("div");
                                         sunrise.classList.add("small", "bright", "sunrise");
                                         sunrise.innerHTML = "Sunrise is at " + moment(SunRiseSet.sunrise).local().format("h:mm a") + " &nbsp &nbsp "
                                      + "Sunset is at " + moment(SunRiseSet.sunset).local().format("h:mm a");
                                         wrapper.appendChild(sunrise);
                                      • pugslyP Offline
                                        pugsly @henry2man
                                        @henry2man
                                        I am having the same problem, whenever I put it in my config the display is blank.
                                          sdetweil @pugsly
                                          @pugsly not in config… you have to edit the actual module code
                                          pugslyP 1 Reply Last reply Reply Quote 0
                                          • pugslyP Offline
                                            pugsly @sdetweil
                                            @sdetweil Not sure I know what you mean. When I put this in my config the screen is all blank:
                                                    header: "Sunrise",
                                                        latitude: "39.2907",
                                                        longitude: "-75.6344",
                                                        apikey: "xxxxxxxxxxxxxxxxxxxxxxxxxxxxxx",
                                                        layout: "inline"
                                            • 1 / 3
