    no helper modules
    5 Posts 4 Posters 5.0k Views 4 Watching
    • C Offline
      CFJoe
      Hi @all,
      after new installaton i have no helper modules?
      But MM works fine.
      Is that correct?
      magicmirror@2.0.0 start /home/pi/MagicMirror
      electron js/electron.js
      Loading config …
      Loading module helpers …
      Initializing new module helper …
      All module helpers loaded.
      Starting server op port 8080 …
      Server started …
      Starting module: newsfeed
      Sockets connected & modules started …
      Launching application.
      Create new calendar fetcher for url: http://calendar.google.com/calendar/ical/de.german%23holiday%40group.v.calendar.google.com/public/basic.ics - Interval: 300000
      Create new news fetcher for url: http://www.tagesschau.de/xml/rss2 - Interval: 300000
      Joe
      • Y Offline
        yawns Moderator
        That’s correct, these modules don’t have any helper module. If you take a look at the module folders you will see there is no node_helper.js file for these modules.
        So all is fine.
        • C Offline
          CFJoe
          OK, Thx for info. I am Newbee…
            swagatbiswal
            I am trying to run it in ubuntu 16 , And I can only see black screen, No module is loading.
            What could be the cause. After that I tried with https://github.com/HackerHouseYT/AI-Smart-Mirror and this module is working fine.
            Any clue?
              Mykle1 Project Sponsor Module Developer @swagatbiswal
              @swagatbiswal said in no helper modules:
              I have MM installed on uBuntu. I remember updating node.js and npm was necessary. Are you getting any errors in the terminal or the console of dev tools?
