    MMM-PIR doesn´t work with MM 2.8
    13 Posts 5 Posters 5.3k Views 5 Watching
      shgmongohh
      I have update to 2.9. But unfortunaly its the same.
      I have tested the PIR. It detects motion, so the hardware is ok. I don´t understand why it doesn´t turn off the monitor.
        sdetweil @shgmongohh
        @shgmongohh what did u configure for the callbackscripts config entry?
        • L Offline
          lxne Project Sponsor
          Unfortunately getting MMM-PIR up and running on 2.8/2.9 is some kind of a mystery. It’s working on my setup now, but I honestly do not know why. You can read a bit about the odyssey over at github https://github.com/mboskamp/MMM-PIR/issues/10
            shgmongohh
            The same as before when it was still working
                    module: 'MMM-PIR-Sensor',
            			//https://github.com/paviro/MMM-PIR-Sensor
                      sensorPIN: 23,//18, //VCC 5V; BMC Pin: gpio readall
            		powerSaving: true
            • pugslyP Offline
              pugsly
              I have been having the same problem kinda where my monitor goes to sleep and it never wakes back up. I know what needs to be added somewhere in order to fix it.
              fbset -depth 8; fbset -depth 16
              for some reason even after issuing a wakeup code to the HDMI the fbset command is needed in order for the screen to come back. No clue how to get that into the code at all.
              • cowboysdudeC Offline
                cowboysdude Module Developer
                Folks don’t want to make this terribly hard but I wrote this module way back when and it’s not dependent on MagicMirror. It runs in it’s own window all by itself. Keeping in mind that I am using a PIR sensor… it works and has for 3 years…
                Simple Pir Sensor on/off
                  shgmongohh
                  Hi Folks,
                  maybe I have found the problem (unfortunatly not the solution.).
                  In the Version where the PIR is working I have the GIOP Version 2.44.
                  Where the PIR Sensor is not working I have the GIOP Version 2.25.
                  How can I update the giop version 2.25 to 2.44?
                    shgmongohh @shgmongohh
                    @shgmongohh
                    I have found a solution to fix the gpio problem
                    npm install wiringpi-node
                    found on here
                      @shgmongohh said in MMM-PIR doesn´t work with MM 2.8:
                      so it should be added as a dependency in the package.json file
