    MMM-PIR doesn´t work with MM 2.8
    13 Posts 5 Posters 5.4k Views 5 Watching
      sdetweil @shgmongohh
      @shgmongohh what did u configure for the callbackscripts config entry?
      • L Offline
        lxne Project Sponsor
        Unfortunately getting MMM-PIR up and running on 2.8/2.9 is some kind of a mystery. It’s working on my setup now, but I honestly do not know why. You can read a bit about the odyssey over at github https://github.com/mboskamp/MMM-PIR/issues/10
          shgmongohh
          The same as before when it was still working
                  module: 'MMM-PIR-Sensor',
          			//https://github.com/paviro/MMM-PIR-Sensor
                    sensorPIN: 23,//18, //VCC 5V; BMC Pin: gpio readall
          		powerSaving: true
          • pugslyP Offline
            pugsly
            I have been having the same problem kinda where my monitor goes to sleep and it never wakes back up. I know what needs to be added somewhere in order to fix it.
            fbset -depth 8; fbset -depth 16
            for some reason even after issuing a wakeup code to the HDMI the fbset command is needed in order for the screen to come back. No clue how to get that into the code at all.
            • cowboysdudeC Offline
              Folks don’t want to make this terribly hard but I wrote this module way back when and it’s not dependent on MagicMirror. It runs in it’s own window all by itself. Keeping in mind that I am using a PIR sensor… it works and has for 3 years…
              Simple Pir Sensor on/off
                shgmongohh
                Hi Folks,
                maybe I have found the problem (unfortunatly not the solution.).
                In the Version where the PIR is working I have the GIOP Version 2.44.
                Where the PIR Sensor is not working I have the GIOP Version 2.25.
                How can I update the giop version 2.25 to 2.44?
                  shgmongohh @shgmongohh
                  @shgmongohh
                  I have found a solution to fix the gpio problem
                  npm install wiringpi-node
                  found on here
                    @shgmongohh said in MMM-PIR doesn´t work with MM 2.8:
                    so it should be added as a dependency in the package.json file
