    MMM-PIR doesn´t work with MM 2.8
    13 Posts 5 Posters 5.8k Views 5 Watching
      shgmongohh
      after a few years with a working MM 2.0 I want a fresh installed MM2.8 on my Pi3.
      The hardware configuration wasn´t changed. With MM2.0 MMM-PIR was working fine. After the fresh installation, without changing PINs or any other hardware, MMM-PIR doesn´t turn of the monitor.
      Has anybody an idea, why MMM-PIR doesn´t work on MM2.8
      Sebastian
        sdetweil @shgmongohh
        @shgmongohh how did u update? 2.9 is the latest
          shgmongohh
          I delete MM folder from the pi and install it via
          bash -c "$(curl -sL https://raw.githubusercontent.com/MichMich/MagicMirror/master/installers/raspberry.sh)"
            @shgmongohh ok, then got 2.9…
            and then u installed the pir module and did an npm install in its folder (as it has dependencies above MM)…
            its package.json lists onoff module which is not part of MM…
            and if still problems, opened developers window, ctrl-shift-i, select the tab labeled console, and maybe add PIR to the filter field. to see any errors…
            2.0 to 2.9 is a BIG change, lots of non-MM code changed
            I have a new install script
            see https://forum.magicmirror.builders/topic/10171/anyone-want-to-try-updated-installer
            and an update script
            see https://forum.magicmirror.builders/topic/10859/new-update-upgrade-script-ready-for-testing
            both coming in the next release…
            but usable now
              shgmongohh
              I have update to 2.9. But unfortunaly its the same.
              I have tested the PIR. It detects motion, so the hardware is ok. I don´t understand why it doesn´t turn off the monitor.
                @shgmongohh what did u configure for the callbackscripts config entry?
                • L Offline
                  lxne Project Sponsor
                  Unfortunately getting MMM-PIR up and running on 2.8/2.9 is some kind of a mystery. It’s working on my setup now, but I honestly do not know why. You can read a bit about the odyssey over at github https://github.com/mboskamp/MMM-PIR/issues/10
                    shgmongohh
                    The same as before when it was still working
                            module: 'MMM-PIR-Sensor',
                    			//https://github.com/paviro/MMM-PIR-Sensor
                              sensorPIN: 23,//18, //VCC 5V; BMC Pin: gpio readall
                    		powerSaving: true
                    • pugslyP Offline
                      pugsly
                      I have been having the same problem kinda where my monitor goes to sleep and it never wakes back up. I know what needs to be added somewhere in order to fix it.
                      fbset -depth 8; fbset -depth 16
                      for some reason even after issuing a wakeup code to the HDMI the fbset command is needed in order for the screen to come back. No clue how to get that into the code at all.
                      • cowboysdudeC Offline
                        Folks don’t want to make this terribly hard but I wrote this module way back when and it’s not dependent on MagicMirror. It runs in it’s own window all by itself. Keeping in mind that I am using a PIR sensor… it works and has for 3 years…
                        Simple Pir Sensor on/off
                          shgmongohh
                          Hi Folks,
                          maybe I have found the problem (unfortunatly not the solution.).
                          In the Version where the PIR is working I have the GIOP Version 2.44.
                          Where the PIR Sensor is not working I have the GIOP Version 2.25.
                          How can I update the giop version 2.25 to 2.44?
                            shgmongohh @shgmongohh
                            @shgmongohh
                            I have found a solution to fix the gpio problem
                            npm install wiringpi-node
                            found on here
                              @shgmongohh said in MMM-PIR doesn´t work with MM 2.8:
                              so it should be added as a dependency in the package.json file
