    dead SD-card every aprox. 6 months
    19 Posts 10 Posters 8.9k Views 12 Watching
      sdetweil
      i switched to using a small ssd USB stick, boot from the sd card, run from the usb stick… all the i/o goes to the ssd
      • BKeyportB Offline
        BKeyport Module Developer
        can you explain how to do this, or provide a link to an explaination?
          sdetweil @BKeyport
          https://www.tomshardware.com/news/boot-raspberry-pi-from-usb,39782.html
          really easy, copy all the data from sd to ssd, then change one line in sd config, reboot… voila
          on one machine I had trouble with regularly, I had a 500gb ssd drive I wasn’t using…
          for my main dev machine, I just bought a 128gig usb stick ssd. came with a cable, took 20 minutes to copy the data…spent $35 from amazon
            @BKeyport I am NOT trying to BOOT from the usb stick, most pi’s don’t support that
            • BKeyportB Offline
              Speak of the evil, the evil happens. Blew up my SD card.
                sdetweil @BKeyport
                @BKeyport boooooo
                • P Offline
                  PHAGE.GOV @MoreLinux
                  @MoreLinux so how do you edit this text file using root?
                  • P Offline
                    @MoreLinux said in dead SD-card every aprox. 6 months:
                    tmpfs /tmp tmpfs defaults,noatime,nosuid,size=100m 0 0
                    tmpfs /var/tmp tmpfs defaults,noatime,nosuid,size=30m 0 0
                    tmpfs /var/log tmpfs defaults,noatime,nosuid,mode=0755,size=100m 0 0
                    tmpfs /var/run tmpfs defaults,noatime,nosuid,mode=0755,size=2m 0 0
                    tmpfs /var/spool/mqueue tmpfs defaults,noatime,nosuid,mode=0700,gid=12,size=30m 0 0
                    could you potentilally give a more in-depth guide to doing this?
                      sdetweil @PHAGE.GOV
                      @PHAGE-GOV edit the file as root
                      if u are not root, then u must use the sudo prefix on a command
                      commands to edit on linux are vi, nano and (too many) others…
                      I use nano
                      SO its
                      sudo nano /etc/fstab
                      has nothing to do with MM, just basic linux skills.
