    dead SD-card every aprox. 6 months
    19 Posts 10 Posters 9.1k Views 12 Watching
      marvin424 Project Sponsor
      Hi Zdeněk,
      SD cards have limited write cycles so it’s just a question of time when your pi will not start.
      To increase their life, all manufactures have implemented an internal algorithm which uses different physical sectors when writing data to the SD-Card, see wear leveling.
      You can help your hardware if you “oversize” the SD-Card, avoid ram discs and swap partitions.
      I am using a 16GB SD-Card even though just 4GB is used by the system. It’s running now for more than 4 years without any trouble.
      Brgds, Michael…
      zdenekZ 1 Reply Last reply Reply Quote 0
      • zdenekZ Offline
        zdenek @marvin424
        @marvin424 that’s really weird. I’m also using 16 cards, in both my mirrors (one is for testing) a in both I’ve had to replace card in about 6 months max. Maybe I’m using to many modules, maybe there is al lot of writes on card… I’ll try SSD
          almliden
          I know this is an old thread, but hope someone finds this helpful.
          1. Use a proper power source, one reason for SD-cards to wear out fast is that the RPi doesn’t receive enough power to actually perform the writes and therefore writes bad data which corrupts the card. Depending on which model it is it might need more power. Since I switched to better power supplies I haven’t had a dead SD-card for quite a while, so it seem to have an impact.
          2. Use RPi-images that writes to /tmpfs, or configure them to write temporary data to RAM to reduce wear on the SD-card.
          3. Since it hasn’t been mentioned before in this thread, avoid powering off the device by removing power since this could cancel an ongoing write which potentially could corrupt the card. If you need to power it off, do it properly.
          SergeS 1 Reply Last reply Reply Quote 3
          • SergeS Offline
            Serge @almliden
            @almliden said in dead SD-card every aprox. 6 months:
            How to do that?
            MoreLinuxM 1 Reply Last reply Reply Quote 0
            • MoreLinuxM Offline
              MoreLinux @Serge
              @Serge said in dead SD-card every aprox. 6 months:
              How to do that?
              As root user, edit the file /etc/fstab and add the following lines:
              tmpfs    /tmp    tmpfs    defaults,noatime,nosuid,size=100m    0 0
              tmpfs    /var/tmp    tmpfs    defaults,noatime,nosuid,size=30m    0 0
              tmpfs    /var/log    tmpfs    defaults,noatime,nosuid,mode=0755,size=100m    0 0
              tmpfs    /var/run    tmpfs    defaults,noatime,nosuid,mode=0755,size=2m    0 0
              tmpfs    /var/spool/mqueue    tmpfs    defaults,noatime,nosuid,mode=0700,gid=12,size=30m    0 0
              Now most of the write intensive files write to the Raspberry PI’s ram.
              Disable the swap file, as it can be write intensive too. First check if you have swap activated with the command:
              free -h
              If your total swap is 0B, you are good, if not, execute the following commands:
              dphys-swapfile swapoff
              dphys-swapfile uninstall
              systemctl disable dphys-swapfile
              Now the command activated with the command:
              free -h
              should tell you that you are not using the swap file anymore.
              P 2 Replies Last reply Reply Quote 0
                i switched to using a small ssd USB stick, boot from the sd card, run from the usb stick… all the i/o goes to the ssd
                • BKeyportB Offline
                  BKeyport Module Developer
                  can you explain how to do this, or provide a link to an explaination?
                    sdetweil @BKeyport
                    https://www.tomshardware.com/news/boot-raspberry-pi-from-usb,39782.html
                    really easy, copy all the data from sd to ssd, then change one line in sd config, reboot… voila
                    on one machine I had trouble with regularly, I had a 500gb ssd drive I wasn’t using…
                    for my main dev machine, I just bought a 128gig usb stick ssd. came with a cable, took 20 minutes to copy the data…spent $35 from amazon
                      @BKeyport I am NOT trying to BOOT from the usb stick, most pi’s don’t support that
                      • BKeyportB Offline
                        Speak of the evil, the evil happens. Blew up my SD card.
