    dead SD-card every aprox. 6 months
    19 Posts 10 Posters 10.5k Views 12 Watching
    • zdenekZ
      zdenek
      hi all
      what do u do use for store MM? I’ve tried USB and it was slow. I’ve bought about 5 different micro SD cards (Kingston, …) but after 3-8 months, when I did restart, the RPi doesn’t start at all. Some “error” with mounting or something (fatal error…). For me the only solution was reinstall (recovery, reinstall Jessie and reinstall MM). What’s wrong? Too many access to SD card and cause fo that damage?
      Any recommendation?
      thanks
      Zdeněk
      • buzzkcB
        buzzkc
        Had that happen just last week, did a backup of the card using win32diskimager after it was restored.
        I’m looking at setting up a read-only os to play around with and configure myself… https://medium.com/swlh/make-your-raspberry-pi-file-system-read-only-raspbian-buster-c558694de79
        Darren
        My Build: https://forum.magicmirror.builders/topic/11153/new-non-mirror
          I have one system (physical location.) that eats sd cards too Pi or odroid hardware doesn’t matter…
          haven’t figured out the cause yet
            MadScientist
            I use the cheapest SSD I could get for my Pi at that time. It’s running non-stop for 2 years without any issues. You can get 120GB SSD’s for less than 20€. A SATA-USB adapter costs around 2€ from China. Maybe that’s an option for you.
            SD cards are not designed to be permanently written to. They wear out too fast.
            • zdenekZ
              zdenek
              @MadScientist thx, sounds great, i’ll try that
                marvin424 Project Sponsor
                Hi Zdeněk,
                SD cards have limited write cycles so it’s just a question of time when your pi will not start.
                To increase their life, all manufactures have implemented an internal algorithm which uses different physical sectors when writing data to the SD-Card, see wear leveling.
                You can help your hardware if you “oversize” the SD-Card, avoid ram discs and swap partitions.
                I am using a 16GB SD-Card even though just 4GB is used by the system. It’s running now for more than 4 years without any trouble.
                Brgds, Michael…
                zdenekZ 1 Reply Last reply
                • zdenekZ
                  zdenek @marvin424
                  @marvin424 that’s really weird. I’m also using 16 cards, in both my mirrors (one is for testing) a in both I’ve had to replace card in about 6 months max. Maybe I’m using to many modules, maybe there is al lot of writes on card… I’ll try SSD
                  • A
                    almliden
                    I know this is an old thread, but hope someone finds this helpful.
                    1. Use a proper power source, one reason for SD-cards to wear out fast is that the RPi doesn’t receive enough power to actually perform the writes and therefore writes bad data which corrupts the card. Depending on which model it is it might need more power. Since I switched to better power supplies I haven’t had a dead SD-card for quite a while, so it seem to have an impact.
                    2. Use RPi-images that writes to /tmpfs, or configure them to write temporary data to RAM to reduce wear on the SD-card.
                    3. Since it hasn’t been mentioned before in this thread, avoid powering off the device by removing power since this could cancel an ongoing write which potentially could corrupt the card. If you need to power it off, do it properly.
                    SergeS 1 Reply Last reply
                    Reply Quote 3
                    • SergeS
                      Serge @almliden
                      @almliden said in dead SD-card every aprox. 6 months:
                      How to do that?
                      MoreLinuxM 1 Reply Last reply
                      • MoreLinuxM
                        MoreLinux @Serge
                        @Serge said in dead SD-card every aprox. 6 months:
                        How to do that?
                        As root user, edit the file /etc/fstab and add the following lines:
                        tmpfs    /tmp    tmpfs    defaults,noatime,nosuid,size=100m    0 0
                        tmpfs    /var/tmp    tmpfs    defaults,noatime,nosuid,size=30m    0 0
                        tmpfs    /var/log    tmpfs    defaults,noatime,nosuid,mode=0755,size=100m    0 0
                        tmpfs    /var/run    tmpfs    defaults,noatime,nosuid,mode=0755,size=2m    0 0
                        tmpfs    /var/spool/mqueue    tmpfs    defaults,noatime,nosuid,mode=0700,gid=12,size=30m    0 0
                        Now most of the write intensive files write to the Raspberry PI’s ram.
                        Disable the swap file, as it can be write intensive too. First check if you have swap activated with the command:
                        free -h
                        If your total swap is 0B, you are good, if not, execute the following commands:
                        dphys-swapfile swapoff
                        dphys-swapfile uninstall
                        systemctl disable dphys-swapfile
                        Now the command activated with the command:
                        free -h
                        should tell you that you are not using the swap file anymore.
                        P 2 Replies Last reply
                          i switched to using a small ssd USB stick, boot from the sd card, run from the usb stick… all the i/o goes to the ssd
                          • BKeyportB
                            BKeyport Module Developer
                            can you explain how to do this, or provide a link to an explaination?
                              sdetweil @BKeyport
                              https://www.tomshardware.com/news/boot-raspberry-pi-from-usb,39782.html
                              really easy, copy all the data from sd to ssd, then change one line in sd config, reboot… voila
                              on one machine I had trouble with regularly, I had a 500gb ssd drive I wasn’t using…
                              for my main dev machine, I just bought a 128gig usb stick ssd. came with a cable, took 20 minutes to copy the data…spent $35 from amazon
                                @BKeyport I am NOT trying to BOOT from the usb stick, most pi’s don’t support that
                                • BKeyportB
                                  Speak of the evil, the evil happens. Blew up my SD card.
                                    sdetweil @BKeyport
                                    @BKeyport boooooo
                                      PHAGE.GOV @MoreLinux
                                      @MoreLinux so how do you edit this text file using root?
                                        @MoreLinux said in dead SD-card every aprox. 6 months:
                                        could you potentilally give a more in-depth guide to doing this?
                                          sdetweil @PHAGE.GOV
                                          @PHAGE-GOV edit the file as root
                                          if u are not root, then u must use the sudo prefix on a command
                                          commands to edit on linux are vi, nano and (too many) others…
                                          I use nano
                                          SO its
                                          sudo nano /etc/fstab
                                          has nothing to do with MM, just basic linux skills.
