MMM-SoccerLiveScore
Hey, what about the Confed Cup? Is it possible to show? If its still in, what ID do I need to add?
Where does it pull the fixtures from? There is currently a new draw for Europa and Champions League Qualifiers. Europa games are today.
Hey Guys
i think i solved the problem for now with the blank table.
The problem is in the config.js the leagues command, if u put only one ID in this command likeleagues: [35], // it doesnt work
but
leagues: [35, 999], // it works. dont know why im not a programmer^^
but i have a question too,
where can i configure that my header and the scores are not going from the left side to my right side cause i have the clock on the left side and the weather on my right side -
I have a problem when switching from the results to the table. At the beginning everything runs as it should. After about an hour there is when switching misfires. Attached to the link of a video of the error, hope it works.
Does somebody has any idea?Greeting Jörg
EDIT:
For me this is probably the “blank screen problem”
With only one league, it only comes to an interruption and then nothing will be displayed. With two leagues, everything works as it should.
The tip of Arzeg with the entry [35, 999] unfortunately does not work. -
Here is another error. If the table is displayed without names, the line with teams etc. is moved about it, does not fit properly.
Hey Jörg,
bad to hear that the tip doesnt work for you.
For me it works perfect.
But I still have the problem with the width of the module, it goes from the left to the right side and i dont know, how i can change the width…MfG Arzeg
EDIT:
I dont know if it’s for you a solution but I use MMM-soccer for the table and MMM-SoccerLiveScore as my live ticker, so i set showTables to false in config.js
Its not the perfect solution but i can live with it -
This post is deleted! -
HI,
is it possible to send an alarm/notification if there is a goal in any game in a league i set to shown on the mirror?
Maybe its quite easy but honestly i do not have any idea how this alterts/notifications work
The results and the table of the german bundesliga are now also not updated. A pity about an otherwise great module and the author does not care about the errors.
@JoeFranz are u sure? Everything works fine at my mm
So I have three errors in it. Blank sreen if only one league is displayed, with the table without names fit above the symbols and is not updated now, only after a reboot of magicmirror. Here is my config.js
module: ‘MMM-SoccerLiveScore’,
position: ‘bottom_left’,
leagues: [35, 9],
showNames: false,
showLogos: true,
displayTime: 60 * 1000,
showTables: true
i love this module but there is a problem with update live score and table. It don’t work for me. All other installed module works fine and update work well. if i restart mm it loads the new data score etc
I created a new version of this module:
https://github.com/master117/MagicMirror-FootballLeagues
Most of the errors mentioned above, should be fixed. It works with only one league selected for example. The old module also polls its undocumented datasource too often and eventually gets banned, which is why the scores stop refreshing. It does not yet have support for logos.
Greetings,
master117 -
@master117 I just tried and got two errors on the installation:
npm WARN enoent ENOENT: no such file or directory, open ‘/home/pi/MagicMirror/modules/package.json’
npm WARN enoent ENOENT: no such file or directory, open ‘/home/pi/MagicMirror/modules/node_modules/node_helper/package.json’
npm WARN modules No description
npm WARN modules No repository field.
npm WARN modules No README data
npm WARN modules No license field.When I add the module to the config.js nothing shows up. I tried several different configurations and problem persist. any idea on what I am doing wrong?
@fabbr Did you ever get this working? I get the same errors;
npm WARN enoent ENOENT: no such file or directory, open '/home/pi/MagicMirror/modules/package.json' npm WARN enoent ENOENT: no such file or directory, open '/home/pi/MagicMirror/modules/node_modules/node_helper/package.json' npm WARN modules No description npm WARN modules No repository field. npm WARN modules No README data npm WARN modules No license field.@master117 Anything?
Those are not errors (ERR) just regular warnings (WARN). They are unrelated to whatever issue you are having, they are even unrelated to the module itself, request (the thing being installed) is a semi standard nodejs library and not made by me.
I would guess either your config is wrong or there is not enough space on the mirror. If you list your steps and config I may be able to help.
Here is my config:
{ module: 'MagicMirror-FootballLeagues', position: 'bottom_center', header: 'Live-Scores', config: { leagues: [445, 455, 464, 456, 450], showNames: true, displayTime: 60 * 1000, showTables: true, showLogos: true, apiKey: 'MyApiKey' } }, -
I don’t think the API is working anymore. :(
Is it possible to integrate the World Cup 2018 into this module?
Is there a way to diasable tables for specific leagues? e.g. I don’t want to show tables for the Champions Leagues, cause it will only show the table of group A.
