MMM-CalendarExt2
4 Posts 3 Posters 2.0k Views 4 Watching
    shfaxx
    Re: MMM-CalendarExt2
    Hello all, loving this project, new to MM… I see lots of things I like but don’t always see how to accomplish then, any help you guys can provide would be awesome.
    Using a 1920x1080 display rotated, want full month view to replace traditional wall calendar.
    • How can I get events to wrap to second line in month view?
      Saw somewhere that it’s not possible due to multi day events? However I think I just saw someone post this.
    • My entire left side of my calendar getting cut off - How can I shift the whole calendar to the right? I’m assuming I have some conflict border or margin setting somewhere, but after many edits, I still cannot correct it.
    • Why does calendar disappear for a second and come back? Is it refreshing? Can I stop it from disappearing?
    *************  CONFIG.JS **********
                              module: 'MMM-CalendarExt2',
                                calendars : [
                                    url: "https://rest.cozi.com/api/ext/
    /*                              url: "https://calendar.google.com/calendar/
                                views: [
                                      title: "What's Happening Soon",
                                      mode: "daily",
                                      calendars: [],
                                      position:"top_left",
                                      hideOverflow: false,
                                      slotCount: 3,
                                      className: "remove_empty_slot"
                                    mode: "month",
                                    position: "fullscreen_below",
                                    timeFormat: "h:mm",
                                    slotMaxHeight: "200px",
                                    maxItems: 500,
                                scenes: [
    ******************CSS*****************
    body {
            margin: 10px;
    /*      height: calc(100%);*/
            width: 1060px;
    .CX2 .remove_empty_slot .eventCount_0 {
      display:none;
    .CX2 .cellSlot .slotSubTitle {
    color:#3A6061;
    .CX2 .cellSlot .slotTitle {
    color:#999;
    text-alignment: "right";
    .CX2 .cellSlot.weekday_6 .slotSubTitle {
    color:#3A6061;
    .CX2 .cellSlot.weekday_6 .slotTitle {
    color:#999;
    .CX2 .cellSlot.weekday_7 .slotSubTitle {
    color:#661414;
    .CX2 .slot{
    padding:0px 4px;
    border:4px solid #000000;
    /* Formats header */
    .CX2 .slot .slotHeader {
    background-color:#000000;
    border-top:2px solid #3A6061;
    border-bottom:2px solid #3A6061;
    margin-top:5px;
    margin-bottom:15px;
    height:calc(var(--font-size) + 6px);
    font-weight:normal;
    padding:6px 6px 0;
    .CX2 .today .slotHeader { /* today slot /
    background-color:#afcecf;
    /* background-color:#080a0a;*/
    color:#999;
    .CX2 .today .slotHeader * {
    color:#999;
    .CX2 .today .slotSubTitle {
    color:#3A6061;
    .CX2 .weekSlot {
    position:relative;
    .CX2 .today.slot {
    /*background-color:#afcecf;*/
    background-color:#0a1010;
    border:4px solid #1d2f30;
    .CX2 .slot > .slotContent{
    position:relative;
    width:100%;
    background-image: none;
    .CX2 .module-content { /* fake module body */
    color:#999;
    font-family: 'Roboto', sans-serif;
    .CX2 .weeksmark {
    display:none;
    /***** Event *****/
    .CX2 .event {
    padding:5px;
    margin:12px 0 0 8px;
    background-color:transparent;
    position:relative;
    text-align:left;
    /* how to treat full day events*/
    .CX2 .event.fullday {
    border-radius:unset;
    color:#999;
    S ? 2 Replies Last reply Nov 30, 2019, 7:46 PM Reply Quote 0
      shfaxx @shfaxx
      Also would like to know how to remove the extra line at the bottom of the events in each day. This sucks up a bunch of space.
      B 1 Reply Last reply Dec 1, 2019, 8:53 AM Reply Quote 0
        BKeyport Module Developer @shfaxx
        @shfaxx Check to see if “hideOverflow: false,” in your view section takes out the extra space. It did for me in another view style.
        also, @sean would have the answer on the cutoff, but I suspect it’s something to do with the rotation - I think it’s been covered before, check the main topic at https://forum.magicmirror.builders/topic/9279/
        • ? Offline
          A Former User @shfaxx
          @shfaxx said in MMM-CalendarExt2:
          Can’t wrap. Ideally, it could be done by modification of CSS, but I don’t recommend it.
          I regard this table views as a summary or overview, so I didn’t make it show details. MagicMirror screen resolution is not so enough(especially vertical layout). If wrapping would be allowed, the number of showing events should be less. For example, you have 6 events on Nov. 13, 4 are partially shown and 2 are hidden. With wrapping, 1 or 2 events would be displayed fully but others might be hidden. I believe it would be worse than current.
          My suggestions are;
          • To use with other detail views - daily or upcoming, current views - together to get detailed information.
          • You can abbreviate titles and give separated styles by transform option to distinguish easily with less text.
            (Example; you can give an icon and blue font for Kim's schedule and remove the text Kim from event Title.)
          Maybe. But without whole CSS, I have no idea about it.
          Yes, it is refreshing. Adjust interval from configuration.
