    IR touch frame Calibration help
    6 Posts 4 Posters 1.5k Views 4 Watching
      Raz
      Hello im new to this forum i really need some advice I have a magic mirror and im trying to Calibrate it to work on landscape however this dont work how do i rotate the setting for it to work on landscape currently its working on portrait.
      • C Offline
        cyberphox
        xinput-calibrator if using a Rasp Pi
          Raz
          @cyberphox said in IR touch frame Calibration help:
          xinput-calibrator
          Thank you for your reply All i know is im using a TV and IR sensors what is Rasp pi?
          • C Offline
            cyberphox
            You said you have a Magic Mirror. What are you running it on?
              sdetweil
              Rasp Pi is Raspberry Pi
              • cowboysdudeC Offline
                cowboysdude Module Developer
                How to rotate a display on Rasp Pi… Unless you’re not using a Rasp Pi
                https://www.raspberrypi-spy.co.uk/2017/11/how-to-rotate-the-raspberry-pi-display-output/
                As for calibration you should check with manufacturer… I am using a 32" TV with an IR frame so it covers 100% and no calibration was needed.
