    Node/ npm error? Blank magicmirror. Please help - desperate, frustrated and grateful for the right direction
    11 Posts 4 Posters 3.9k Views 4 Watching
    • N Offline
      nakulbende
      Hello,
      I am trying to amke a magicmirror for my wife - this was supposed to be an easy Christmas present. I am pretty well versed with Arduino and Pis, so I thought it will be straightforward. But, reality was very different.
      I am getting a blank screen. My output from npm start in MagicMirror directory is:
      pi@magicmirror:~/MagicMirror $ npm start
      > magicmirror@2.9.0 start /home/pi/MagicMirror
      > sh run-start.sh
      Starting MagicMirror: v2.9.0
      Loading config ...
      Loading module helpers ...
      WARNING! Could not load config file. Starting with default configuration. Error found: Error: Cannot find module 'googleapis'
      App threw an error during load
          at Module._resolveFilename (internal/modules/cjs/loader.js:602:15)
          at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/common/reset-search-paths.js:35:12)
          at Function.Module._load (internal/modules/cjs/loader.js:528:25)
          at Module.require (internal/modules/cjs/loader.js:658:17)
          at require (internal/modules/cjs/helpers.js:20:18)
          at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-Buller/node_helper.js:14:18)
          at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-Buller/node_helper.js:214:3)
          at Module._compile (internal/modules/cjs/loader.js:711:30)
          at Object.Module._extensions..js (internal/modules/cjs/loader.js:722:10)
          at Module.load (internal/modules/cjs/loader.js:620:32)
      { Error: Cannot find module 'googleapis'
          at Module.load (internal/modules/cjs/loader.js:620:32) code: 'MODULE_NOT_FOUND' }
      Launching application.
      I have the following modules clones in my directory:
      • DailyXKCD
      • Beestat
      • Buller
      • DarkSkyForecast
      • Lyft
      • Fitbit
      • MyCommute
      • Bring
      • DailyPokemon
      • MBTA
      • pi-hole-stats
      I am using a Raspberry pi 3, and installed MM using the curl script. The first alarm was whenever I tried using npm install inside a module directory. I got a node.js incompatibility command. I was on 10.something, and following the text updated to latest version of 9.something. After that, the npm warning of incompatible version went away, but the following still comes up:
      pi@magicmirror:~/MagicMirror/modules/MMM-Buller $ npm install
      npm WARN Invalid version: "1.0"
      npm WARN MMM-Buller No description
      npm WARN MMM-Buller No repository field.
      npm WARN MMM-Buller No README data
      npm WARN MMM-Buller No license field.
      Is this a catastrophic warning? I do not think my config.json is an issue. npm run config:check outputs:
      pi@magicmirror:~/MagicMirror $ npm run config:check
      > magicmirror@2.9.0 config:check /home/pi/MagicMirror
      > node tests/configs/check_config.js
      Checking file...  /home/pi/MagicMirror/config/config.js
      Your configuration file doesn't contain syntax errors :)
      Also, for some reason, npm does not recognize `npm audit’ command.
      I know it is a lot of info, I will promtly try to post outputs of any validation commands.
      Lastly - my config.json is as follows:
      /* Magic Mirror Config Sample
       * MIT Licensed.
      var config = {
      	port: 8080,
      	language: "en",
      	timeFormat: 12,
      	units: "metric",
      	// Modules //
      		// Alert
      			module: "alert",
      		// Notifications
      			module: "updatenotification",
      			position: "top_bar"
      		// Buller - It will put out reminders and compliments
      			module: 'MMM-Buller',
      			position: 'top_bar',
      			//header: 'Buller',
      				debug: false,
      				lists: [
      						type: 'gTasks',
      						updateInterval: 1000 * 60 * 1 * 2, //every minutes
      						color: 'pink',
      						icon: 'fas heart'
      						type: 'gTasks',
      						icon: 'fas lightbulb-o',
      						updateInterval: 1000 * 60 * 1 * 3, //every minutes
      						color: 'blue'
      		// Clock
      			module: "clock",
      				timeFormat: '12',
      				displaySeconds: 'false',
      				showPeriod: 'true',
      				clockBold: 'true',
      				timezone: 'America/New_York' //Karachi
      		// calendar
      			//header: "Calenar",
      						symbol: "island-tropical",
      						url: "webcal://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics"
      						symbol: "user-friends",
      		//Buller - this one will be todo in house
      			position: 'top_right',
      			header: 'To Do',
      				debug: false,
      				lists: [
      						type: 'gTasks',
      						updateInterval: 1000 * 60 * 1 * 1, //every minutes
      						icon: 'fas tasks',
      		// dARKYsKY module
      			module: "MMM-DarkSkyForecast",
      			header: "XXXXX",
      			classes: "default everyone",
      				apikey: "XXXX",
      				latitude: "XXXX",
      				longitude: "XXXX",
      				iconset: "3c",
      				concise: false,
      				forecastLayout: "table",
      				units: "us",
      				maxHourliesToShow: "4",
      				maxDailiesToShow: "4",
      		// XKCD
      			module: 'DailyXKCD',
      			position: 'bottom_left',
      				invertColors: true,
      				showTitle: true,
      				showAltText: true,
      				randomComic: true
      		// Bring shopping list
      			module: "MMM-Bring",
      			position: "bottom_center",
      				email: "USER@EXAMPLE.COM",
      				password: "SECRET",
      				updateInterval: 15, // in Minutes
      				listName: "Weggies", // optional
      				showListName: true,
      				activeItemColor: "#EE524F",
      				latestItemColor: "#4FABA2",
      				showLatestItems: false,
      				maxItems: 0,
      				maxLatestItems: 0,
      				locale: "de-DE"
      		// MBTA - Main x Emerson
      			module: 'MMM-MBTA',
      			position: 'bottom_left', // This can be any of the regions.
      			header: "XXXXXx",
      				apikey: 'XXXX',
      				updateInterval: 30,
      				stations: 'XXX',
      				formatETA: 'true',
      				showOnly: ["Subway", "Bus"],
      				colorIcons: 'true',
      				direction: 'Inbound',
      				noETAToBack: 'false'
      		// MBTA - Davis
      			module: 'MMM-MBTA',
      			header: "XXXX",
      				apikey: 'XXXX',
      				updateInterval: 20,
      				stations: 'XXX": "XXX',
      				formatETA: 'true',
      				colorIcons: 'true',
      				flipDirection: 'true',
      		// Commute
      			module: 'MMM-MyCommute',
      			position: 'bottom_right',
      			header: 'XXXX',
      			classes: 'default everyone',
      				apikey: 'XXXX ',
      				origin: 'XXXX',
      				startTime: '06:00',
      				endTime: '18:00',
      				hideDays: [0,6],
      				pollFrequency: '10 * 60 * 1000',
      				destinations: [
      						destination: 'XXXX',
      						label: 'XXXX',
      						mode: 'transit',
      						color: '#82E5AA'
      						label: 'XXXX',
      						mode: 'driving'
      						label: 'XXXX',
      						mode: 'transit',
      						color: '#82E5AA'
      						label: 'XXXX',
      						mode: 'driving'
      • N Offline
        nakulbende
        @sdetweil - your script worked flawlessly, and everything just works. I have a few kinks to sort out but it is looking like i can finish my wife’s gift before christmas after all. I can’t thank you enough!
        :folded_hands_medium_skin_tone: :person_bowing_medium_skin_tone:
        Thank you all for pointing me in the right direction!
        S FoziF 2 Replies Last reply Reply Quote 0
          Mykle1 Project Sponsor Module Developer @nakulbende
          @nakulbende
          Was it working ever? If npm is v1 then you are seriously down level and should upgrade that.
          If it was working and stopped after an addition then remove/comment out that addition.
          It could be one of the modules you installed. You could disable all and turn them on one by one to determine which (if any) is causing the issue.
          Frankly, I would use @sdetweil’s installer script. It really is the best option and he fully supports it. It has saved many a user and I have found it quite useful. I dare say that everyone here would say the same and recommend it.
          You’ll find the url here
          https://forum.magicmirror.builders/topic/10171/anyone-want-to-try-updated-installer
          S N 2 Replies Last reply Reply Quote 0
            sdetweil @Mykle1
            @nakulbende @Mykle1 I agree. lets back up and start with the default config and then add one module at a time…
            so, rename your config.js
            cd ~/MagicMirror/config
            mv config.js config.js.save
            cp config.js.sample config.js
            and then start the mirror
            again:
            now, pic one module,
            copy the module section from the config.js.save to the config.js
            restart the mirror… verify
            save config.js
            go to again
            many modules cannot be used more than once without special handling…
            so don’t do two of anything yet
            mmm-buller only documents one dependency
            “googleapis” : “>=33.0.0”
            so, do that manually
            from the mmm-buller folder do
            npm install googleapis@33.0.0
            I don’t think u have to reinstall the base…
            let me know
            • N Offline
              nakulbende @Mykle1
              @Mykle1 How do you update npm - when I do this, would I have to run npm install in each module folder again?
              The mirror works with default configuration just fine. I will try disabling them one by one.
              I did use the usual script bash -c "$(curl -sL https://raw.githubusercontent.com/MichMich/MagicMirror/master/installers/raspberry.sh)". How is @sdetweil’s script different?
              S Mykle1M 2 Replies Last reply Reply Quote 0
              • N Offline
                nakulbende
                Thanks all - I will install dependencies and try to add modules one by one. Is there a way to backup my installation if I do decide to reinstall using @sdetweil 's script? Would just copying the whole ~/MagicMirror folder work?
                  sdetweil @nakulbende
                  @nakulbende the one you used hasn’t been updated in quite some time…
                  quite a few things have changed…
                  my scipt, which will replace the current one on next release, has been updated and tested for about 6 months.
                  see here
                  there is also a new version update script, that will help migrate from one MM release to another…
                  see here https://forum.magicmirror.builders/topic/10859/new-update-upgrade-script-ready-for-testing
                  to ‘backup’. just rename the MagicMirror folder, no copy, no delete…
                    @nakulbende install assumes that NO previous installation exists…so, no MagicMirror folder.
                    the installer and updater both create log files so we can see what happened at the time.
                    the original does not
                      @nakulbende said in Node/ npm error? Blank magicmirror. Please help - desperate, frustrated and grateful for the right direction:
                      I see @sdetweil has been in contact with you. You’re in good hands. Follow his directions and advice. I’m pretty sure his installer will install the correct versions of node and npm so you won’t have to do anything regarding that. Any modules you install after that (that require dependencies) will need you run npm install in their respective folders.
                      • N Offline
                        nakulbende
                          @nakulbende cool… glad it helped…
                          come on back if you find some other problem!
                          • FoziF Offline
                            Fozi Project Sponsor @nakulbende
                            @nakulbende oh, great you sorted it out! My recommendation on Reddit to join this forum was not that bad😁. Another happy builder on bord!
