    Magic Mirror will not boot but Pi will, Cache issue?
    25 Posts 2 Posters 7.4k Views 2 Watching
      sdetweil @tkaauf32
      @tkaauf32 change head -n 10 to -n 20
      • T Offline
        tkaauf32
        I hope you can decipher this haha
        0_1577726759666_d55e67d9-9db4-4a13-9820-e92f4186c64d-image.png Screen Shot 2019-12-30 at 11.04.44 AM
          sdetweil @tkaauf32
          @tkaauf32 need with head -n 20, to give more lines of output
          /opt/Wolfram is taking a bit of space
          • T Offline
            tkaauf32 @sdetweil
            @sdetweil I pasted the wrong image. Thanks for your patience with me
            0_1577727269763_ff6f75b7-7d77-4203-b3c3-6b434617c8a2-image.png Screen Shot 2019-12-30 at 11.25.35 AM
              sdetweil @tkaauf32
              @tkaauf32 its not the logs… not even showing in the top 20.
              that /opt/Wolfram is taking 16.7 % or disk space (1146764/6846289)
              /usr/lib & share is taking 53%
              I would guess that your memory card is too small…
              what size is it?
              what did u add last?
              • T Offline
                tkaauf32 @sdetweil
                @sdetweil I guess I need to delete the wolfram. I’m using an 8GB but I have’t manually changed anything so I’m surprised that it doesn’t work anymore. Maybe the logs put it over the edge.
                  sdetweil @tkaauf32
                  @tkaauf32 logs are pretty small… do the du /var/logs | sort | head thing, just on the logs folder…
                  • T Offline
                    tkaauf32 @sdetweil
                    @sdetweil Permission denied. Also tried it with /logs and /log. /log says “is a directory” and the latter says permission denied
                      sdetweil @tkaauf32
                      @tkaauf32 sorry, typo
                       du  /var/log 2>/dev/null
                      may need sudo
                      sudo du  /var/log 2>/dev/null
                      • T Offline
                        tkaauf32 @sdetweil
                        • 2 / 3
