    MagicMirror stopped working after screensaver installed
    16 Posts 2 Posters 5.6k Views 3 Watching
    • D
      demetry07
      After I installed the screensaver to stop the screen going dark my MagicMirror stopped working.
      I now get this error.
      magicmirror@2.10.0 start /home/pi/MagicMirror
      ./run-start.sh
      App threw an error during load
      Error: Cannot find module ‘module-alias/register’
      at Module._resolveFilename (internal/modules/cjs/loader.js:602:15)
      at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/common/reset-search-paths.js:35:12)
      at Function.Module._load (internal/modules/cjs/loader.js:528:25)
      at Module.require (internal/modules/cjs/loader.js:658:17)
      at require (internal/modules/cjs/helpers.js:20:18)
      at Object. (/home/pi/MagicMirror/js/app.js:15:1)
      at Object. (/home/pi/MagicMirror/js/app.js:283:3)
      at Module._compile (internal/modules/cjs/loader.js:711:30)
      at Object.Module._extensions…js (internal/modules/cjs/loader.js:722:10)
      at Module.load (internal/modules/cjs/loader.js:620:32)
      A JavaScript error occurred in the main process
      Uncaught Exception:
        sdetweil @demetry07
        @demetry07 said in MagicMirror stopped working after screensaver installed:
        what does that mean?
        • D
          demetry07
          I installed
          apt-get install xscreensaver
            sdetweil @demetry07
            @demetry07 ok… that should not have affected the mirror in any way…
            • D
              demetry07
              I agree but that was all I did.
              Installed then disabled making the screen go blank then sudo reboot.
              After reboot I get the error I posted above.
                sdetweil @demetry07
                @demetry07 weird…
                please do
                cd ~/MagicMirror
                npm instal
                advise npm start results after
                • D
                  demetry07
                  That fixed it thank you.
                    sdetweil @demetry07
                    @demetry07 for the future, I have a script as part of install to disable screensaver on a lot of systems…
                    its also in the installers folder with 2.10
                    screensaveroff.sh
                    • D
                      demetry07 @sdetweil
                      @sdetweil When I ran the install it asked me if I wanted to disable screensaver and I said yes but my screen was still going black over night. I would have to CTRL-Q out then it would run again automatically after a few seconds. Thought installing the screensaver and disabling it would help. Will see after tonight.
                      • D
                        demetry07
                        I spoke to soon. This morning it stopped working again.
                        I ran
                        npm install
                        then
                        sudo reboot
                        then cd ~/MagicMirror
                        then
                        npm start
                        Here are the results
                        ./run-start.sh
                        [11:35:13.428] [LOG] Starting MagicMirror: v2.10.0
                        [11:35:13.448] [LOG] Loading config …
                        [11:35:13.463] [LOG] Loading module helpers …
                        [11:35:13.466] [LOG] No helper found for module: alert.
                        [11:35:13.594] [LOG] Initializing new module helper …
                        [11:35:13.596] [LOG] Module helper loaded: updatenotification
                        [11:35:13.597] [LOG] No helper found for module: clock.
                        [11:35:13.599] [LOG] No helper found for module: currentweather.
                        /home/pi/MagicMirror/node_modules/electron/dist/electron js/electron.js: symbol lookup error: /home/pi/MagicMirror/modules/MMM-PIR/node_modules/epoll/build/Release/epoll.node: undefined symbol: _ZN2v816FunctionTemplate3NewEPNS_7IsolateEPFvRKNS_20FunctionCallbackInfoINS_5ValueEEEENS_5LocalIS4_EENSA_INS_9SignatureEEEiNS_19ConstructorBehaviorENS_14SideEffectTypeE
                        npm ERR! code ELIFECYCLE
                        npm ERR! syscall spawn
                        npm ERR! file sh
                        npm ERR! errno ENOENT
                        npm ERR! magicmirror@2.10.0 start: ./run-start.sh
                        npm ERR! spawn ENOENT
                        npm ERR!
                        npm ERR! Failed at the magicmirror@2.10.0 start script.
                        npm ERR! /home/pi/.npm/_logs/2020-01-07T17_35_13_737Z-debug.log
                        I pulled the log file here is the data in the log file.
                        1 verbose cli [ ‘/usr/bin/node’, ‘/usr/bin/npm’, ‘start’ ]
                        2 info using npm@6.13.4
                        3 info using node@v10.18.0
                        4 verbose run-script [ ‘prestart’, ‘start’, ‘poststart’ ]
                        5 info lifecycle magicmirror@2.10.0~prestart: magicmirror@2.10.0
                        6 info lifecycle magicmirror@2.10.0~start: magicmirror@2.10.0
                        7 verbose lifecycle magicmirror@2.10.0~start: unsafe-perm in lifecycle true
                        8 verbose lifecycle magicmirror@2.10.0~start: PATH: /usr/lib/node_modules/npm/node_modules/npm-lifecycle/node-gyp-bin:/home/pi/MagicMirror/node_modules/.bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/local/games:/usr/games
                        9 verbose lifecycle magicmirror@2.10.0~start: CWD: /home/pi/MagicMirror
                        10 silly lifecycle magicmirror@2.10.0~start: Args: [ ‘-c’, ‘./run-start.sh’ ]
                        11 info lifecycle magicmirror@2.10.0~start: Failed to exec start script
                        12 verbose stack Error: magicmirror@2.10.0 start: ./run-start.sh
                        12 verbose stack spawn ENOENT
                        12 verbose stack at ChildProcess. (/usr/lib/node_modules/npm/node_modules/npm-lifecycle/lib/spawn.js:48:18)
                        12 verbose stack at ChildProcess.emit (events.js:198:13)
                        12 verbose stack at maybeClose (internal/child_process.js:982:16)
                        12 verbose stack at Process.ChildProcess._handle.onexit (internal/child_process.js:259:5)
                        13 verbose pkgid magicmirror@2.10.0
                        14 verbose cwd /home/pi/MagicMirror
                        15 verbose Linux 4.19.75-v7+
                        16 verbose argv “/usr/bin/node” “/usr/bin/npm” “start”
                        17 verbose node v10.18.0
                        18 verbose npm v6.13.4
                        19 error code ELIFECYCLE
                        20 error syscall spawn
                        21 error file sh
                        22 error errno ENOENT
                        23 error magicmirror@2.10.0 start: ./run-start.sh
                        23 error spawn ENOENT
                        24 error Failed at the magicmirror@2.10.0 start script.
                        24 error This is probably not a problem with npm. There is likely additional logging output above.
                        25 verbose exit [ 1, true ]
                        Thoughts?
                          sdetweil @demetry07
                          fun times!!
                          do
                          cd ~/MagicMirror
                          npm install electron-rebuild
                          node_modules/.bin/electron-rebuild
                          • D
                            demetry07
                            Ran the suggested commands see below. Looks like they both ran just fine.
                            pi@raspberrypi:~/MagicMirror $ npm install electron-rebuild
                            • electron-rebuild@1.8.8
                              added 68 packages from 42 contributors and audited 3926 packages in 124.52s
                            16 packages are looking for funding
                            run npm fund for details
                            found 0 vulnerabilities
                            pi@raspberrypi:~/MagicMirror $ node_modules/.bin/electron-rebuild
                            ✔ Rebuild Complete
                            ./run-start.sh
                            [11:51:32.453] [LOG] Starting MagicMirror: v2.10.0
                            [11:51:32.478] [LOG] Loading config …
                            [11:51:32.491] [LOG] Loading module helpers …
                            [11:51:32.494] [LOG] No helper found for module: alert.
                            [11:51:32.615] [LOG] Initializing new module helper …
                            [11:51:32.617] [LOG] Module helper loaded: updatenotification
                            [11:51:32.619] [LOG] No helper found for module: clock.
                            [11:51:32.620] [LOG] No helper found for module: currentweather.
                            npm ERR! file sh
                            npm ERR!
                            npm ERR! /home/pi/.npm/_logs/2020-01-07T17_51_32_806Z-debug.log
                              sdetweil @demetry07
                              @demetry07 ok, module is a pain in the butt…
                              cd modules/MMM-PIR
                              npm install
                              ~/MagicMirror/node_modules/.bin/electron-rebuild
                              • D
                                demetry07
                                Yeah I missed that in the log I see it now. Thanks for the help after updating that Module it’s starting again. Do you have a recommendation for a PIR Module that works better then something else?
                                  sdetweil @demetry07
                                  @demetry07 no… sorry, none of the PIR modules play nice
                                  • D
                                    demetry07
                                    Ok thank you again for helping.
