    A problem about MMM-BMW-DS
    25 Posts 4 Posters 9.5k Views 4 Watching
    • zokiyaZ Offline
      zokiya @sdetweil
      Thank you.I took your suggestion to modify the code, but it doesn’t seem to work.:face_with_cold_sweat:
      S Mykle1M 2 Replies Last reply Reply Quote 0
        sdetweil @zokiya
        @zokiya open the developers window, ctrl-shift-i on the keyboard, select the tab labeled console, and scroll up to see any errors, usually red text.
          @sdetweil said in A problem about MMM-BMW-DS:
          number to the right of : should not have quotes… turns them into strings
          In this case, they ARE stings. The OP’s config example is rife with syntax errors. So, I corrected it, tested it, confirmed its validity and posted it, minus the API key. :thumbsup:
            sdetweil @Mykle1
            @Mykle1 hmmmmm, need to learn, never correct a module author!
              Mykle1 Project Sponsor Module Developer @zokiya
              @zokiya
              Please follow sdetweil’s suggestion to look for errors. Again, if you copy and paste the following config entry directly into your config it should avoid the syntax errors. Enter your API key EXACTLY. This is very important.
                    disabled: false,
                    module: "MMM-BMW-DS",
                    position: "bottom_bar", // bottom_bar is best
                      apiKey: "YOUR API KEY GOES HERE", // Free API key @ darksky.net
                      tempUnits: "F", // MUST BE CAPITAL LETTER C or F
                      lat: '31.318889',
                      lng: '121.395',
                      css: "1", // 1=default, 2=Clean, 3=Lord of the Rings, 4=handwriting, 5=Julee, 6=Englebert, "" = returns default css
                      ownTitle: "Current Conditions", // Use your own language and statement
                      playSounds: "yes", // yes = weather sounds, no = no weather sounds
                      useHeader: false,
                      header: "Your header",
                      maxWidth: "100%",
              zokiyaZ 1 Reply Last reply Reply Quote 0
                Feel free to correct me any time you like. :-)
                I’ve learned much by being corrected. :thumbsup:
                • T Offline
                  TheGeekfather @Mykle1
                  @Mykle1
                  Your modules are excellent :)
                  • Off topic but does Hello-Lucy still work? I’ve installed it but always starts off with blank screen - even when I put hide all - false. Mic works but no response. I start with saying hello lucy and then Show - your key words like HOROSCOPE. Any help would be GREATLY Appreciated!
                    Mykle1 Project Sponsor Module Developer @TheGeekfather
                    @TheGeekfather said in A problem about MMM-BMW-DS:
                    Thank you for your kind words. :thumbsup:
                    Yes, in fact I’ve just finished a substantial upgrade. You’ve installed recently?
                    Please paste your config entry in a code block ( </> in menu) so I can take a look at it.
                    T 1 Reply Last reply Reply Quote 1
                    • T Offline
                      @Mykle1
                      		disabled: false,
                      		module: "Hello-Lucy",
                      		position: "bottom_left",
                        			keyword: "HELLO LUCY",               // MUST BE CAPITALS to make Lucy start listening
                        			timeout: 15,                        // timeout listening for a command/sentence
                        			defaultOnStartup: "Hello-Lucy",
                        			standByMethod: 'DPMS',              // 'DPMS' = anything else than RPi or 'PI'
                        			sounds: ["1.mp3", "11.mp3"],        // welcome sound at startup. Add several for a random choice of welcome sound
                        			confirmationSound: "ding.mp3",      // when command is accepted. use your own or default, name and extension of sound file
                        			                // startHideAll: false,   if true, all modules start as hidden
                        			pageOneModules: ["Hello-Lucy", "MMM-Astro"],    // default modules to show on page one/startup
                        			pageTwoModules: ["MMM-BMW-DS", "MMM-Events"],     // modules to show on page two
                        			pageThreeModules: ["email"],               // modules to show on page three
                        			pageFourModules: ["MMM-iFrame"],                // modules to show on page four
                        			pageFiveModules: [],                              // modules to show on page five
                        			pageSixModules: [],                               // modules to show on page six
                        			pageSevenModules: [],                             // modules to show on page seven
                        			pageEightModules: [],                             // modules to show on page eight
                        			pageNineModules: [],                              // modules to show on page nine
                        			pageTenModules: [],                               // modules to show on page ten
                        @TheGeekfather
                        Ok, the config is fine. I just tested it.
                        1. When you say Hello Lucy, the microphone icon does not start pulsing?
                        2. Have you installed and enabled the modules that are named in the config?
                        • 3 / 3
