    A problem about MMM-BMW-DS
    25 Posts 4 Posters 13.3k Views 4 Watching
    • T
      TheGeekfather @Mykle1
      @Mykle1
      Hi, Yes, modules are set to disabled: false
      Also, I don’t see any microphone icon and even with starthideall at false - still blank on boot up screen?
      i can hear my microphone through my speaker when I talk so mic seems to be working
      unless, I’m not suppose to hear my voice on speaker?
      Mykle1M 1 Reply Last reply
      • Mykle1M
        Mykle1 Project Sponsor Module Developer @TheGeekfather
        @TheGeekfather
        startHideAll: false, if true, all modules start as hidden
        First, you need to comment out after the comma if you are using this line. The entire line is commented out in your example. If you uncomment that line then the module will error.
        Then the module is not loading. You should see the microphone icon along with, Say, ‘Hello Lucy’ on screen.
        That seems odd. Mine does not do that. I don’t know if that’s a problem
        Start your mirror using npm start dev and then click the console tab in the window that opens. Scroll to find any errors in red and report
        T 1 Reply Last reply
        • T
          @Mykle1
          I Just heard “Hello Michael What would you like to see”
          It seems I was missing lmtool which I just installed
          • T
            TheGeekfather @TheGeekfather
            @TheGeekfather
            OK, getting closer :)
            says under mic icon
            Initializing then undefined so it seems I just have to get mic to work
            • Mykle1M
              @TheGeekfather
              Did you not follow the readme on how to install the dependencies?
              T 2 Replies Last reply
              • T
                @Mykle1
                OK, that might be the problem because for some reason all the modules were installed in
                modules/default
                so when I bash dependencies, it says it couldn’t find the /modules/Hello-Lucy folder
                I moved the Hello-Lucy folder to modules - ran bash dependencies.sh again but no go :(
                Thank you for any help !!! I’m a retired computer science teacher that wont’s to keep on learning :)
                • zokiyaZ
                  zokiya @Mykle1
                  @Mykle1 I just copied and pasted the code you corrected, reset my API, and copied and pasted it, but it didn’t work. I checked the developer window and there are only two warnings, and they don’t seem to have anything to do with this module. I checked my Dark Sky console and it shows that my API has not been called. Now I suspect that there is a problem with my network.
                  • Mykle1M
                    @TheGeekfather said in A problem about MMM-BMW-DS:
                    modules/default
                    I wonder how that happened? I could take a guess. ;-)
                    The only modules that belong in the modules/default folder are the default modules from the MagicMirror installation. All additional modules should be installed into the modules folder itself, not the default folder. Each repo should have directions for installation. cd MagicMIrror/modules being the most common
                    Because the installer expects to find Hello-Lucy where it belongs.
                    No go, meaning what? Errors? Where did you run that command?
                    • Mykle1M
                      Mykle1 Project Sponsor Module Developer @zokiya
                      @zokiya said in A problem about MMM-BMW-DS:
                      Do you have other modules that are calling an API. Are they working? Please let me know when you’ve confirmed your internet is working and we’ll get MMM-BMW-DS working for you.
                      • T
                        @Mykle1
                        Hi, I hear the voice at startup but mic says “Undefined” under it - line through indicating mic not found? I can record and play back at the command line and USB sound card same as yours.
                        Do you think it could be a dependency that wasn’t installed?
                        Thank you again for your help
                        • Mykle1M
                          Uhh, I’m not using a USB sound card.
                          I think, rather than trying to troubleshoot this, it would be best that you delete your current installation of Hello Lucy. You didn’t exactly follow the directions. You can save your config entry.
                          Read the arecordHelp.md file inside the docs folder of the repo. The microphone should be working before the installation of Hello Lucy.
                          Then follow the installation instructions in the readMe.md file. if you deviate from the instructions then I won’t be able to help you.
