    MMM Remote Control Error
    11 Posts 5 Posters 4.4k Views 4 Watching
    • C Offline
      Chynovsky
      Hi, I followed the “https://github.com/Jopyth/MMM-Remote-Control” guide and after the first reboot, I get an error that says: Please create a config file. I’m still a noob to linux, and would appreciate some help!
      I have been using putty to make the command input easier.
      • T Offline
        ttarzan
        @Chynovsky You probably made a mistake when inserting the module into config.js. Sometimes it is only one character, which is missing or too much. Post your config.js here.
        • C Offline
          Chynovsky
          [0_1578708666463_config.txt](Uploading 100%)
          Thanks for the response! I didn’t know how to transfer the entire file, so I just copied from VNC into a text document. that’s the attached config js file!
          Update. I don’t think it got attached, but here it is. I don’t know how to find the API key for the MMM remote. I also removed the appid on weather.
          /* Magic Mirror Config Sample
           * MIT Licensed.
          var config = {
          	address: "0.0.0.0", // Address to listen on, can be:
          	port: 8080,
          	ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1", "::ffff:192.168.0.182", "::ffff:192.168.0.171"], // Set [] to allow all IP addresses
          	language: "en",
          	timeFormat: 12,
          	units: "imperial",
          			     // false, default for all  NON-armv6l devices
          			module: "alert",
          			module: "updatenotification",
          			position: "top_bar"
          			module: "clock",
          			position: "top_left"
          			header: "Holidays",
          						symbol: "calendar-check",
          						url: "webcal://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics"					}
          			module: "compliments",
          			position: "middle_center"
          			module: "currentweather",
          				locationID: "4703384",  //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
          				appid: ""
          			module: "weatherforecast",
          			header: "Weather Forecast",
          				appid: ""
          		  module: "MMM-NowPlayingOnSpotify",
          		  position: "bottom_left",
          		    clientID: "hidden",
          		    clientSecret: "hidden",
          		    accessToken: "hidden"
          		    module: 'MMM-Remote-Control'
          		    // uncomment the following line to show the URL of the remote control on the mirror
          		    position: 'bottom_left'
          		    // you can hide this module afterwards from the remote control itself
          			customCommand: {},  // Optional, See "Using Custom Commands" below
          			customMenu: "custom_menu.json", // Optional, See "Custom Menu Items" below
          			showModuleApiMenu: true, // Optional, Enable the Module Controls menu
          			apiKey: "",         // Optional, See API/README.md for details
          • brobergB Offline
            broberg Project Sponsor @Chynovsky
            @Chynovsky you are missing commas after
            And
            It should be
            module: 'MMM-Remote-Control',
            And
            position: 'bottom_left',
            • C Offline
              Chynovsky
              Thanks for the update. I just added the commas and I’m still getting an error. Is the localhost change to 0.0.0.0 and the ip addresses added correct?
              • C Offline
                Chynovsky
                ok, the problem WAS on the local host and IP section. it worked after modifying just the commas you mentioned!
                Any tips on fixing the ip address section?
                “(3) For security reasons, the MagicMirror (and therefore the Remote Control) is not reachable externally. To change this, configure address, and ipWhitelist in your config.js (see these lines in the sample config). For example change address to 0.0.0.0 and add two allowed devices with IP-Adresses 192.168.0.42 and 192.168.0.50:”
                  sdetweil @Chynovsky
                  @Chynovsky
                  ipWhitelist: [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”, “::ffff:192.168.0.182”, “::ffff:192.168.0.171”],
                  the ipWHiteList controls which external machines can access the mirror
                  127.0.0.1 is only the mirror machine
                  and then u have two mangled ipV6 addresses
                  I would just start with anyone can access
                  ipWhitelist: []
                  • C Offline
                    Chynovsky
                    I keep getting this error now: This device is not allowed to access your mirror.
                    Please check your config.js or config.js.sample to change this.
                    I do see “http://ip-of-your-mirror:8080/remote.html” though. so definitely progress.
                    • C Offline
                      Chynovsky
                      excuse the spam. FINALLY works!
                      • BKeyportB Offline
                        BKeyport Module Developer
                        FWIW, in the future,
                        Open a terminal
                        Type cd MagicMirror and press Enter
                        Now you’re in the MagicMirror directory
                        Type npm run config:check and press Enter
                        MagicMirror will now check your config
