    MMM-AssistantMk2 (v3)
    135 Posts 27 Posters 100.6k Views 25 Watching
    • P Offline
      pnobrega @Guest
      @Sean i’m gonna install now the module. After installed I’ll translate it.
      Wanna see context for better translate.
      I’ll send you the files after
      • P Offline
        pnobrega
        hi.
        What am i missing here?
        https://ibb.co/TcH3MHF
        current config never works. I’m shown 2 devices
        card 0: Generic [HD-Audio Generic], device 3: HDMI 0 [HDMI 0]
        card 1: SB [HDA ATI SB], device 0: ALC269VB Analog [ALC269VB Analog]
        i’ve choosen different settings but never works.
        Sound it working good cause i hear it from youtube. Speakers are from the monitor through hdmi
        • ? Offline
          [[global:former-user]]
          Hi, I wrote audio script with play plughw. If don’t work try manually to find your configuration
          • K Offline
            Kevinho195
            Hi @Sean
            I just updated from 3.0 to the latest version. I did git pull and npm install and did create the token.json again and store it as decribed in your manual. Version 3.0 did work great, but now I get this error: What am I doing wrong?
            0|MagicMirror  | [21:35:32.002] [LOG]
            0|MagicMirror  | Starting MagicMirror: v2.10.0
            0|MagicMirror  | [21:35:32.032] [LOG]
            0|MagicMirror  | Loading config ...
            0|MagicMirror  | [21:35:32.071] [LOG]
            0|MagicMirror  | Loading module helpers ...
            0|MagicMirror  | [21:35:32.078] [LOG]
            0|MagicMirror  | No helper found for module: MMM-pages.
            0|MagicMirror  | [21:35:36.901] [ERROR]
            0|MagicMirror  | WARNING! Could not load config file. Starting with default configuration. Error found: Error: Cannot find module 'play-sound'
            0|MagicMirror  | [21:35:36.903] [LOG]    Loading module helpers ...
            0|MagicMirror  | [21:35:36.906] [LOG]    No helper found for module: MMM-pages.
            0|MagicMirror  | [21:35:36.913] [ERROR]  App threw an error during load
            0|MagicMirror  | [21:35:36.919] [ERROR]  Error: Cannot find module 'play-sound'
            0|MagicMirror  |     at Module._resolveFilename (internal/modules/cjs/loader.js:602:15)
            0|MagicMirror  |     at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/common/reset-search-paths.js:35:12)
            0|MagicMirror  |     at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/module-alias/index.js:49:29)
            0|MagicMirror  |     at Function.Module._load (internal/modules/cjs/loader.js:528:25)
            0|MagicMirror  |     at Module.require (internal/modules/cjs/loader.js:658:17)
            0|MagicMirror  |     at require (internal/modules/cjs/helpers.js:20:18)
            0|MagicMirror  |     at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_helper.js:12:19)
            0|MagicMirror  |     at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_helper.js:201:3)
            0|MagicMirror  |     at Module._compile (internal/modules/cjs/loader.js:711:30)
            0|MagicMirror  |     at Object.Module._extensions..js (internal/modules/cjs/loader.js:722:10)
            0|MagicMirror  | [21:35:36.939] [LOG]
            0|MagicMirror  | Whoops! There was an uncaught exception...
            0|MagicMirror  | [21:35:36.941] [ERROR]
            0|MagicMirror  | { Error: Cannot find module 'play-sound'
            0|MagicMirror  |     at Object.Module._extensions..js (internal/modules/cjs/loader.js:722:10) code: 'MODULE_NOT_FOUND' }
            0|MagicMirror  | [21:35:36.975] [LOG]    MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
            0|MagicMirror  | [21:35:36.977] [LOG]    If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
            0|MagicMirror  | Fontconfig error: "/home/pi/.config/fontconfig/fonts.conf", line 10: junk after document element
            0|MagicMirror  | [21:35:37.852] [LOG]
            0|MagicMirror  | Launching application.
            • ? Offline
              Try this :
              cd ~/MagicMirror/modules/MMM-AssistantMk2
              ./update
              I think package. Json and package-lock. Json are outdated. I wrote a script for this ;)
              • K Offline
                Kevinho195 @Guest
                @Bugsounet thanks for your help :)
                • ? Offline
                  We have updated AMk2 to v3.1.0-2
                  Changes:
                  • Standby icon Touch to activate assistant
                  • AMk2 is now prepared to receive addons
                  Note: I prepare sample and template addons.
                  Coming soon ;)
                  Just a little patience and I will come back to you for the addons
                  EDIT
                  Addons repository is now online
                  • N Offline
                    nakedrabbit
                    New version installed fine for me, though I did not git pull, just wiped the old one off. Installer worked great, and I no longer have to rebuild electron afterwards, as I did previously. Everything worked great.
                    HOWEVER
                    I still can’t get much action out of the plugin. Here’s my latest error dump:
                    [AMK2] MMM-AssistantMk2 Version: 3.1.0-3
                    0|mm | [AMK2] AssistantMk2 is initialized.
                    0|mm | [HOTWORD] begins.
                    0|mm | [HOTWORD] Detector starts listening.
                    0|mm | [HOTWORD] Detected: SMARTMIRROR
                    0|mm | [HOTWORD] After Recording: 4000
                    0|mm | [HOTWORD] stops.
                    0|mm | [HOTWORD] After Recording finised. size: 16050
                    0|mm | [HOTWORD:B2W] WAV_FILE_CREATED: /home/pi/MagicMirror/modules/MMM-Hotword/temp/afterRecording.wav 16050
                    0|mm | [HOTWORD] Final Result: { detected: true,
                    0|mm | hotword: ‘SMARTMIRROR’,
                    0|mm | file: ‘temp/afterRecording.wav’ }
                    Seems to indicate Hotword is the problem…?
                    Here are the last 15 errors:
                    0|mm | at Object. (/home/pi/MagicMirror/modules/MMM-AssistantMk2/components/assistant.js:235:3)
                    0|mm | at Module._compile (internal/modules/cjs/loader.js:711:30)
                    0|mm | at Object.Module._extensions…js (internal/modules/cjs/loader.js:722:10)
                    0|mm | at Module.load (internal/modules/cjs/loader.js:620:32)
                    0|mm | { Error: Cannot find module ‘google-assistant’
                    0|mm | at Module._resolveFilename (internal/modules/cjs/loader.js:602:15)
                    0|mm | at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/common/reset-search-paths.js:35:12)
                    0|mm | at Function.Module._load (internal/modules/cjs/loader.js:528:25)
                    0|mm | at Module.require (internal/modules/cjs/loader.js:658:17)
                    0|mm | at require (internal/modules/cjs/helpers.js:20:18)
                    0|mm | at Object. (/home/pi/MagicMirror/modules/MMM-AssistantMk2/components/assistant.js:1:180)
                    0|mm | at Module.load (internal/modules/cjs/loader.js:620:32) code: ‘MODULE_NOT_FOUND’ }
                    Triggered the module with MMM-Buttons, but when I do that, AssistantMk2 just waits and doesn’t listen, finally timing out.
                    • ? Offline
                      hi, google-assistant module is not installed.
                      try this:
                      npm install
                      and execute electron rebuild :)
                      • N Offline
                        nakedrabbit
                        Yes, that seems obvious, but I did, in fact, follow the installation instructions, so I’m not sure why I have this error message either… left over from an aborted earlier attempt?
                        In addition I took out Hotword and used your fine snowboy addon. Exactly the same effect, so I must have something wrong with my general setup… still testing…
                        Thanks for your patience!
                        • ? Offline
                          @nakedrabbit : oupss, i have not seen your post :(
                          maybe your problem is now solved…
                          • ? Offline
                            MMM-AssisantMk2 v3.1.1-1
                            3.1.1-1 (05/03/2020)
                            • BUG: correct audio cutting response for mpg321 (test)
                            • ADD: add cvlc audio out support (vlc using)
                            3.1.1-0 (02/03/2020)
                            • ADD: add new function for addons-recipe (socketExec, onSocketExec)
                            • BUG: continous conversation bug - infinite loop on no user response
                            • BUG: double chimed on TRANSCRIPTION_FAILS retry
                            • ADD: ability to set no chime on activate assistant
                            • ADD: touching the keyword “try to say” activates the assistant for the suggested search (Fullscreen and Classic2 ui)
                            • ADD: ASSISTANT_WEB server for activate with keyword
                            • MOTIFY : search KEYWORD/ TRYTOSAY translation script to improve performance
                            • BUG: correct screen parser log
                            Assistant2Display v1.0.0
                            addons of AMk2 to display result links and photos of assistant search
                            credits:
                            • @Sean
                            • @bugsounet
                            Addons repository updated
                            see addon repository for more information ;)
                            Good assistant to you !
                            @bugsounet, @Sean
                            SergeS 1 Reply Last reply Reply Quote 0
                            • SergeS Offline
                              Serge @Guest
                              @Bugsounet said in MMM-AssistantMk2 (v3):
                              Excellent updates!
                              @Bugsounet could you please explain in a few words the functionality of these two features:
                              I have looked briefly on module’s wiki and did not found what do they mean.
                              • ? Offline
                                @Serge said in MMM-AssistantMk2 (v3):
                                internal server to activate assistant with http://127.0.0.1:8080/activatebytext/?query='your request'
                                it’s used in Fullscreen ui for touch help response screen word to active assistant with it
                                KEYWORD/ TRYTOSAY
                                script to search and store
                                try to say... translation
                                keyword is help word if found
                                it’s used in Classic 2 ui
                                • ? Offline
                                  MMM-AssisantMk2 v3.1.1-2
                                  3.1.1-2 (06/03/2020)
                                  • ADD/MODIFY: ui: "Fullscreen"
                                    • position: "fullscreen_above" is now ui like Google Home
                                  • MODIFY: user interface priority order Assistant2Display -> AMk2
                                  • ADD: move native sound to class
                                  SergeS A 2 Replies Last reply Reply Quote 0
                                  • SergeS Offline
                                    Serge @Guest
                                    @Bugsounet got it. thanx for quick reply. will test shortly
                                      athavanraja @Guest
                                      @Bugsounet Hi I am on version 3.0.2 and trying to update to latest version.
                                      Running npm run update at ~/MagicMirror/modules/MMM-AssistantMk2 gives the following error message
                                      pi@raspberrypi:~/MagicMirror/modules/MMM-AssistantMk2 $ npm run update
                                      npm ERR! missing script: update
                                      npm ERR! /home/pi/.npm/_logs/2020-03-15T18_41_39_806Z-debug.log
                                      Any help is highly appreciated.
                                      Thanks.
                                      • ? Offline
                                        hi, write update script since v3.1.X ;)
                                        so, retry with this:
                                        git pull
                                        npm run update
                                        it should work ;)
                                        notes :
                                        • install all new needed dependencies
                                        • skip GCC check
                                        • Electron rebuild step is not needed
                                        • Audio check is not needed too
                                        If you have some problems for updating, or if don’t work, i will help you ;)
                                          athavanraja @Guest
                                          @Bugsounet Thank you very much. Updated to 3.1.1-2 All working fine.
                                            amsuvarna27
                                            Can anyone share me image file of Magic mirror back up with Voice recognition and face recognition
                                            • 6
                                            • 7
                                            • 3 / 7
