    Fresh install but pm2 error
    37 Posts 2 Posters 14.7k Views 2 Watching
    • H
      Hubschra01
      I do a fresh install of the MagicMirror 2. The Mirror seem to work if i look in the logs of pm2 there is show an error.
      I searched the forum but found nothing suitableI.
      What kind of error is this?
      The Hardware is a Pi 3B+ with SD card.
      1 verbose cli [ '/usr/bin/node', '/usr/bin/npm', 'start' ]
      2 info using npm@6.13.4
      3 info using node@v10.18.1
      5 info lifecycle magicmirror@2.10.1~prestart: magicmirror@2.10.1
      6 info lifecycle magicmirror@2.10.1~start: magicmirror@2.10.1
      7 verbose lifecycle magicmirror@2.10.1~start: unsafe-perm in lifecycle true
      8 verbose lifecycle magicmirror@2.10.1~start: PATH: /usr/lib/node_modules/npm/node_modules/npm-lifecycle/node-gyp-bin:/home/pi/MagicMirror/node_modules/.bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/local/games:/usr/games
      9 verbose lifecycle magicmirror@2.10.1~start: CWD: /home/pi/MagicMirror
      10 silly lifecycle magicmirror@2.10.1~start: Args: [ '-c', './run-start.sh' ]
      11 silly lifecycle magicmirror@2.10.1~start: Returned: code: 1  signal: null
      12 info lifecycle magicmirror@2.10.1~start: Failed to exec start script
      13 verbose stack Error: magicmirror@2.10.1 start: `./run-start.sh`
      13 verbose stack Exit status 1
      13 verbose stack     at EventEmitter.<anonymous> (/usr/lib/node_modules/npm/node_modules/npm-lifecycle/index.js:332:16)
      13 verbose stack     at EventEmitter.emit (events.js:198:13)
      13 verbose stack     at ChildProcess.<anonymous> (/usr/lib/node_modules/npm/node_modules/npm-lifecycle/lib/spawn.js:55:14)
      13 verbose stack     at ChildProcess.emit (events.js:198:13)
      13 verbose stack     at maybeClose (internal/child_process.js:982:16)
      13 verbose stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:259:5)
      14 verbose pkgid magicmirror@2.10.1
      15 verbose cwd /home/pi/MagicMirror
      16 verbose Linux 4.19.75-v7+
      17 verbose argv "/usr/bin/node" "/usr/bin/npm" "start"
      18 verbose node v10.18.1
      19 verbose npm  v6.13.4
      20 error code ELIFECYCLE
      21 error errno 1
      22 error magicmirror@2.10.1 start: `./run-start.sh`
      22 error Exit status 1
      23 error Failed at the magicmirror@2.10.1 start script.
      23 error This is probably not a problem with npm. There is likely additional logging output above.
      24 verbose exit [ 1, true ]
      Thanks André
        sdetweil @Hubschra01
        @Hubschra01 if you do the start manually what happens
        pm2 stop 0
        cd ~/MagicMirror
        npm start
        • H
          Hubschra01
          I think there are no Errors…
          > magicmirror@2.10.1 start /home/pi/MagicMirror
          > ./run-start.sh
          [07:31:12.357] [LOG]    Starting MagicMirror: v2.10.1
          [07:31:12.375] [LOG]    Loading config ...
          [07:31:12.387] [LOG]    Loading module helpers ...
          [07:31:12.389] [LOG]    No helper found for module: alert.
          [07:31:12.465] [LOG]    Initializing new module helper ...
          [07:31:12.466] [LOG]    Module helper loaded: updatenotification
          [07:31:12.468] [LOG]    No helper found for module: clock.
          [07:31:13.307] [LOG]    Initializing new module helper ...
          [07:31:13.308] [LOG]    Module helper loaded: calendar
          [07:31:13.309] [LOG]    No helper found for module: currentweather.
          [07:31:13.310] [LOG]    No helper found for module: weatherforecast.
          [07:31:13.367] [LOG]    Initializing new module helper ...
          [07:31:13.368] [LOG]    Module helper loaded: newsfeed
          [07:31:13.369] [LOG]    All module helpers loaded.
          [07:31:13.371] [LOG]    Starting server on port 8080 ...
          [07:31:13.393] [LOG]    Server started ...
          [07:31:13.395] [LOG]    Connecting socket for: updatenotification
          [07:31:13.397] [LOG]    Connecting socket for: calendar
          [07:31:13.398] [LOG]    Starting node helper for: calendar
          [07:31:13.399] [LOG]    Connecting socket for: newsfeed
          [07:31:13.401] [LOG]    Starting module: newsfeed
          [07:31:13.401] [LOG]    Sockets connected & modules started ...
          [07:31:13.625] [LOG]    Launching application.
          [07:31:16.629] [LOG]    Create new calendar fetcher for url: https://calendar.google.com/calendarX - Interval: 30000
          [07:31:16.654] [LOG]    Create new calendar fetcher for url: https://calendar.google.com/XX - Interval: 30000
          [07:31:16.762] [LOG]    Create new news fetcher for url: http://www.tagesschau.de/xml/rss2 - Interval: 300000
          ^C
          But on the Mirror there is only the Desktop from Buster shown, not the Mirror Screen
            @Hubschra01 how are you connecting to the pi? over ssh?
            did u set DISPLAY=:0
            • H
              Hubschra01
              sorry i forget this.
              This is the CLI output i tried now.
              pi@raspberrypi:~/MagicMirror $ DISPLAY=:0 npm start
              > ./run-start.sh
              [23:11:47.885] [LOG]    Starting MagicMirror: v2.10.1
              [23:11:47.902] [LOG]    Loading config ...
              [23:11:47.911] [LOG]    Loading module helpers ...
              [23:11:47.914] [LOG]    No helper found for module: alert.
              [23:11:48.008] [LOG]    Initializing new module helper ...
              [23:11:48.010] [LOG]    Module helper loaded: updatenotification
              [23:11:48.012] [LOG]    No helper found for module: clock.
              [23:11:48.875] [LOG]    Initializing new module helper ...
              [23:11:48.876] [LOG]    Module helper loaded: calendar
              [23:11:48.877] [LOG]    No helper found for module: currentweather.
              [23:11:48.878] [LOG]    No helper found for module: weatherforecast.
              [23:11:48.935] [LOG]    Initializing new module helper ...
              [23:11:48.936] [LOG]    Module helper loaded: newsfeed
              [23:11:48.937] [LOG]    All module helpers loaded.
              [23:11:48.939] [LOG]    Starting server on port 8080 ...
              [23:11:48.962] [LOG]    Server started ...
              [23:11:48.964] [LOG]    Connecting socket for: updatenotification
              [23:11:48.966] [LOG]    Connecting socket for: calendar
              [23:11:48.967] [LOG]    Starting node helper for: calendar
              [23:11:48.969] [LOG]    Connecting socket for: newsfeed
              [23:11:48.970] [LOG]    Starting module: newsfeed
              [23:11:48.971] [LOG]    Sockets connected & modules started ...
              [23:11:49.186] [LOG]    Launching application.
              [23:11:52.113] [LOG]    Create new calendar fetcher for url: https://calendar.google.com/calendar/ical/XXX/basic.ics - Interval: 30000
              [23:11:52.265] [LOG]    Create new calendar fetcher for url: https://calendar.google.com/calendar/XXXX - Interval: 30000
              [23:11:52.331] [LOG]    Create new news fetcher for url: http://www.tagesschau.de/xml/rss2 - Interval: 300000
                @Hubschra01 good, thank you
                did the mirror app display correctly on the display this time? looks like it should have
                • H
                  Hubschra01
                  Yes it did.
                  I Start the Mirror again with
                  pm2 restart MagicMirror
                  and it works.
                  Next step i flush the pm2 log and restart pm2 again.
                  All works fine no errors.
                  But if i reboot the pi the error appear again in the pm2 log…
                    @Hubschra01
                    ok do
                    pm2 start  MagicMirror
                    pm2 save
                    • H
                      Hubschra01 @sdetweil
                      OK i did it. what else?
                      if i reboot pm2 log show this.
                      pi@raspberrypi:~ $ pm2 log
                      [TAILING] Tailing last 15 lines for [all] processes (change the value with --lines option)
                      /home/pi/.pm2/pm2.log last 15 lines:
                      PM2        | 2020-01-20T15:12:28: PM2 log: PM2 version          : 4.2.1
                      PM2        | 2020-01-20T15:12:28: PM2 log: Node.js version      : 10.18.1
                      PM2        | 2020-01-20T15:12:28: PM2 log: Current arch         : arm
                      PM2        | 2020-01-20T15:12:28: PM2 log: PM2 home             : /home/pi/.pm2
                      PM2        | 2020-01-20T15:12:28: PM2 log: PM2 PID file         : /home/pi/.pm2/pm2.pid
                      PM2        | 2020-01-20T15:12:28: PM2 log: RPC socket file      : /home/pi/.pm2/rpc.sock
                      PM2        | 2020-01-20T15:12:28: PM2 log: BUS socket file      : /home/pi/.pm2/pub.sock
                      PM2        | 2020-01-20T15:12:28: PM2 log: Application log path : /home/pi/.pm2/logs
                      PM2        | 2020-01-20T15:12:28: PM2 log: Worker Interval      : 30000
                      PM2        | 2020-01-20T15:12:28: PM2 log: Process dump file    : /home/pi/.pm2/dump.pm2
                      PM2        | 2020-01-20T15:12:28: PM2 log: Concurrent actions   : 2
                      PM2        | 2020-01-20T15:12:28: PM2 log: SIGTERM timeout      : 1600
                      PM2        | 2020-01-20T15:12:28: PM2 log: ===============================================================================
                      PM2        | 2020-01-20T15:12:28: PM2 log: App [MagicMirror:0] starting in -fork mode-
                      PM2        | 2020-01-20T15:12:28: PM2 log: App [MagicMirror:0] online
                      /home/pi/.pm2/logs/MagicMirror-error.log last 15 lines:
                      0|MagicMir | npm ERR! code ELIFECYCLE
                      0|MagicMir | npm ERR! errno 1
                      0|MagicMir | npm ERR! magicmirror@2.10.1 start: `./run-start.sh`
                      0|MagicMir | npm ERR! Exit status 1
                      0|MagicMir | npm ERR! Failed at the magicmirror@2.10.1 start script.
                      0|MagicMir | npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
                      0|MagicMir |
                      0|MagicMir | npm ERR! A complete log of this run can be found in:
                      0|MagicMir | npm ERR!     /home/pi/.npm/_logs/2020-01-20T14_12_10_107Z-debug.log
                      /home/pi/.pm2/logs/MagicMirror-out.log last 15 lines:
                      0|MagicMir | [15:12:38.792] [LOG]    Initializing new module helper ...
                      0|MagicMir | [15:12:38.793] [LOG]    Module helper loaded: newsfeed
                      0|MagicMir | [15:12:38.794] [LOG]    All module helpers loaded.
                      0|MagicMir | [15:12:38.795] [LOG]    Starting server on port 8080 ...
                      0|MagicMir | [15:12:38.819] [LOG]    Server started ...
                      0|MagicMir | [15:12:38.820] [LOG]    Connecting socket for: updatenotification
                      0|MagicMir | [15:12:38.822] [LOG]    Connecting socket for: calendar
                      0|MagicMir | [15:12:38.823] [LOG]    Starting node helper for: calendar
                      0|MagicMir | [15:12:38.825] [LOG]    Connecting socket for: newsfeed
                      0|MagicMir | [15:12:38.826] [LOG]    Starting module: newsfeed
                      0|MagicMir | [15:12:38.827] [LOG]    Sockets connected & modules started ...
                      0|MagicMir | [15:12:39.460] [LOG]    Launching application.
                      0|MagicMir | [15:12:43.347] [LOG]    Create new calendar fetcher for url: https:
                        @Hubschra01 said in Fresh install but pm2 error:
                        weird…
                        can u show that log
                        • H
                          sure here it is:
                          8 verbose lifecycle magicmirror@2.10.1~start: PATH: /usr/lib/node_modules/npm/n$
                          13 verbose stack     at EventEmitter.<anonymous> (/usr/lib/node_modules/npm/nod$
                          13 verbose stack     at ChildProcess.<anonymous> (/usr/lib/node_modules/npm/nod$
                          13 verbose stack     at Process.ChildProcess._handle.onexit (internal/child_pro$
                          21 error errno 1
                          23 error This is probably not a problem with npm. There is likely additional lo$
                            @Hubschra01 can u show output of
                            ls ~/MagicMirror/run-start.sh -laF
                            mine looks like
                            -rwxrwxr-x 1 sam sam 2399 Jan 16 09:55 /home/sam/MagicMirror/run-start.sh*
                            • H
                              -rwxr-xr-x 1 pi pi 1989 Jan 16 20:05 /home/pi/MagicMirror/run-start.sh*
                                @Hubschra01 weird…
                                can u change line 1 of run-start.sh to
                                #!/bin/bash -x
                                do pm2 flush
                                and then reboot
                                then show the pm2 logs --lines=100
                                this has got to be a permissions error
                                • H
                                  here it is…
                                  PM2        | 2020-01-20T16:05:29: PM2 log: App [MagicMirror:0] exited with code                      [2] via signal [SIGINT]
                                  PM2        | 2020-01-20T16:05:29: PM2 log: App [MagicMirror:0] starting in -fork                      mode-
                                  PM2        | 2020-01-20T16:05:29: PM2 log: App [MagicMirror:0] online
                                  PM2        | 2020-01-20T16:05:31: PM2 log: Stopping app:MagicMirror id:0
                                  PM2        | 2020-01-20T16:05:31: PM2 log: pid=1305 msg=failed to kill - retryin                     g in 100ms
                                  PM2        | 2020-01-20T16:05:32: PM2 log: pid=1305 msg=failed to kill - retryin                     g in 100ms
                                  PM2        | 2020-01-20T16:05:33: PM2 log: pid=1305 msg=failed to kill - retryin                     g in 100ms
                                  PM2        | 2020-01-20T16:05:33: PM2 log: Process with pid 1305 still alive aft                     er 1600ms, sending it SIGKILL now...
                                  PM2        | 2020-01-20T16:05:33: PM2 log: App [MagicMirror:0] exited with code                      [0] via signal [SIGKILL]
                                  PM2        | 2020-01-20T16:05:33: PM2 log: pid=1305 msg=process killed
                                  PM2        | 2020-01-20T16:05:33: PM2 log: PM2 successfully stopped
                                  PM2        | 2020-01-20T16:05:48: PM2 log: =====================================                     ==========================================
                                  PM2        | 2020-01-20T16:05:48: PM2 log: --- New PM2 Daemon started ----------                     ------------------------------------------
                                  PM2        | 2020-01-20T16:05:48: PM2 log: Time                 : Mon Jan 20 202                     0 16:05:48 GMT+0100 (GMT+01:00)
                                  PM2        | 2020-01-20T16:05:48: PM2 log: PM2 version          : 4.2.1
                                  PM2        | 2020-01-20T16:05:48: PM2 log: Node.js version      : 10.18.1
                                  PM2        | 2020-01-20T16:05:48: PM2 log: Current arch         : arm
                                  PM2        | 2020-01-20T16:05:48: PM2 log: PM2 home             : /home/pi/.pm2
                                  PM2        | 2020-01-20T16:05:48: PM2 log: PM2 PID file         : /home/pi/.pm2/                     pm2.pid
                                  PM2        | 2020-01-20T16:05:48: PM2 log: RPC socket file      : /home/pi/.pm2/                     rpc.sock
                                  PM2        | 2020-01-20T16:05:48: PM2 log: BUS socket file      : /home/pi/.pm2/                     pub.sock
                                  PM2        | 2020-01-20T16:05:48: PM2 log: Application log path : /home/pi/.pm2/                     logs
                                  PM2        | 2020-01-20T16:05:48: PM2 log: Worker Interval      : 30000
                                  PM2        | 2020-01-20T16:05:48: PM2 log: Process dump file    : /home/pi/.pm2/                     dump.pm2
                                  PM2        | 2020-01-20T16:05:48: PM2 log: Concurrent actions   : 2
                                  PM2        | 2020-01-20T16:05:48: PM2 log: SIGTERM timeout      : 1600
                                  PM2        | 2020-01-20T16:05:48: PM2 log: App [MagicMirror:0] starting in -fork                      mode-
                                  PM2        | 2020-01-20T16:05:49: PM2 log: App [MagicMirror:0] online
                                  /home/pi/.pm2/logs/MagicMirror-error.log last 100 lines:
                                  0|MagicMir | ./run-start.sh: Zeile 68: Syntaxfehler beim unerwarteten Wort `fi'
                                  0|MagicMir | ./run-start.sh: Zeile 68: `fi'
                                  0|MagicMir | npm ERR! errno 2
                                  0|MagicMir | npm ERR! Exit status 2
                                  0|MagicMir | npm ERR! This is probably not a problem with npm. There is likely a                     dditional logging output above.
                                  0|MagicMir |
                                  0|MagicMir | npm ERR!     /home/pi/.npm/_logs/2020-01-20T15_05_29_835Z-debug.log
                                  0|MagicMir | + ./untrack-css.sh
                                  0|MagicMir | + '[' -z :0 ']'
                                  0|MagicMir | ++ uname -m
                                  0|MagicMir | + arch=armv7l
                                  0|MagicMir | + false=false
                                  0|MagicMir | ++ grep -v '^\s//' config/config.js
                                  0|MagicMir | ++ grep -i serveronly:
                                  0|MagicMir | ++ tr -d ',"'\'''
                                  0|MagicMir | ++ awk '{print tolower($2)}'
                                  0|MagicMir | + serveronly=
                                  0|MagicMir | + serveronly=false
                                  0|MagicMir | ++ pgrep Xorg
                                  0|MagicMir | + xorg=
                                  0|MagicMir | + mac=Linux
                                  0|MagicMir | + '[' false. '!=' false. -o armv7l == armv6l ']'
                                  0|MagicMir | + '[' . == . -a Linux '!=' Darwin ']'
                                  0|MagicMir | + '[' false. == true. -o . == . ']'
                                  0|MagicMir | + node serveronly
                                  0|MagicMir | + xorg=437
                                  0|MagicMir | + '[' 437. == . -a Linux '!=' Darwin ']'
                                  0|MagicMir | + electron js/electron.js
                                  /home/pi/.pm2/logs/MagicMirror-out.log last 100 lines:
                                  0|MagicMir |
                                  0|MagicMir | > magicmirror@2.10.1 start /home/pi/MagicMirror
                                  0|MagicMir | > ./run-start.sh
                                  0|MagicMir |
                                  0|MagicMir | [16:05:33.029] [LOG]    Starting MagicMirror: v2.10.1
                                  0|MagicMir | [16:05:33.045] [LOG]    Loading config ...
                                  0|MagicMir | [16:05:33.054] [LOG]    Loading module helpers ...
                                  0|MagicMir | [16:05:33.057] [LOG]    No helper found for module: alert.
                                  0|MagicMir | [16:05:33.129] [LOG]    Initializing new module helper ...
                                  0|MagicMir | [16:05:33.131] [LOG]    Module helper loaded: updatenotification
                                  0|MagicMir | [16:05:33.132] [LOG]    No helper found for module: clock.
                                  0|MagicMir |
                                  0|MagicMir |
                                  0|MagicMir | [16:05:56.837] [LOG]    Starting MagicMirror: v2.10.1
                                  0|MagicMir | [16:05:56.853] [LOG]    Loading config ...
                                  0|MagicMir | [16:05:56.872] [LOG]    Loading module helpers ...
                                  0|MagicMir | [16:05:56.875] [LOG]    No helper found for module: alert.
                                  0|MagicMir | [16:05:57.006] [LOG]    Initializing new module helper ...
                                  0|MagicMir | [16:05:57.012] [LOG]    Module helper loaded: updatenotification
                                  0|MagicMir | [16:05:57.014] [LOG]    No helper found for module: clock.
                                  0|MagicMir | [16:05:58.224] [LOG]    Initializing new module helper ...
                                  0|MagicMir | [16:05:58.225] [LOG]    Module helper loaded: calendar
                                  0|MagicMir | [16:05:58.226] [LOG]    No helper found for module: currentweather.
                                  0|MagicMir | [16:05:58.227] [LOG]    No helper found for module: weatherforecast                     .
                                  0|MagicMir | [16:05:58.315] [LOG]    Initializing new module helper ...
                                  0|MagicMir | [16:05:58.316] [LOG]    Module helper loaded: newsfeed
                                  0|MagicMir | [16:05:58.316] [LOG]    All module helpers loaded.
                                  0|MagicMir | [16:05:58.318] [LOG]    Starting server on port 8080 ...
                                  0|MagicMir | [16:05:58.341] [LOG]    Server started ...
                                  0|MagicMir | [16:05:58.343] [LOG]    Connecting socket for: updatenotification
                                  0|MagicMir | [16:05:58.345] [LOG]    Connecting socket for: calendar
                                  0|MagicMir | [16:05:58.346] [LOG]    Starting node helper for: calendar
                                  0|MagicMir | [16:05:58.347] [LOG]    Connecting socket for: newsfeed
                                  0|MagicMir | [16:05:58.349] [LOG]    Starting module: newsfeed
                                  0|MagicMir | [16:05:58.349] [LOG]    Sockets connected & modules started ...
                                  0|MagicMir | [16:05:59.000] [LOG]    Launching application.
                                  0|MagicMir | [16:06:02.809] [LOG]    Create new calendar fetcher for url: https:
                                    0|MagicMir | ./run-start.sh: Zeile 68: Syntaxfehler beim unerwarteten Wort `fi’
                                    there is the problem, syntax error…
                                    can show the run-start.sh
                                    I have to leave in about 15 minutes for the rest of the day
                                    • H
                                      here is the run-start.sh
                                      #!/bin/bash -x
                                        # use bash instead of sh
                                      ./untrack-css.sh
                                      if [ -z "$DISPLAY" ]; then #If not set DISPLAY is SSH remote or tty
                                      	export DISPLAY=:0 # Set by default display
                                      fi
                                      # get the processor architecture
                                      arch=$(uname -m)
                                      false='false'
                                      # get the config option, if any
                                      # only check non comment lines
                                      serveronly=$(grep -v '^\s//'  config/config.js | grep -i serveronly: | awk '{print tolower($2)}' | tr -d ,\"\')
                                      # set default if not defined in config
                                      serveronly=${serveronly:-false}
                                      # check for xwindows running
                                      xorg=$(pgrep Xorg)
                                      #check for macOS
                                      mac=$(uname)
                                      # if the user requested serveronly OR
                                      #    electron support for armv6l has been dropped OR
                                      #    system is in text mode
                                      if [ "$serveronly." != "false." -o  "$arch" == "armv6l" ] ||  [ "$xorg." == "." -a $mac != 'Darwin' ]; then
                                      	# if user explicitly configured to run server only (no ui local)
                                      	# OR there is no xwindows running, so no support for browser graphics
                                      	if [ "$serveronly." == "true." -o "$xorg." == "." ]; then
                                      	  # start server mode,
                                      	  node serveronly
                                      	else
                                      		# start the server in the background
                                      		# wait for server to be ready
                                      		# need bash for this
                                      		exec 3< <(node serveronly)
                                      		# Read the output of server line by line until one line 'point your browser'
                                      		while read line; do
                                      			 case "$line" in
                                      			 *point\ your\ browser*)
                                      					echo $line
                                      					break
                                      					echo $line
                                      					#sleep .25
                                      			 esac
                                      		done <&3
                                      		# Close the file descriptor
                                      		exec 3<&-
                                      		# lets use chrome to display here now
                                      		# get the server port address from the ready message
                                      		port=$(echo $line | awk -F\: '{print $4}')
                                      		# start chromium
                                      		echo "Starting chromium browser now, have patience, it takes a minute"
                                      		chromium-browser -noerrdialogs -kiosk -start_maximized  --disable-infobars --app=http://localhost:$port  --ignore-certificate-errors-spki-list --ignore-ssl-errors --ignore-certificate-errors 2>/dev/null
                                      		exit
                                      	fi
                                      else
                                      	# we can use electron directly
                                      	electron js/electron.js $1;
                                      fi
                                        @Hubschra01 i don’t know… weird… don’t have more time today
                                          Are u running two copies?
                                          pm2 status
                                          • H
                                            Hubschra01
                                            No it is only one to see…
                                            pi@raspberrypi:~/MagicMirror $ pm2 status
                                            │ id │ name               │ mode     │ ↺    │ status    │ cpu      │ memory   │
                                            │ 0  │ MagicMirror        │ fork     │ 0    │ online    │ 0%       │ 2.4mb    │
