    Text Align Vertical
    4 Posts 3 Posters 1.6k Views 4 Watching
    • P
      Plainbroke 0
      How to I go about aligning up and down, the text in the center of the modules area instead of at the top of the modules area?
      https://drive.google.com/open?id=1ttBZLkjFizAlJvrADEfT2XJqGqU3g1RX
      See photo for better explanation.
        sdetweil @Plainbroke 0
        @Plainbroke-0 we are having troubles with photo uploads…
        may have to use pastebin, or some other site and link to the images
        Reply Quote 1
        • P
          Plainbroke 0
          ok now you should be able to see the picture showing what I want to do.
          I tried padding but that only works if the displayed information stays the same.
          I also tried vertical-align: center also tried middle but no luck
          hopefully one of you guru’s can help me …
          • D
            doubleT Module Developer
            Vertical-align only works in inline elements and table cells.
            Two common css hacks are these: https://jsfiddle.net/02vxofa6/1/
            The parent (or a wrapper div container filling the parent) is set to display: table-cell; and vertical-align: middle;
            If there’s a reason this cannot be done, there’s also another hack:
            Set the parent to position: relative; and the text to position: absolute: top: 50%;
            But then it’s not exactly in the middle, as the distance to the top is 50%. Give the text a fixed height (maybe even considering a line break there) and set margin-top to - half the text height. height: 20px; margin-top: -10pxfor example.
            Reply Quote 2
