    Mmm-My Weather question
    6 Posts 3 Posters 2.0k Views 4 Watching
      rdwilbrink
      Hello
      I have a question I was making a magic mirror. For the weather I found the module Mmm-My Weather it’s looks really nice. Than now my question
      how can I get this lay out what you see on the screenshot.
      On the screenshot you see the date time and the weather how can I create that layout it’s looks amazing
      alt text
      Can I do that with css?
      I hope that anyone can help me
        sdetweil @rdwilbrink
        @rdwilbrink well, thats a number of modules working together…
        left column is two calandars
        weather top middle
        some waste collection schedule app
        then a sports scoreboard
        then some local public service location and status…
          rdwilbrink @sdetweil
          @sdetweil only wat I want is the time and the weather layout. The other modules I found the layout
            @rdwilbrink i don’t think the clock is that default version as it doesn’t display the weather at all
            I looked thru the 3rd party modules list and don’t see one that does this
            https://github.com/MichMich/MagicMirror/wiki/3rd-party-modules
              rdwilbrink
              no, I thought so too The default clock does not show the weather all.
              thanks for your help
              I will continue to search if I can find something
                j.e.f.f Project Sponsor Module Developer
                This is a layout I made for a native 1366x768 TV that I use in my kitchen as an information centre. I’ve used a LOT of custom CSS to make this work. It does indeed use the standard clock module. The weather has been repositioned with CSS to make it look like it’s part of the top-left module, but they are in fact two separate modules.
                I no longer use this layout as it didn’t really work for my needs and there were several modules that I didn’t actually use at all. So I use something now that is simpler.
                I could share the custom.css and config for my current layout but it would be useless to anyone else unless the TV uses a native 1366x768 display.
                You can read about it here in case it inspires you to do something similar:
                http://jeffsnerdyprojects.blogspot.com/2018/04/information-center-v2.html?m=1
