    MMM-Fitbit2
    Scheduled Pinned Locked Moved Health
    fitbithealthfitnesshealthywaterfoodtrackingactivity tracker
    98 Posts 21 Posters 169.4k Views 19 Watching
    • jonspragginsJ Offline
      jonspraggins @bhepler
      This post is deleted!
      jonspragginsJ 1 Reply Last reply Reply Quote 0
        jonspraggins @jonspraggins
        • Arno-StrasbourgA Offline
          Arno-Strasbourg
          Do you think it would be possible to add the watch battery level ?
          • V Offline
            Vizulize Module Developer
            Hi all (notably, @chsp) - turns out that there was a bug if you had selected the “weight” resource and did not have any weight data for the last 30 days. I have pushed a fix for this, so hopefully you don’t end up with “Loading…” any more!
            • V Offline
              Vizulize Module Developer @mattx38
              @mattx38 As the client secret a password, it is blocked from printing. Just paste the secret into your terminal and press enter - it will work.
              This is separate to what @bhepler raised re: SSH. Actually, you can run all of the commands over SSH, but you will need to log in to your Fitbit account in a browser on the Pi in order to generate your access tokens. Alternatively, you can run the script on another machine, generate the tokens and then transfer them onto the Pi (if you have no way to do things on your Pi’s display).
              • V Offline
                Vizulize Module Developer @Arno-Strasbourg
                @Arno-Strasbourg
                Seems like it’s possible to get a low-resolution status of device battery levels from the Fitbit API.
                It also seems as though the Python library supports this endpoint.
                However, because it returns a list of devices, targeting the right one may prove to be a little more complicated.
                Not much good if the battery level relates to a second tracker that you aren’t actually wearing!
                I could possibly do it based on the device with "type": "TRACKER" that has the most recent "lastSyncTime", but I will need to think about it.
                Arno-StrasbourgA 1 Reply Last reply Reply Quote 0
                  Arno-Strasbourg @Vizulize
                  @Vizulize said in MMM-Fitbit2:
                  @Arno-Strasbourg
                  I could possibly do it based on the device with “type”: “TRACKER” that has the most recent “lastSyncTime”, but I will need to think about it.
                  It would be very nice. Thank you
                    aunrea
                    I think this module is great! It works well and looks great.
                    Is there a way to set it to imperial instead of metric measurements?
                    A V 2 Replies Last reply Reply Quote 0
                      aunrea @aunrea
                      I have also noticed that the sleep time is inaccurate. It currently says 08:04, but the Fitbit website says 07:10. I am not sure why it is adding 56mins to my sleep time.
                      • StoffbeuteluweS Offline
                        Stoffbeuteluwe Project Sponsor
                        My question is…after updating MM
                        the module is not working.
                        I must do the (auth.sh) again after every MM upgrade.
                        Is that the same on your Mirrors??
                          aunrea
                          Is there a way to use more than 1 Fitbit account? I tried but the second one would not authorize.
                          V goldyfruitG 2 Replies Last reply Reply Quote 0
                          • V Offline
                            Vizulize Module Developer @aunrea
                            @aunrea For now, to get Imperial measurements, remove this line:
                            https://github.com/m-roberts/MMM-Fitbit2/blob/master/python/get_data.py#L96
                            • V Offline
                              @aunrea The module is returning the sleep data from the web API directly, which can be found here: https://dev.fitbit.com/build/reference/web-api/sleep/
                              You can see in the code here that the result that is returned is “totalMinutesAsleep”:
                              https://github.com/m-roberts/MMM-Fitbit2/blob/master/python/get_data.py#L194
                              Beyond that, I am not sure why it is adding time to your records. Apologies!
                              • V Offline
                                Vizulize Module Developer @Stoffbeuteluwe
                                @Stoffbeuteluwe This should not be the case. What are the logs saying?
                                • V Offline
                                  @aunrea This should work - I have 2 accounts on my MagicMirror and they have worked together for some time. What are you seeing?
                                    mkufner24
                                    Hi, this module is great! It works almost perfectly, the only exception being inaccurate sleep time. Mine is underreporting my sleep time. Any ideas?
                                    • V Offline
                                      Vizulize Module Developer @mkufner24
                                      @mkufner24 I have explained what I am doing to retrieve sleep data in an earlier post. Beyond that, I’m not sure!
                                      I’m glad to hear you’re enjoying the module though 😄
                                        jonspraggins
                                        I have dockerized my MM (https://github.com/bastilimbach/docker-MagicMirror) and having trouble getting MMM-Fitbit2 to work properly.
                                        Some things I’ve attempted:
                                        • I cannot launch a web browser from my container; it doesn’t have one.
                                        • SSHing into the container to launch auth.sh will not launch a web browser to finish the setup
                                        • Copying the token from my old MM doesn’t seem to work.
                                        Suggestions?
                                        • goldyfruitG Offline
                                          goldyfruit Project Sponsor
                                          @Vizulize It would be great it you could allow the issue creation on GitHub, this will be easier to contribute and raise issue. :)
                                          Build smart things with magic and love! | https://smartgic.io
                                            goldyfruit Project Sponsor @aunrea
                                            @aunrea I have the same behavior with a second account, like if some cache was used.
                                            My workaround was to clone the repository on my laptop (not on my RPi) and run the Python script from there and then copy/paste the tokens-XXXXX.json file to my RPi.
                                            • 2 / 5
