    MMM-NetworkScanner-loading...indefinitely
    54 Posts 6 Posters 15.0k Views 7 Watching
      jthirasilpa
      Hmm
      So with the password entered only in the config file, the error output still references line 42
       var arpHosts = this.config.network || '-l';
      Error output:
      0|mm       | [19:37:36.956] [ERROR]  TypeError: Cannot read property 'network' of undefined
      0|mm       |     at Class.scanNetworkMAC (/home/jojo/MagicMirror/modules/MMM-NetworkScanner/node_helper.js:42:36)
      0|mm       |     at Class.socketNotificationReceived (/home/jojo/MagicMirror/modules/MMM-NetworkScanner/node_helper.js:30:18)
      0|mm       |     at Socket.<anonymous> (/home/jojo/MagicMirror/js/node_helper.js:113:11)
      0|mm       |     at Socket.emit (events.js:198:13)
      0|mm       |     at /home/jojo/MagicMirror/node_modules/socket.io/lib/socket.js:528:12
      0|mm       |     at process._tickCallback (internal/process/next_tick.js:61:11)
      0|mm  | [19:37:50.982] [LOG]    MMM-NetworkScanner received SCAN_NETWORK
      0|mm  | [19:37:50.983] [LOG]    MMM-NetworkScanner is performing arp-scan
      0|mm  | [19:37:50.984] [LOG]    Whoops! There was an uncaught exception...
      0|mm  | [19:37:50.984] [ERROR]
      0|mm  | TypeError: Cannot read property 'network' of undefined
      0|mm  | [19:37:50.985] [LOG]
      0|mm  | MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
      0|mm  | [19:37:50.986] [LOG]    If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
      0|mm  | [19:38:21.046] [LOG]
      0|mm  | MMM-NetworkScanner received SCAN_NETWORK
      0|mm  | [19:38:21.047] [LOG]
      0|mm  | MMM-NetworkScanner is performing arp-scan
      0|mm  | [19:38:21.048] [LOG]    Whoops! There was an uncaught exception...
      0|mm  | [19:38:21.048] [ERROR]
        sdetweil @jthirasilpa
        @jthirasilpa said in MMM-NetworkScanner-loading...indefinitely:
        0|mm | [19:37:36.956] [ERROR] TypeError: Cannot read property ‘network’ of undefined
        Ok, but not ‘options’…
        now, to check, this system is case sensitive… so in config.js it MUST look like this, right?
                    keepAlive: 300,
                    updateInterval: 5,
        	    Password: 'pi'                        // added password (note capital P)
        using your password of course
          jthirasilpa
          That is how the config looks.
          Still getting the node_helper line 42 error. Will park this for now. Thank you for spending so much time on this Sam - much appreciated. Will come back to this later in the week.
            @jthirasilpa update the current code
            cd ~MagicMirror/modules/MMM-NetworkScanner
            git pull
            then you can shutdown and restart the MM app
            there was a tiny timing gap where the config info is not yet set, when the helper is asked to scan the network…
            let me know
            • O Offline
              OldSunGuy
              Is it bad to have this?
              pi@raspberrypi ~ % sudo -l|grep NOPASS
                  (ALL) NOPASSWD: ALL
              pi@raspberrypi ~ %
              Edit: To expand further, I have MMM-NetworkScanner running. I do not need to supply a password when I run sudo and I don’t have a password stored in a config file.
                jthirasilpa @sdetweil
                Hi Sam - thanks I tried the update. Still getting the same error - from the log:
                [19:00:49.868] [ERROR]  TypeError: Cannot read property 'network' of undefined
                  @jthirasilpa do another git pull from my repo… and try again
                    Thanks Sam
                    Tried update. Error log below:
                    [11:45:29.130] [ERROR]  TypeError: Cannot read property 'network' of undefined
                        at Class.scanNetworkMAC (/home/jojo/MagicMirror/modules/MMM-NetworkScanner/node_helper.js:46:36)
                        at Class.socketNotificationReceived (/home/jojo/MagicMirror/modules/MMM-NetworkScanner/node_helper.js:33:18)
                    Node_helper code:
                            // Target hosts/network supplied in config or entire localnet
                     46         var arpHosts = self.config.network || '-l';
                     47                                 var options = {
                     48                                                 cachePassword: true,
                     49                                                 prompt: 'Password,' + self.config.Password     // put your password where ???? are (notice the quotes around)
                     50                                 }
                     51         var arp = sudo(['arp-scan', '-q', arpHosts]) //, options);
                    Module entry in config.js:
                    139                         module:                 "MMM-NetworkScanner",
                    140                         position:               "bottom_center",
                    141                         header:                 "Devices Online",
                    142                         config: {
                    143                                 devices: [
                    144                                 { ipAddress: "192.168.1.11", name: "Champagne", icon: "server"},
                    145                                 { ipAddress: "192.168.1.15", name: "Millie", icon: "server"},
                    146                                 { ipAddress: "192.168.1.17", name:  "Marmite", icon:  "server"}
                    147                                 ],
                    148                                 showUnknown: false,
                    149                                 showOffline:  true,
                    150                                 keepAlive:  600,
                    151                                 showLastSeen:  true,
                    152                                 updateInterval:  30,
                    153                                 Password:  'xxxx'
                    154                                 }
                    155                 },
                      @jthirasilpa weird…
                      the trace shows, on a timer tick (in the modulename.js) the node+helper received a socket message (sendSocketNotification from modulename.js), and received in node_helper)
                      the notification is correct, and it starts to rescan the network…
                      but, it has lost the config pointer for some reason…
                      weird…
                      please do another git pull
                      also add debug:true,
                      to the module config section
                      let me know
                      thanks
                        jthirasilpa
                        Thanks. Scan seems to find some devices, but does not display them on Mirror.
                        Here is output log:
                        [20:41:24.611] [LOG]    MMM-NetworkScanner is performing arp-scan
                        [20:41:24.650] [LOG]    MMM-NetworkScanner is performing ip address scan
                        [20:41:24.651] [LOG]    MMM-NetworkScanner is checking device:  Champagne
                        [20:41:24.651] [LOG]    MMM-NetworkScanner is pinging  192.168.1.11
                        [20:41:24.666] [LOG]    MMM-NetworkScanner is checking device:  Millie
                        [20:41:24.667] [LOG]    MMM-NetworkScanner is checking device:  Marmite
                        [20:41:24.667] [LOG]    MMM-NetworkScanner is pinging  192.168.1.17
                        [20:41:24.690] [LOG]    MMM-NetworkScanner is checking device:  JoJo
                        [20:41:24.691] [LOG]    MMM-NetworkScanner is pinging  192.168.1.70
                        [20:41:24.705] [LOG]    MMM-NetworkScanner completed SCAN_NETWORK
                        [20:41:24.707] [LOG]    MMM-NetworkScanner ping result:  [ 'Champagne', true ]
                        [20:41:26.741] [LOG]    MMM-NetworkScanner ping result:  [ 'Marmite', false ]
                        [20:41:26.743] [LOG]    MMM-NetworkScanner ping result:  [ 'JoJo', false ]
                        [20:41:54.605] [LOG]    MMM-NetworkScanner received SCAN_NETWORK
                        [20:41:54.605] [LOG]    MMM-NetworkScanner is performing arp-scan
                        [20:41:54.630] [LOG]    MMM-NetworkScanner is performing ip address scan
                        [20:41:54.631] [LOG]    MMM-NetworkScanner is checking device:  Champagne
                        [20:41:54.631] [LOG]    MMM-NetworkScanner is pinging  192.168.1.11
                        [20:41:54.644] [LOG]    MMM-NetworkScanner is checking device:  Millie
                        [20:41:54.645] [LOG]    MMM-NetworkScanner is checking device:  Marmite
                        [20:41:54.645] [LOG]    MMM-NetworkScanner is pinging  192.168.1.17
                        [20:41:54.658] [LOG]    MMM-NetworkScanner is checking device:  JoJo
                        [20:41:54.659] [LOG]    MMM-NetworkScanner is pinging  192.168.1.70
                        [20:41:54.672] [LOG]    MMM-NetworkScanner completed SCAN_NETWORK
                        [20:41:54.675] [LOG]    MMM-NetworkScanner ping result:  [ 'Champagne', true ]
                        [20:41:56.706] [LOG]    MMM-NetworkScanner ping result:  [ 'Marmite', false ]
                        [20:41:56.707] [LOG]    MMM-NetworkScanner ping result:  [ 'JoJo', false ]
                        Error log:
                        [20:35:38.953] [ERROR]  (node:20348) MaxListenersExceededWarning: Possible Event        Emitter memory leak detected. 11 error listeners added. Use emitter.setMaxListen        ers() to increase limit
                        [20:35:38.953] [ERROR]  (node:20348) MaxListenersExceededWarning: Possible Event        Emitter memory leak detected. 11 end listeners added. Use emitter.setMaxListener        s() to increase limit
                        [20:35:38.954] [ERROR]  (node:20348) MaxListenersExceededWarning: Possible Event        Emitter memory leak detected. 11 drain listeners added. Use emitter.setMaxListen        ers() to increase limit
                        [20:35:38.954] [ERROR]  (node:20348) MaxListenersExceededWarning: Possible Event        Emitter memory leak detected. 11 close listeners added. Use emitter.setMaxListen        ers() to increase limit
                        [20:35:38.955] [ERROR]  (node:20348) MaxListenersExceededWarning: Possible Event        Emitter memory leak detected. 11 data listeners added. Use emitter.setMaxListene        rs() to increase limit
                        • 6
                        • 3 / 6
