    MMM-MQTTbridge
    Scheduled Pinned Locked Moved Unsolved System
    44 Posts 14 Posters 25.4k Views 15 Watching
    • SergeS Offline
      Serge
      @chimera said in MMM-MQTTbridge:
      eg: swimming pool temperature, only updates if it changes, garden sprinkler last run, only updates when it’s run, etc
      As far as I understood you, you need to issue some NOTI during the MM/Module startup, right?
      How would be the best option to do that? One possible solution is to have a file with the list of topics (e.g. “swimmingpool/temp/status”, “gardenspirnkler/run/status”) to which MQTTbrdige will send the mqtt-messages at startup.
      Will this solve your problem with the integration of MM to your smart home?
      • SergeS Offline
        Serge @oberpiller
        @oberpiller said in MMM-MQTTbridge:
        Is it possible to get variables (from “arrays”) into the mqttMsgPayload variable of NotiDictionary.js?
        nope. I will think about it.
        should it work somehow like that:
        In notiMqtt dict should be specified whether we are using variable or not and, if yes, use it:
        var notiMqttCommands = [
            commandId: "Command 1",
            mqttTopic: "myhome/kitchen/light/set",
            useVariables: true, //added new setting to the dict to
            mqttMsgPayload: ARTICLE_INFO_RESPONSE //if useVriables=true, put here the variable name. If useVariable=false or not stated - mqttMsgPayload will send "ARTICLE_INFO_RESPONSE" in its payload.
        SergeS 1 Reply Last reply Reply Quote 0
        • SergeS Offline
          Serge @Serge
          This post is deleted!
            shinebright
            When i publish 1 message, it’s receiving it multiple times for some reason. Do i need to be worried?
            screenshot
            • SergeS Offline
              Serge @shinebright
              @shinebright should produce one note per each mqtt message, check your settings once more or try to install on clean mm setup.
                shinebright @Serge
                @Serge got it thanks! i’ll give that a try. awesome module by the way, i managed to change some of your codes along with the compliments module. Now I’m sending messages from my phone to update the mirror compliments and the kids think the mirror is replying back to them. :)
                SergeS 1 Reply Last reply Reply Quote 1
                • SergeS Offline
                  Serge @shinebright
                  @shinebright what you had changed? Could you tell soi can add it as an option for the next releases
                  • F Offline
                    fribse
                    Hi @Serge
                    I’ve finally received the mirror itself, so now the MagicMirror is finally getting finished.
                    One of the things was to update the MM itself, as well as a few modules (screencast).
                    After doing that, I don’t see any mqtt status messages going out, and it doesn’t react on incoming either.
                    I’ve checked the username/password, still correct, and the IP hasn’t changed either?
                    • SergeS Offline
                      Serge @fribse
                      • SergeS Offline
                        Serge
                        Version 1.1 released https://github.com/sergge1/MMM-MQTTbridge
                        Code updated with the help of community members.
                        Now,
                        • mqtt topics introduced into mqttDictionary. This allows now:
                          – Subscribe to that specific topic from the mqttDictionary.
                          – now you can specify different behavior for the same payload from different topics,
                          e.g. if you got the mqttPayload “20” at “kitchen/temperature” topic and at “kitchen/humiduty” topic - different Command could be executed (before module recognized only payload for all the topics subscribed);
                        • Now, if notiPayload or mqttPayload are not specified within mqttDictionary or notiDictionary, the respective payload from mqtt or noti will be sent as payload for noti or mqtt.
                          E.g. if MM receives the mqtt message at “kitchen/temperature” with payload “20”, and mqttDictionary does not have specified payload at all - the “20” will go as payload for issued Noti.
                        • All errors of several mqtt connections disappear;
                        • mqttBridgeFormatOnly - not used anymore;
                        • Changed mqttDictionary according to notiDictionary. Subscription to topic only once
                        Please do not forget to change the config section and mqttDictionary accroding to the new structure.
                        • cowboysdudeC Offline
                          cowboysdude Module Developer
                          This is really needed and very nice!! Thank you!
                            majdzik84
                            Stupid novice question. How can I update the module? :) I have to remove the old one and upload the new one, is there any command to update the already uploaded module?
                              sdetweil @majdzik84
                              @majdzik84 upload? internet is upload, local computer is download
                              to update a module locally, you go to that module folder and do a git pull
                              sometimes you also need to do npm install again, but I would try first without it
                              • K Offline
                                KSumwalt
                                Hello,
                                I installed the module on Aug 18, 2020 and have it connecting to my broker. Either I have something off or the module always sends out the notification’s payload and I cannot over-ride such. My notiDictionary.js file looks like this:
                                var notiHook = [
                                    notiId: "USERS_LOGIN",
                                    notiPayload: [
                                        payloadValue: '',
                                        notiMqttCmd: ["Command 1"]
                                    notiId: "SHOW_ALERT",
                                    notiPayload: [
                                        payloadValue: '',
                                        notiMqttCmd: ["Command 2"]
                                    notiId: "NEWS_FEED",
                                    notiPayload: [
                                        payloadValue: '',
                                        notiMqttCmd: ["Command 3"]
                                    mqttTopic: "mirror/profile",
                                    mqttMsgPayload: 'george'
                                 //    mqttMsgPayload: '{state:"OFF"}'
                                    commandId: "Command 2",
                                    mqttTopic: "mirror/alert/set",
                                    mqttMsgPayload: 'on'
                                    commandId: "Command 3",
                                    mqttTopic: "mirror/alert/test",
                                    mqttMsgPayload: 'go'
                                module.exports = { notiHook, notiMqttCommands };
                                When an alert is shown, the SHOW_ALERT send an MQTT Topic of mirror/alert/set but the payload according to MQTT Snooper and my HomeSeer system is [object Object]. I expected it to be a string of on. NEWS_FEED does noth8ing, as expected from the config. USERS_LOGIN is from the MMM-Face-Reco-DNN module. It has a string value of the person who’s face it recognizes. When it recognizes me, the payload for the MQTT topic is Karl both when I have no value and when I have George in the payload setting as shown above.
                                This is how I have the module configured in the config.js file:
                                			module: 'MMM-MQTTbridge',
                                //			disabled: false,
                                				mqttServer: "mqtt://192.168.1.2:1883",
                                				mqttConfig:
                                					listenMqtt: true,
                                					interval: 300000,
                                				notiConfig:
                                					listenNoti: true,
                                					ignoreNotiId: ["CLOCK_MINUTE", "NEWS_FEED"],
                                					ignoreNotiSender: ["system", "NEWS_FEED"],
                                				// set "NOTIFICATIONS -> MQTT" dictionary at /dict/notiDictionary.js
                                				// set "MQTT -> NOTIFICATIONS" dictionary at /dict/mqttDictionary.js
                                What might I be doing wrong?
                                Note that for an IP address and no username/password I had to set the server to mqttServer: “mqtt://192.168.1.2:1883”, dropping the colon (:) prior to the IP address. I had it in there based on the provided settings for the localhost version.
                                SergeS 3 Replies Last reply Reply Quote 0
                                • SergeS Offline
                                  Serge @KSumwalt
                                    Mrtrol2013
                                    Can I use this module to manage MMM-pages?
                                    • SergeS Offline
                                      Serge @KSumwalt
                                      @KSumwalt
                                      the module is working. try to reinstall it and check the configuration once more.
                                      Here is the community member says that he uses module perfectly https://forum.magicmirror.builders/topic/13726/mmm-ledstripcontrol-control-a-led-strip-with-optional-pong-game-support
                                      @Mrtrol2013 said in MMM-MQTTbridge:
                                      Yes.
                                      See
                                      • that part of MMM-pages’s readme here https://github.com/edward-shen/MMM-pages#regarding-notifications and
                                      • that part of MMM-MQTTbridge’s readme here https://github.com/sergge1/MMM-MQTTbridge#mqtt-to-notifications-dictionary-section
                                      • SergeS Offline
                                        Serge @KSumwalt
                                        @KSumwalt please update the module and try once more. If the problem will exist, send here your logs
                                        • F Offline
                                          fribse
                                          • Cr4z33C Offline
                                            Cr4z33
                                            I’ve got a BTicino F20T60A power consumption meter connected by MQTT so can someone please help me to show power usage only on MagicMirror by using this MM module?
                                            Feel free to ask me MQTT / Home Assistant details to provide (as I don’t know right now what you need 😅)!
                                            • 2 / 3
