    MMM-MQTT/MMM-TeslaLogger - Cleanup JS - help needed
    1 Posts 1 Posters 544 Views 1 Watching
    • spitzlbergerjS
      spitzlbergerj Project Sponsor Module Developer
      I have used MMM-MQTT as the basis for my MMM-TeslaLogger module. In MMM-MQTT there is an own local directory node_modules. At first sight this local dir is identical with the dir node_modules in the root directory of Magic Mirror.
      I now try to get rid of the local dir node_modules in my module. But I do not succeed.
      In MMM-TeslaLogger.js I only found one reference to the local node_modules, namely jsonpointer.js. This is also the case in MMM-MQTT.
      But if I change this reference to the node_modules in the Magic Mirror root, the module doesn’t run anymore and partly generates error messages. The pm2 log also shows error messages for the node_helper. These seem to refer to the line after the last line of the file ???
      I am a JavaScript Newbee and can’t get any further. Can someone please take a look at this?
      Unfortunately I don’t have access to the error messages right now - sorry. I will deliver them later.
      I would be very grateful for any help.
      Regards
      Josef
      Regards
      Josef
      http://www.spitzlberger.de/smartmirror, https://github.com/spitzlbergerj/MMM-TeslaLogger, https://github.com/spitzlbergerj/CaravanPi, https://www.la-gondola-barocca.de
