Module Regions - Tutorial Requested
9 Posts 4 Posters 6.5k Views 3 Watching
  • V Offline
    valid8r
    Can someone explain in basic conceptual terms how the module regions (‘.top., .third., … etc.’) are designed to work? I am trying to understand so I can enlarge or shrink the 4 boundaries for a given region but don’t understand how the .css works in this case.
    I suspect that others might find this useful as well and appreciate the time anyone takes to put something together.
    Many thanks in advance.
      mochman Module Developer
      You can find information about them here.
      V 1 Reply Last reply Dec 20, 2016, 4:51 PM Reply Quote 0
      • V Offline
        valid8r @mochman
        @mochman Thanks, I had/have that link and it is useful. I am trying to understand the way in which main.css defines the regions and how that structure actually works. I’m new to .css and find the code hard to understand. How for example are the horizontal dimensions set for a given region?
        S 1 Reply Last reply Dec 20, 2016, 4:55 PM Reply Quote 0
          strawberry 3.141 Project Sponsor Module Developer @valid8r
          @valid8r a couple of regions as you can see on the picture have full width and the others are generic
          they are placed with top, left, right and bottom properties and position: absolute on the screen
          V 1 Reply Last reply Dec 20, 2016, 5:05 PM Reply Quote 0
          • V Offline
            valid8r @strawberry 3.141
            @strawberry-3.141 If my questions get to be too frustrating, please feel free to say so and I will stop. So from this thread, how would I know what the right hand border size of a .top.left region was (in other words, how wide is the region)? The code I think from main.css for this is I believe the followingn, but it only defines the top for these regions is 100% of top, what are the width or border dimensions…?
            .region.top.right,
            .region.top.left,
            .region.top.center {
            top: 100%;
              broberg Project Sponsor
              They have no defined size per say,
              add
              outline: #fff solid;
              to all .regions, that will give you a sense of how they look.
              V 1 Reply Last reply Dec 20, 2016, 5:26 PM Reply Quote 1
              • V Offline
                valid8r @broberg
                @broberg Thanks, will do so, but I don’t understand how they can not have a defined size??? how does that work? For example, I have calendar (.top.left), Advent (.top.center) and Weather (.top.right)… however, the default sizes of each region/module are not equal thirds… trying to understand this.
                B 1 Reply Last reply Dec 20, 2016, 5:34 PM Reply Quote 0
                  broberg Project Sponsor @valid8r
                  @valid8r they expand, adapting to the content of the
                  They only need positioning and orientation.
                  all
                  without size constrains will adapt to it’s content and the
                  or body it’s placed in.
                  You can certainly add width and height constrains to the regions if you feel like it.
                  The thing with
                  is you can basically place them anywhere you want to, make them any size, make them lay over or under other
                  and so on and so on.
                  V 1 Reply Last reply Dec 20, 2016, 5:43 PM Reply Quote 1
                  • V Offline
                    valid8r @broberg
                    @broberg Interesting… I didn’t know about
                    and am now reading up on it. Thanks for pointing me in the right direction that explains a lot. I’ll try to read up on this before asking any more questions!
