    MMM-soccer v2
    Scheduled Pinned Locked Moved Sport
    52 Posts 9 Posters 35.7k Views 9 Watching
    • lavolp3L
      lavolp3 Module Developer
      Description:
      This module is based on @strawberry-3-141 s MMM-soccer but with many more functions and major changes in the background and frontside.
      Download:
      [card:lavolp3/MMM-soccer]
      Screenshots:
      (image upload seems still broken, please check github page for screenshots)
      Features:
      • major leagues and competitions from Europe included in the free API (see Readme)
      • (automatic) league rotation
      • Logos included, colored or b/w
      • flexible width, slim version available
      • LIVE mode (more API calls when live games are shown)
      • table with focus mode
      • Focus on one team per league
      Version 1.0.1
      • initial
      Version 1.0.2
      • bugfix in node_helper
      • UI tweaks (smaller team names)
      How to troubleshoot modules
      MMM-soccer v2, MMM-AVStock
      • C
        chassain 0
        Hello,
        Some errors after npm install
        pi@raspberrypi:~/MagicMirror/modules/MMM-soccer $ npm install
        npm ERR! code EJSONPARSE
        npm ERR! file /home/pi/MagicMirror/modules/MMM-soccer/package.json
        npm ERR! JSON.parse Failed to parse json
        npm ERR! JSON.parse Unexpected string in JSON at position 312 while parsing '{
        npm ERR! JSON.parse   "name": "mmm-soccer v2",
        npm ERR! JSON.parse   "version"'
        npm ERR! JSON.parse Failed to parse package.json data.
        npm ERR! JSON.parse package.json must be actual JSON, not just JavaScript.
        npm ERR!     /home/pi/.npm/_logs/2020-02-28T14_41_48_433Z-debug.log
        • lavolp3L
          lavolp3 Module Developer @chassain 0
          @chassain-0 thanks!
          Please do a git pull and try again.
          There was a missing comma in package.json.
          Let me know if it works.
          • C
            chassain 0 @lavolp3
            @lavolp3
            better but still…
            npm WARN Invalid name: "mmm-soccer v2"
            npm WARN MMM-soccer No description
            npm WARN MMM-soccer No repository field.
            npm WARN MMM-soccer No README data
            npm WARN MMM-soccer No license field.
            added 8 packages from 1 contributor in 4.453s
            found 0 vulnerabilities
            • C
              chassain 0 @chassain 0
              @chassain-0
              name changed in package.json and it’s ok
              • lavolp3L
                @chassain-0 yeah has also been changed in origin/master now.
                Recognized this as well.
                Sorry for the hickups and looking forward to any comments.
                C 2 Replies Last reply Reply Quote 0
                • C
                  chassain 0 @lavolp3
                  @lavolp3 thanks to you. I m going to try now
                  • C
                    chassain 0 @lavolp3
                    @lavolp3 Nice job…:)
                    • lavolp3L
                      Node_helper.js needed to be fixed.
                      Please do a git pull and restart the mirror if you experience problems.
                      • C
                        chassain 0
                        i understand live is ok now with api calls ? i like it
                        • lavolp3L
                          @chassain-0 It should but as I see it doesn’t seem to work. Will check tonight or tomorrow.
                          • StoffbeuteluweS
                            Stoffbeuteluwe Project Sponsor @lavolp3
                            @lavolp3 Hi, does the module work?
                            do I need a api ?
                            Thanks in advance…
                            greetings from Germany
                            • lavolp3L
                              lavolp3 Module Developer @Stoffbeuteluwe
                              @Stoffbeuteluwe HI,
                              live mode seems broken, will fix it tomorrow, but apart from that it works, yes.
                              You need a free api key from football-data.org.
                              Try it out and let me know if you find any problems.
                              • StoffbeuteluweS
                                @lavolp3 Hi, do i have to use the API out of the Email and that’s it?..or do I have to do something else with the API?
                                Thanks in advance
                                • lavolp3L
                                  @Stoffbeuteluwe Yes use the key that you have received and put it in your config and that’s it.
                                  • StoffbeuteluweS
                                    @lavolp3 thank you
                                    • D
                                      dirk-graetz
                                      Hi lavolp3,
                                      your module is crashing if showMatches = false
                                      kind regards
                                      • lavolp3L
                                        lavolp3 Module Developer @dirk-graetz
                                        @dirk-graetz thanks! Will have a look into it. Have to admit that I am not good in debugging my modules.
                                        • N
                                          Nero
                                          Does this show the Championship, Leagues 1 and 2 in England? Thanks
                                          • lavolp3L
                                            lavolp3 Module Developer @Nero
                                            @Nero No, only Premier League for England.
                                            • 1 / 3
