    MMM-COVID-19 (Deprecated)
    Scheduled Pinned Locked Moved Health
    71 Posts 16 Posters 38.7k Views 16 Watching
      sdetweil @Guest
      @Sean hm… ok. graph to me means line graph (something different from what was displayed before)…
      I have the table charts…
      france mainland is what I wanted…
      • ? Offline
        [[global:former-user]] @sdetweil
        To draw line graph needs canvas or other tricks. For me this enough. But if you have a PR, I will accept with welcome. :)
          sdetweil @Guest
          @Sean ok, i had misunderstood… default is drawgraph:true, so it was no different than before
            banbutcher
            ive reinstalled and now im only getting NZ graph showing and no world or spain or ireland, its solved the rise in cpu usage… hers my config code:
            // Covid-19
            			module: "MMM-COVID-19",
            			header: "COVID-19",
            			position: "bottom_right",
            			config:{
            				scanInterval: 1000 * 60 * 60 * 12,
            				rotateInterval: 0,
            				detailProvince: true,
            				pinned: ["Ireland"],
            				pinned: ["Spain"],
            				pinned: ["New Zealand"],
            				myPosition: {latitude:-43.5523955, longitude:172.6328479, metric:"km",}, //or null. // reserved for later.
            				logProvinceCountry: false,
            				logOnce: true,
            		        	sortOrder: null,
            				reportTimeFormat: "YYYY.MM.DD hh a",
            				drawGraph: true,
            any ideas?
              sdetweil @banbutcher
              @banbutcher pinned needs to be a single array w multiple names. See mine a few posts back. Also some names have changed
                banbutcher @sdetweil
                yup that did it… is it possible to scale the sizes down?
                ? R S 3 Replies Last reply Reply Quote 0
                • ? Offline
                  [[global:former-user]] @banbutcher
                  @banbutcher
                  All magic mirror modules have their own css ([module name].css). Look inside of that file then find what you need and override it in your css/custom.css of MagicMirror. Sorry, MM is DIY project so there is no silver bullet out of box.
                    retroflex Project Sponsor Module Developer @banbutcher
                    @banbutcher Another tip to easier find the css class for a certain text… use the Chrome developer tools where you can see all elements and their css attributes graphically.
                      @banbutcher I turned off the little graph at the bottom, drawgraph:false to save space
                      • W Offline
                        war6000
                        @Sean I just wanted to thank you for your work; also it would be helpful to note in GitHub that by setting
                        rotateInterval:0
                        it also disables the third slot (if users only need 2 slots). Again Thank you very much for your work.
                        • ? Offline
                          [[global:former-user]] @war6000
                          @war6000
                          :) Thanks for your mention. Frankly, it is described in README already
                           rotateInterval: 1000 * 5, // 0 means no rotate
                          But I agree it is somewhat not obvious.
                          • W Offline
                            wi_brewer
                            Anybody know why I’m getting this error when I try to start MM?
                            • ? Offline
                              [[global:former-user]] @wi_brewer
                              @wi_brewer What is your node version? (node -v)
                              • W Offline
                                wi_brewer @Guest
                                @Sean v7.10.1
                                • ? Offline
                                  @wi_brewer
                                  Too low to run this module. Sorry.
                                  • W Offline
                                    wi_brewer @Guest
                                    @Sean Thanks for the quick replies. What’s the minimum version required?
                                    • ? Offline
                                      @wi_brewer
                                      I think to use async arrow function, At least node 8 be needed.
                                      Current Most Recent version is 13.11 and Most recommended version is 12.16 at this moment.
                                      And MagicMirror install guide usually assumes 10.x
                                        siggmur
                                        Possible to add some sort of scaling?
                                          mrdenmark
                                          at the moments i have 2 slots,the first is world total and the second rotates through all the affected countries-can i change the second to rotate though a defined range of countries instead? i don’t have enough scrren space to give each country its own slot.
                                          • L Offline
                                            luxiouronimo
                                            heya, thanks for the module; here’s what myne is looking like with some custom css:
                                            https://imgur.com/a/1y61O7L
                                            can we get a thousands separator? personally i’d like a comma, but i gather folks in other regions might prefer a period, so the option for either would be useful…
                                            also the US Total numbers don’t seem right; there’s a blue bar a few days ago, but no R or NR, but then again, perhaps the data is outta whack or the api is changing as i now see negative numbers in various places…
                                            ? 2 Replies Last reply Reply Quote 0
                                            • 3 / 4
