    MMM-COVID-19 (Deprecated)
    Scheduled Pinned Locked Moved Health
    71 Posts 16 Posters 31.4k Views 16 Watching
    • ? Offline
      A Former User @war6000
      @war6000
      :) Thanks for your mention. Frankly, it is described in README already
       rotateInterval: 1000 * 5, // 0 means no rotate
      But I agree it is somewhat not obvious.
      • W Offline
        wi_brewer
        Anybody know why I’m getting this error when I try to start MM?
        • ? Offline
          A Former User @wi_brewer
          @wi_brewer What is your node version? (node -v)
          • W Offline
            wi_brewer @Guest
            @Sean v7.10.1
            • ? Offline
              @wi_brewer
              Too low to run this module. Sorry.
              • W Offline
                wi_brewer @Guest
                @Sean Thanks for the quick replies. What’s the minimum version required?
                • ? Offline
                  @wi_brewer
                  I think to use async arrow function, At least node 8 be needed.
                  Current Most Recent version is 13.11 and Most recommended version is 12.16 at this moment.
                  And MagicMirror install guide usually assumes 10.x
                    siggmur
                    Possible to add some sort of scaling?
                      mrdenmark
                      at the moments i have 2 slots,the first is world total and the second rotates through all the affected countries-can i change the second to rotate though a defined range of countries instead? i don’t have enough scrren space to give each country its own slot.
                      • L Offline
                        luxiouronimo
                        heya, thanks for the module; here’s what myne is looking like with some custom css:
                        https://imgur.com/a/1y61O7L
                        can we get a thousands separator? personally i’d like a comma, but i gather folks in other regions might prefer a period, so the option for either would be useful…
                        also the US Total numbers don’t seem right; there’s a blue bar a few days ago, but no R or NR, but then again, perhaps the data is outta whack or the api is changing as i now see negative numbers in various places…
                        ? 2 Replies Last reply Reply Quote 0
                        • 6
                        • 7
                        • 8
                        • 6 / 8
