    MMM-COVID-19 (Deprecated)
    Scheduled Pinned Locked Moved Health
    71 Posts 16 Posters 31.4k Views 16 Watching
      sdetweil @Guest
      @Sean hm… ok. graph to me means line graph (something different from what was displayed before)…
      I have the table charts…
      france mainland is what I wanted…
      • ? Offline
        A Former User @sdetweil
        To draw line graph needs canvas or other tricks. For me this enough. But if you have a PR, I will accept with welcome. :)
          sdetweil @Guest
          @Sean ok, i had misunderstood… default is drawgraph:true, so it was no different than before
            banbutcher
            ive reinstalled and now im only getting NZ graph showing and no world or spain or ireland, its solved the rise in cpu usage… hers my config code:
            // Covid-19
            			module: "MMM-COVID-19",
            			header: "COVID-19",
            			position: "bottom_right",
            			config:{
            				scanInterval: 1000 * 60 * 60 * 12,
            				rotateInterval: 0,
            				detailProvince: true,
            				pinned: ["Ireland"],
            				pinned: ["Spain"],
            				pinned: ["New Zealand"],
            				myPosition: {latitude:-43.5523955, longitude:172.6328479, metric:"km",}, //or null. // reserved for later.
            				logProvinceCountry: false,
            				logOnce: true,
            		        	sortOrder: null,
            				reportTimeFormat: "YYYY.MM.DD hh a",
            				drawGraph: true,
            any ideas?
              sdetweil @banbutcher
              @banbutcher pinned needs to be a single array w multiple names. See mine a few posts back. Also some names have changed
                banbutcher @sdetweil
                yup that did it… is it possible to scale the sizes down?
                ? R S 3 Replies Last reply Reply Quote 0
                • ? Offline
                  A Former User @banbutcher
                  @banbutcher
                  All magic mirror modules have their own css ([module name].css). Look inside of that file then find what you need and override it in your css/custom.css of MagicMirror. Sorry, MM is DIY project so there is no silver bullet out of box.
                    retroflex Project Sponsor Module Developer @banbutcher
                    @banbutcher Another tip to easier find the css class for a certain text… use the Chrome developer tools where you can see all elements and their css attributes graphically.
                      @banbutcher I turned off the little graph at the bottom, drawgraph:false to save space
                      • W Offline
                        war6000
                        @Sean I just wanted to thank you for your work; also it would be helpful to note in GitHub that by setting
                        rotateInterval:0
                        it also disables the third slot (if users only need 2 slots). Again Thank you very much for your work.
                        • 6
                        • 7
                        • 8
                        • 5 / 8
