    Diego Vieria Random-Photo read image from PI ?
    13 Posts 3 Posters 8.7k Views 3 Watching
      alverman
      HI,
      is possible change the random-photo module to make sure that it refers to one of the PI image folder?
      many thanks, Alberto
      • U Offline
        Ultimatum22 Module Developer
        Try this module: https://github.com/Ultimatum22/MMM-RandomBackground I developed it. Should meet your requirements.
          alverman
          But where put the folder address ?
          In RandomBackground.js ?
          // Additional folders to find photos in
          in this mode:
          photoDirectories: [images]
          Thanks, Alberto
          • strawberry 3.141S Offline
            strawberry 3.141 Project Sponsor Module Developer @alverman
            @alverman currently a custom path is not implemented yet.
            the images should be placed in this directory MagicMirror/modules/MMM-RandomBackground/photos/
              alverman
              Ah OK !!
              But when active this module in config.js I see all black !!
              In photos directory I have 3 png images !!
              why ?
              Thanks, Alberto
              • U Offline
                Please post the part of the config file you have added for this module. Also did you look in the log and/or browser console? Without any info it’s near impossible to help.
                  alverman
                  And in dev mode I have 1 error:
                  failed to load http://localhost:8080/modules/RandomBackground//RandomBackground.js
                  resource: the server responded with a status of 404 (non found)
                  • U Offline
                    Please show your config, I am assuming your either did something wrong there. Also how did you add this module? The folder and js file are wrong, should be MMM- before it.
                      alverman
                      You were right !!
                      I had forgotten to put in the MMM- config.js
                      But now I have another error when I npm install I get:
                      Succeffully applied Snyk Patches
                      npm grunt-yamllint@0.2.0 WARN requires a peer of grunt@tilde0.4.0 but none installed
                      While in the dev box now I get:
                      http: // localhost: 8080 / modules / MMM-RandomBackground // node_modules / jquery / dist / jquery.min.js
                      Failed to load resource: the server responded with a status of 404 (not found)
                      my config.js is:
                      /* Magic Mirror Config Sample
                      • By Michael Teeuw http://michaelteeuw.nl
                      • MIT Licensed.
                      var config = {
                      port: 8080,
                      language: 'it',
                      timeFormat: 24,
                      units: 'metric',
                      		module: 'alert',
                      		module: 'clock',
                      		position: 'top_left',
                      			//displayType: 'analog',
                      			//analogSize: '150px',
                      			clockBold: 'true',
                      		module: 'calendar',
                      		header: 'Italy Holidays',
                      			symbol: 'calendar-check-o ',
                      			url: 'webcal://www.calendarlabs.com/templates/ical/Italy-Holidays.ics'
                      		module: 'compliments',
                      		position: 'lower_third'
                      		module: 'currentweather',
                      		position: 'top_right',
                      			locationID: '',  //ID from http://www.openweathermap.org
                      			appid: 'bd58e4e078cdfc75d925db0884834114'
                      		module: 'weatherforecast',
                      		header: 'Weather Forecast',
                      			locationID: '5128581',  //ID from http://www.openweathermap.org
                      		module: 'newsfeed',
                      		position: 'bottom_bar',
                      			feeds: [
                      				title: "Repubblica",
                      				url: "http://www.repubblica.it/rss/cronaca/rss2.0.xml"
                      			showSourceTitle: true,
                      			showPublishDate: true
                      	        module: 'MMM-ImageDisplay',
                      	            image: 'Amore_1.png', // Name of the image (including file extension) here, place image in '/images/' folder
                      	            maxWidth: '20%', // Optional, possible values: absolute (e.g. '20px') or relative ('50%')
                      	            maxHeight: '200%', // Optional, use absolute values (e.g. '30px', '100px')
                      	        position: 'bottom_right'    // This can be any of the regions.
                      		module: 'MMM-Instagram',
                      		position: 'top_center',
                      		access_token: '3231895908.1677ed0.48b0c4acc7a74f1d86a404a4a5616457',
                      		count: 200,
                      		min_timestamp: 0,
                      		animationSpeed: 5500,
                      		updateInterval: 12500
                      module: ‘MMM-RandomPhoto’,
                      position: ‘fullscreen_below’,
                      opacity: 0.3,
                      animationSpeed: 500,
                      updateInterval: 60,
                      url: ‘…/images/Amore_1.png’
                      module: ‘MMM-Remote-Control’
                      , posistion: ‘bottom_left’
                      module: ‘MMM-RandomBackground’,
                      config:{
                      animationSpeed: 1000,
                      updateInterval: 500
                      if (typeof module !== ‘undefined’) {module.exports = config;}
                        alverman
                        All OK !!
                        Work very well … thanks
                        Alberto
