    my mirror freezes!
    98 Posts 5 Posters 48.5k Views 4 Watching
      sdetweil @Manu85
      @Manu85 that means the mirror is already running, probably cause of pm2… need to stop it first, can’t run two at the same time
        Manu85
        ok you can tell me how to do it?
          sdetweil @Manu85
          @Manu85 pm2 stop 0
            Manu85
            ok I made the order my MM goes out and it doesn’t start anymore, and I don’t know how to get you to send the file to your email, I’m really sorry to be too unable :-(
              sdetweil @Manu85
              @Manu85 said in my mirror freezes!:
              on boot, right?
              if you use winscp to connect to pi, then copy the file to your pc and mail from there
                Manu85
                pi@raspberrypi:~/MagicMirror $ tail somefile
                [2020-04-06 15:19:00.632] [LOG] 2020-04-06T15:19:00 Connecting socket for: newsfeed (/home/pi/MagicMirror/js/node_helper.js:97 Class.setSocketIO)
                [2020-04-06 15:19:00.633] [LOG] 2020-04-06T15:19:00 Starting module: newsfeed (/home/pi/MagicMirror/modules/default/newsfeed/node_helper.js:15 Class.start)
                [2020-04-06 15:19:00.634] [LOG] 2020-04-06T15:19:00 Sockets connected & modules started … (/home/pi/MagicMirror/js/app.js:233 )
                [2020-04-06 15:19:00.858] [LOG] 2020-04-06T15:19:00 Launching application. (/home/pi/MagicMirror/js/electron.js:81 App.)
                [2020-04-06 15:19:03.615] [LOG] 2020-04-06T15:19:03 MMM-Logging updated config received, reloading console (/home/pi/MagicMirror/modules/MMM-Logging/node_helper.js:30 Class.socketNotificationReceived)
                [2020-04-06 15:19:03.617] [LOG] 2020-04-06T15:19:03 payload: undefined (/home/pi/MagicMirror/modules/MMM-Logging/node_helper.js:34 Class.socketNotificationReceived)
                [2020-04-06 15:19:03.619] [LOG] 2020-04-06T15:19:03 payload: undefined (/home/pi/MagicMirror/modules/MMM-Logging/node_helper.js:34 Class.socketNotificationReceived)
                [2020-04-06 15:19:03.640] [LOG] 2020-04-06T15:19:03 Create new calendar fetcher for url: http://p59-calendars.icloud.com/published/2/2uR1boEvTP2Z11yC3RAkgMluEyI6FkQslrByha_3OaasENn6SQAtTWIYmfP6JXqtyFFXzQwCFuV_rleNhqA2u8ZaQkK6-6HzuFLzdeE_Pic - Interval: 300000 (/home/pi/MagicMirror/modules/default/calendar/node_helper.js:49 Class.createFetcher)
                [2020-04-06 15:19:03.667] [LOG] 2020-04-06T15:19:03 Create new news fetcher for url: https://www.lepoint.fr/rss.xml - Interval: 300000 (/home/pi/MagicMirror/modules/default/newsfeed/node_helper.js:48 Class.createFetcher)
                [2020-04-06 15:19:04.164] [LOG] 2020-04-06T15:19:04 payload: undefined (/home/pi/MagicMirror/modules/MMM-Logging/node_helper.js:34 Class.socketNotificationReceived)
                  sdetweil @Manu85
                  @Manu85 yes, now we need to wait for hang again
                    Manu85
                    I just rebooted the mirror restarted, is that what I had to do?
                      sdetweil @Manu85
                      @Manu85 yes, it is logging to the pm2 log, all ok
                        Manu85
                        I was afraid of doing something stupid! now something must be done?
                          sdetweil @Manu85
                          @Manu85 tomorrow when hung, do
                          pm2 logs --lines=100 >somefile
                          and look at somefile
                            Manu85
                            ok i will wait tomorrow, thanks for your help
                              Manu85
                              @sdetweil [0_1586246858572_somefile](Uploading 100%)
                                Manu85
                                @sdetweil I can’t get you to pass the “somefile” file on the forum, the file must be in jpg, tif format … I tried to convert them to jpg by splitting the files, but it doesn’t work not either, you told me that I could send it to you by email, but I don’t see how to do it, when I go to your profile it just offers me a chat conversation and the cat only accepts 1000 characters and the file does a lot more, I don’t know how to do it, thanks for your help
                                  sdetweil @Manu85
                                  @Manu85 you would copy somefile to where you have an email client and then send it like normal mail
                                  I gave u my email adress
                                    Manu85
                                    “u can send it to me by email, to my same userid as here at gmail”?
                                      sdetweil @Manu85
                                      @Manu85 correct… what is my userid here? yours is manu85
                                        Manu85
                                        I just sent you an email thank you for confirming that it is correct
                                          sdetweil @Manu85
                                          @Manu85 from the log
                                          looks like MMM-SoccerLiveScore/ had a fatal error when no data was presented
                                           [ERROR]  2020-04-07T09:00:27 <error> SyntaxError: Unexpected token u in JSON at position 0
                                          0|MagicMir |     at JSON.parse (<anonymous>)
                                          0|MagicMir |     at Request._callback (/home/pi/MagicMirror/modules/MMM-SoccerLiveScore/node_helper.js:192:29)
                                          and that error killed MM
                                          0|MagicMir | [2020-04-07 09:00:27.567] [LOG]    2020-04-07T09:00:27 <log> Whoops! There was an uncaught exception... (/home/pi/MagicMirror/js/app.js:39 process.<anonymous>)
                                          0|MagicMir | [2020-04-07 09:00:27.592] [LOG]    2020-04-07T09:00:27 <log> MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection? (/home/pi/MagicMirror/js/app.js:41 process.<anonymous>)
                                            Manu85
                                            @sdetweil well done !!! Do we have to do something?
                                            • 3 / 5
