    [MMM-JaST] Just another Stock Ticker (new: version 2.x)
    166 Posts 37 Posters 232.2k Views 39 Watching
    • H Offline
      Harry @Jalibu
      @Jalibu Thanks! I knew I missed something. :-)
      • JalibuJ Offline
        Jalibu Module Developer
        The latest update officially introduced the new additional “table” view mode.
        Table
        Vertical
        Happy using :-)
        Feedback welcome.
        • 1 Offline
          1a2a3a
          Hi @Jalibu
          1. how do i change the stock name color?
          2. i have the module as static on my top right. how do i shift the entire thing to the screen right?
            justbob
            This module has been missing two things from the start, imho:
            1.) Ability to rename “Portfolio:” to custom tag, just like we can set stocks.
            2.) An option to add to portfolio cash amount.
            Everyone likes seeing MagicMirror, but sometimes when guests come over, the last thing you want somebody from outside to see is that you actually have a portfolio, let alone the size of it.
            Without it being seen, one can just say that they like to follow trends and keep things private.
            I change the name of Portfolio to some made-up ticker and pretend it’s a ticker for some index, but it’s a drag to mess around with en.json file in translations folder every time there’s an update.
            As for cash amount, sometimes there is unspecified amount of cash sitting in investors account. It’s not part of the portfolio per se, but being on investor account, it’s almost as good as being a part of portfolio.
            Is there any chance of seeing 1.) and/or 2.) being implemented?
            JalibuJ 1 Reply Last reply Reply Quote 0
            • JalibuJ Offline
              Jalibu Module Developer @justbob
              @justbob
              Thank you for your feedback and ideas for improvement.
              Do I understand your feature requests correctly?
              1. You want a way to explicitly change the name of the portfolio to e.g. “my money pot:”?
              2. Would you like a way to add a fixed value of money to the calculated portfolio assets consisting of shares?
                portfolioValue = extraMoney + calculatedPortfolioValueBasedOnSpecifiedShares
              Technically this is possible.
              However, unfortunately I don’t have the time to fulfill new requests at the moment due to other projects.
              But I am always happy to receive pull requests or small motivating donations.
              • JalibuJ Offline
                Jalibu Module Developer @Jalibu
                Dear fans and users of this module,
                unfortunately Yahoo has switched off the Stock API in its previous form. The module is therefore currently unable to retrieve data (an error appears in the log).
                The author of the library that Jast uses to retrieve data from Yahoo is working on a solution. At the moment, however, it is unclear whether there will/can be one.
                I will monitor the progress of the development and keep you informed.
                I am sorry that there is nothing else I can do at the moment but wait and see.
                JalibuJ 1 Reply Last reply Reply Quote 1
                • JalibuJ Offline
                  Update: The issue was fixed.
                  Please read the version’s release notes for instructions for updating this module.
                  S L 2 Replies Last reply Reply Quote 1
                    sethzarny @Jalibu
                    @Jalibu Thank you for making the change to resolve the API format modification made by Yahoo. My timing was perfect. I was diagnosing the issue on my mirror when you updated your changes. They are working perfectly. Appreciate it.
                    • M mishman referenced this topic on
                    • L Offline
                      leonids @Jalibu
                      @Jalibu
                      I had tried to install MMM-Jast module several times but always get this error:
                      I run Magic Mirror on Raspberry Pi2B . Is this a problem?
                      (???) ? idealTree:MMM-Jast: sill idealTree buildDeps
                      <— Last few GCs —>
                      [28023:0x57d41a8] 57937 ms: Mark-Compact (reduce) 225.8 (233.7) -> 225.7 (233.9) MB, 270.99 / 0.02 ms (+ 84.6 ms in 0 steps since start of marking, biggest step 0.0 ms, walltime since start of marking 445 ms) (average mu = 0.932, current mu = 0.608) a[28023:0x57d41a8] 58305 ms: Mark-Compact (reduce) 226.1 (233.9) -> 226.1 (234.4) MB, 356.64 / 0.00 ms (average mu = 0.834, current mu = 0.030) allocation failure; scavenge might not succeed
                      <— JS stacktrace —>
                      FATAL ERROR: Reached heap limit Allocation failed - JavaScript heap out of memory
                      ----- Native stack trace -----
                      Aborted
                      leonid@magicmirror:~/MagicMirror/modules/MMM-Jast $
                      S JalibuJ 2 Replies Last reply Reply Quote 0
                        sdetweil @leonids
                        @leonids you need to increase the swap space size
                        and maybe the heap size
                        for the heap size in config.js before the
                        modules:[
                        add
                        electronSwitches:{ "js-flags": "--max-old-space-size=8192"},
                        that will allocate 8 Meg of heap. you can make it bigger…
                        make sure you increase the swap space
                        I’ll leave that to a Google search for you
                        L 2 Replies Last reply Reply Quote 0
                        • L Offline
                          leonids @sdetweil
                          Thanks,
                          I have tried both of these things and nothing helped :(
                          leonid@magicmirror:~/MagicMirror/modules/MMM-Jast $ free -h
                          total used free shared buff/cache available
                          Mem: 922Mi 164Mi 441Mi 8.0Mi 316Mi 695Mi
                          • L Offline
                            leonids @sdetweil
                            I have doubled swap space and added heap settings in config.js but it did not change anything, Still same crash as before
                            Maybe 1G RAM is too small for this program?
                            Mem: 922Mi 247Mi 221Mi 31Mi 453Mi 589Mi
                            Swap: 199Mi 54Mi 145Mi
                              sdetweil @leonids
                              @leonids ok it’s something else
                              • JalibuJ Offline
                                Jalibu Module Developer @leonids
                                @leonids do you get this error during module installation or during runtime?
                                • L Offline
                                  leonids @Jalibu
                                  @Jalibu
                                  I get error when I try “npm install” from MMM-JaST directory
                                  • JalibuJ Offline
                                    This post is deleted!
                                    • JalibuJ Offline
                                      @leonids yes, I guess 1G RAM is not enough.
                                        Askedal @Jalibu
                                        Hello @Jalibu ,
                                        many thanks for this great module.
                                        I lately upgrade the module to get rid of the Yahoo crumb error, but I still get an error like:
                                        1|mm | [07.05.2024 09:04.57.536] [WARN]
                                        1|mm | API request for MSFT failed: request to https://query2.finance.yahoo.com/v10/finance/quoteSummary/MSFT?formatted=false&modules=price&crumb=EIJ.XkWSxQd failed, reason: connect ECONNREFUSED 0.0.0.0:443
                                        Any idea on how to fix this ?
                                        Many thanks
                                        Clas
                                        • JalibuJ Offline
                                          Jalibu Module Developer @Askedal
                                          @Askedal
                                          have you tried to delete and re-clone the module with a fresh npm install?
                                            Askedal @Jalibu
                                            Hi @Jalibu,
                                            yes, I did a uninstall, wiped the directory and then re-cloned the module, but the error is still the same.
                                            Clas
                                            • 6
                                            • 7
                                            • 8
                                            • 9
                                            • 8 / 9
