    Can't clone from GitHub
    107 Posts 3 Posters 63.0k Views 3 Watching
      sdetweil @MMRPi1
      @MMRPi1 no… not really…
      so when u go to clone, you open the project github page, push the green clone or download button mid page right, then push the copy button next to the url, right?
      then open the terminal window and type git clone
      and then paste in the url just copied…
      lets try to get one file, not using git
      curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/dumpactivemodules.js >dumpactivemodules.js
      should produce a tiny js file
        MMRPi1 @sdetweil
        @sdetweil I think that worked
          sdetweil
          this link says it might be a library update
          are you on windows or linux?
          for linux
          https://stackoverflow.com/questions/52379234/gnutls-handshake-failed-error-in-the-pull-function
          circa 2019…
          for windows, do you use a proxy to access the network?
            MMRPi1 @sdetweil
            @sdetweil I’m using SSH on Windows to access the pi (Linux obviously). I tried on the pi as well but I got the same error.
            I tried the advice on stack overflow but got the same error.
              sdetweil @MMRPi1
              @MMRPi1 how do you connect to the internet?
                MMRPi1 @sdetweil
                @sdetweil Through my router. Not sure I understand the question
                  sdetweil @MMRPi1
                  @MMRPi1 ok, just checking… some people have another machine acting as a router…
                    @sdetweil can u use git clone on windows?
                    (have to install git 1st)
                      MMRPi1 @sdetweil
                      @sdetweil Yes it works fine.
                        sdetweil @MMRPi1
                        @MMRPi1 said in Can't clone from GitHub:
                        Not sure what to do about it though. Since I’ve been able to update MM and also add new modules in the past.
                        hm… what OS is this? and when was the last system update?
                        sudo apt-get update
                        sudo apt-get upgrade
                        • 10
                        • 11
                        • 2 / 11
