    Forum Git-Card feature broken?
    Scheduled Pinned Locked Moved Forum
    13 Posts 3 Posters 4.5k Views 3 Watching
    • wishmaster270W Offline
      wishmaster270 Module Developer
      i normally added cards to my module descriptions in the showcase are.
      Currently the cards are not being included. Is this feature broken?
      I tried it with Firefox and Chromium, both with the same result.
      • BKeyportB Offline
        BKeyport Module Developer
        in this forum? This forum is rapidly breaking all over the place. I’ve posted things without the post showing until next load, image uploading hasn’t happened for nearly a year, etc.
          sdetweil @BKeyport
          @BKeyport @MichMich put in a fix for the image loading the other day. the forum has been busted since.
          I have asked him to back out the image upload fix… but haven’t seen any response
          • BKeyportB Offline
            There’s more bugs than functionality at this point. Grrr. carry on, I guess. One thing I noticed, if I strip off the theming, it fixed my major issue - things not showing as posted and the post data stuck…
              sdetweil @BKeyport
              @BKeyport how do you strip off themeing? I had default theme, now have superhero, (it shows the action buttons on the chart top bar)
              if u refresh after posting it will show
              • BKeyportB Offline
                I went from a theme to the default. Even refreshing in the theme I was using wasn’t showing the post was accepted. The big part was it was acting as if the post wasn’t accepted… Leave and come back, and the post wasn’t there. had to navigate off site and then come back to see it - even then, you reply to something else on the thread, and the contents of the post was still in the edit box.
                  sdetweil @BKeyport
                  @BKeyport correct… wait 10 seconds, hit refresh, the post will be there, then hit reply, then discard
                  4 or 5 of us having the same problem…
                  the fix for image upload was a nodebb runtime upgrade, can’t go back.
                  my problem is not cleared by going back to the default theme…
                  also, it follows my userid. I had mitch logon as me, and Mykle1, but experienced the problem.
                  neither have it with their ids.
                  i created a new user, it also fails.
                  • BKeyportB Offline
                    so weird… Oh well, maybe the nodebb crew will figure out which two sticks to rub together to get it fixed soon.
                      sdetweil @BKeyport
                      @BKeyport i don’t think Mich has reported anything to them
                      • BKeyportB Offline
                        Sam, true - however, if as with previous bugs, it’s all over nodebb’s forum.
                          sdetweil
                          I have posted a topic to nodebb forum… looks like card needs a new plugin install with new nodebb update…
                          @MichMich can u check on and fix the card problem?
                            Mitch had to disable the card plugin as it doesn’t have an updated version for the version of nodebb we are running.
                            there were a bunch of breaking changes with the nodebb upgrade.
                              Thanks for the reply. I added download links to all my posts for the moment.
