    MMM-Assistant2Display
    10 Posts 5 Posters 1.9k Views 5 Watching
      JohnBachini
      Hi, I have installed, but unable to get video/youtube to play anything, it attempts to play and then error on screen, but disappears to quickly to read, but in logs
      youtube.js:77 [AMK2:ADDONS:A2D] Player Error 150: Not Allowed By Owner
      config is.
      //			disabled: true,
      			module: "MMM-AssistantMk2",
      				verbose: true,
      				debug: true,
      				useA2D: true,
      				ui: "Fullscreen",
      				deviceModelId: "mmwithga-mmwithga-cffskt",
      				deviceInstanceId: "mmwithga",
      				assistantConfig: {
      					latitude: 51.968653,
      					longitude: -0.737203,
      //				responseConfig: {
      //					useHTML5: false,
      //					playProgram: "mpg123",
      			record: {
      				recordProgram : "arecord",
      				device        : "plughw:2,0",
      				recipes: [ "with-MMM-Hotword.js" ],
          			profiles: {
        		    		"default": {
        		      			profileFile: "default.json",
      		        		lang: "en-UK"
        		  		addons: false,
      			module: "MMM-Assistant2Display",
      				debug: true,
      error log
      MMM-PlexNowPlaying: Data received from the Plex server after 1 attempt(s).
      MMM-Hotword.js:205 [HOTWORD] Command is excuting
      MMM-Hotword.js:215 [HOTWORD] notificationExec: ASSISTANT_ACTIVATE {profile: "default", type: "WAVEFILE", key: "modules/MMM-Hotword/temp/afterRecording.wav"}
      module.js:198 alert is suspended.
      MMM-AssistantMk2.js:563 [AMK2] Command CMD_HOTWORD_PAUSE is executed (notificationExec).
      module.js:198 clock is suspended.
      module.js:198 MMM-OpenmapWeather is suspended.
      module.js:198 weatherforecast is suspended.
      module.js:198 MMM-Tools is suspended.
      MMM-PlexNowPlaying.js:919 MMM-PlexNowPlaying: Suspended.
      module.js:198 MMM-homeassistant-sensors is suspended.
      module.js:198 MMM-Hotword is suspended.
      MMM-Assistant2Display.js:214 [A2D] This module cannot be suspended.
      module.js:198 MMM-synology-ds is suspended.
      response.js:77 [AMK2] Status from standby to think
      youtube.js:152 [A2D] YT Command: setVolume 5
      response.js:77 [AMK2] Status from think to confirmation
      MMM-AssistantMk2.js:654 [AMK2] Send A2D Response.
      display.js:57 [A2D] Response Scan
      display.js:312 [A2D] Lock Screen
      youtube.js:152 [A2D] YT Command: cueVideoById {videoId: "7HD6O9patDE"}
      display.js:89 [A2D] Response Structure: {radio: false, speak: true, locked: true, AMk2: {…}, youtube: {…}, …}
      response.js:77 [AMK2] Status from confirmation to reply
      response.js:210 [AMK2] Wait audio to finish
      display.js:296 [A2D] Hide Iframe
      youtube.js:119 [A2D] YT Status: Video unstarted
      youtube.js:152 [A2D] YT Command: playVideo
      youtube.js:119 [A2D] YT Status: Video cued
      youtube.js:119 [A2D] YT Status: Video buffering
      **youtube.js:77 [AMK2:ADDONS:A2D] Player Error 150: Not Allowed By Owner**
      display.js:268 [A2D] Reset YouTube {radio: false, speak: true, locked: true, AMk2: {…}, youtube: {…}, …}
      response.js:22 [AMK2] audio end
      response.js:142 [AMK2] Conversation ends.
      response.js:77 [AMK2] Status from reply to standby
      youtube.js:152 [A2D] YT Command: setVolume 100
      display.js:322 [A2D] Unlock Screen
      main.js:280 Will not show alert. LockStrings active: AMK2_LOCKED
      main.js:280 Will not show updatenotification. LockStrings active: AMK2_LOCKED
      main.js:280 Will not show clock. LockStrings active: AMK2_LOCKED
      main.js:280 Will not show MMM-OpenmapWeather. LockStrings active: AMK2_LOCKED
      main.js:280 Will not show weatherforecast. LockStrings active: AMK2_LOCKED
      main.js:280 Will not show MMM-Tools. LockStrings active: AMK2_LOCKED
      main.js:280 Will not show MMM-PlexNowPlaying. LockStrings active: AMK2_LOCKED
      main.js:280 Will not show mmm-hue-lights. LockStrings active: AMK2_LOCKED
      main.js:280 Will not show MMM-homeassistant-sensors. LockStrings active: AMK2_LOCKED
      main.js:280 Will not show MMM-Hotword. LockStrings active: AMK2_LOCKED
      main.js:280 Will not show MMM-Assistant2Display. LockStrings active: AMK2_LOCKED
      main.js:280 Will not show MMM-Parcel. LockStrings active: AMK2_LOCKED
      main.js:280 Will not show MMM-synology-ds. LockStrings active: AMK2_LOCKED
      main.js:280 Will not show MMM-CalendarExt2. LockStrings active: AMK2_LOCKED
      MMM-AssistantMk2.js:563 [AMK2] Command CMD_HOTWORD_RESUME is executed (notificationExec).
      module.js:205 alert is resumed.
      module.js:205 clock is resumed.
      module.js:205 MMM-OpenmapWeather is resumed.
      module.js:205 weatherforecast is resumed.
      module.js:205 MMM-Tools is resumed.
      MMM-PlexNowPlaying.js:919 MMM-PlexNowPlaying: Resumed.
      MMM-PlexNowPlaying.js:919 MMM-PlexNowPlaying: Update scheduled to run automatically every 30 second(s).
      module.js:205 MMM-homeassistant-sensors is resumed.
      module.js:205 MMM-Hotword is resumed.
      MMM-PlexNowPlaying.js:919 MMM-PlexNowPlaying: Data received from the Plex server after 1 attempt(s).
      MMM-Assistant2Display.js:218 [A2D] This module cannot be resumed.
      module.js:205 MMM-synology-ds is resumed.
        sdetweil @JohnBachini
        @JohnBachini said in MMM-Assistant2Display:
        seems pretty clear… the owner(s) of the video(s) has restricted where it can play (cause they get money for every play)
        nothing we can do about it
        • ? Offline
          A Former User
          sighs… :dizzy_face: :face_with_thermometer:
          • ? Offline
            A Former User
            this ?
            wiki says :
            config.js file (general config)
            var config = { address: "localhost", port: 8080,
            if addess is 0.0.0.0 or other, YouTube should have some trouble
              JohnBachini @Guest
              @Bugsounet
              Thanks I will give that a try.
              • E Offline
                Egnos
                Hi, I have the same problem…
                alert is suspended.
                module.js:199 clock is suspended.
                module.js:199 calendar is suspended.
                module.js:206 MMM-GoogleAssistant is resumed.
                module.js:199 alert is suspended.
                main.js:297 Will not show alert. LockStrings active: GA_LOCKED
                main.js:297 Will not show updatenotification. LockStrings active: GA_LOCKED
                main.js:297 Will not show clock. LockStrings active: GA_LOCKED
                main.js:297 Will not show MMM-Assistant2Display. LockStrings active: GA_LOCKED
                main.js:297 Will not show calendar. LockStrings active: GA_LOCKED
                youtube.js:1 [A2D] YT Error 150: Not Allowed By Owner
                module.js:206 alert is resumed.
                module.js:206 clock is resumed.
                module.js:206 calendar is resumed.
                module.js:199 MMM-GoogleAssistant is suspended.
                [05.01.2021 02:43.06.540] [LOG]   [ASSISTANT] Found YouTube Title: Michael Jackson - Thriller (Official Video) - videoId: sOnqjkJTMaA
                It’s really strange because with the old version (now I have MagicMirror: v2.14.0
                ) of MM this video opened without problems …
                How can I solve?
                • ? Offline
                  A Former User
                  know issue
                  Working since 3 days about it
                  • T Offline
                    totofar
                    Hello, I’m new in this forum.
                    First I’d like to say a warm thank you to the developers that built these brillant modules.
                    I’ve deployed MMM-GoogleAssistant and MMM-Assistant2Display.
                    I faced the standard issues of localhost, TokenYT and electronOptions (+ another less frequent on screenRotate) that prevented from showing Youtube videos… But finaly I can manage to display some / but not all.
                    In example, Youtube Tom & Jerry works successfuly… some others like Mickael Jackson thriller wont…
                    Logs confirm that video was found… but does not display. :(
                    “J’ai trouvé cette vidéo : Michael Jackson - Thriller (Official Video) - YouTube”,
                    0|mm | links: [],
                    0|mm | photos: [],
                    0|mm | path: ‘/home/pi/MagicMirror/modules/MMM-GoogleAssistant/tmp/lastScreenOutput.html’,
                    0|mm | uri: ‘tmp/lastScreenOutput.html’
                    0|mm | },
                    0|mm | audio: {
                    0|mm | path: ‘/home/pi/MagicMirror/modules/MMM-GoogleAssistant/tmp/lastResponse.mp3’,
                    0|mm | uri: ‘tmp/lastResponse.mp3’
                    0|mm | },
                    0|mm | transcription: { transcription: ‘YouTube Michael Jackson thriller’, done: true },
                    0|mm | continue: false,
                    0|mm | volume: null,
                    0|mm | lastQuery: {
                    0|mm | type: ‘MIC’,
                    0|mm | key: null,
                    0|mm | lang: ‘fr-FR’,
                    0|mm | useScreenOutput: true,
                    0|mm | useAudioOutput: true,
                    0|mm | status: ‘standby’,
                    0|mm | chime: true
                    0|mm | }
                    0|mm | }
                    0|mm | [12.01.2021 23:48.12.152] [LOG]
                    0|mm | [SNOWBOY] Starts listening.
                    0|mm | [12.01.2021 23:48.12.251] [LOG]
                    0|mm | [LPCM16] ~v1.0.1~ Start listening 1 channels, use arecord with sample rate 16000
                    0|mm | [12.01.2021 23:48.13.369] [LOG]
                    0|mm | [ASSISTANT] Found YouTube Title: Michael Jackson - Thriller (Official Video) - videoId: sOnqjkJTMaA
                    Any idea ?
                    Thanks in advance.
                    • ? Offline
                      A Former User
                      je bosse dessus actuellement, ce n’est pas un bug de MM ou de A2D, c’est simplement que Google a changer sa politique de visionnage des videos depuis le 01/01/2021.
                      Je cherche a contourner le problème … un peu de patience :)
                      T 1 Reply Last reply Reply Quote 2
                      • T Offline
                        totofar @Guest
                        @Bugsounet Merci beaucoup pour ta réponse et, de manière générale pour l’ensemble des ressources mises à disposition.
