    Spacing question
    2 Posts 2 Posters 585 Views 2 Watching
    • M
      matelot20
      I’ve trying to understand spacing with CSS and have been using background-color to see where each layout fits on the screen. I notice that the bottom bar and lower sections always have spaces between the 2 areas. No matter what I use margin, padding or border=0px to close the gap, it doesn’t do anything. Is it normal that there must be spacing between each section? What code should I use to close the gap between bottom_bar and bottom_left/right. Thanks.
      • lavolp3L
        lavolp3 Module Developer @matelot20
        @matelot20 what you see is most probably the margin of the modules
        Try changing that
        .bottom_bar .module {
          margin: 0;
        How to troubleshoot modules
        MMM-soccer v2, MMM-AVStock
