    MMM-EFA Config
    6 Posts 2 Posters 1.5k Views 2 Watching
    • R
      rxlDavid
      So If I try to add the config code to the config and save the config it will just go blank.
      The Config Code:
          module: 'MMM-EFA-departures',
          position: 'upper_third',
              efaUrl: "http://www2.vvs.de/vvs/XSLT_DM_REQUEST",
              stopID: "500XXXX",
              stopName: "MMM-EFA is loading",
              lines: ['all'],
              reload: 60000,
              realDepTime: true,
              relativeDepTime: true,
              toggleDepTime: true,
              toggleDepTimePerReload: 6,
              fade: true,
              fadePoint: 0.25,
              maxDepartures: 4
      And If I remove the config of EFA then it works normally…
      Thank you
      lavolp3L 1 Reply Last reply
      • lavolp3L
        lavolp3 Module Developer @rxlDavid
        @rxlDavid Can’t find any errors in the config entry.
        Do the following to debug:
        1. include the config entry, and try the following in the console (directly or via ssh)
        cd ~/MagicMirror
        npm run config:check
        No errors?
        Then: Open the mirror window in a browser on your PC, open the DevTools (F12), select the “console” tab and look for errors/red lines
        How to troubleshoot modules
        MMM-soccer v2, MMM-AVStock
        • R
          rxlDavid
          So I done npm run…:
          And thats what I recieved:
          > magicmirror@2.11.0 config:check /home/pi/MagicMirror
          > node tests/configs/check_config.js
          Checking file...  /home/pi/MagicMirror/config/config.js
          Line 1 col 156 Trailing spaces not allowed.
          Line 95 col 12 Strings must use doublequote.
          Line 96 col 25 Strings must use doublequote.
          Line 97 col 23 Strings must use doublequote.
          Line 99 col 25 Strings must use doublequote.
          Line 100 col 25 Strings must use doublequote.
          Line 101 col 25 Strings must use doublequote.
          Line 109 col 12 Strings must use doublequote.
          Line 110 col 14 Strings must use doublequote.
          Line 115 col 13 Strings must use doublequote.
          The EFA Module starts at Line 109…
          How can I open it on a browser?
          lavolp3L 2 Replies Last reply
          • lavolp3L
            @rxlDavid You have config errors in the respective lines.
            You should use your preferred editor (e.g. nano) and fix them
            nano config/config.js
            Or post your config.js here but delete every sensitive information!
            At least post the first few lines.
            R 1 Reply Last reply
            • lavolp3L
              @rxlDavid
              The errors make it seem like you have a strict mode enabled somehow. Wouldn’t even know how to do that.
              Because normally the check would allow training lines and single quotes…
              • R
                rxlDavid @lavolp3
                @lavolp3 said in MMM-EFA Config:
                /* Magic Mirror Config Sample * * By Michael Teeuw http://michaelteeuw.nl * MIT Licensed. * * For more information on how you can configure this file * See
                 https://github.com/MichMich/MagicMirror#configuration * */
                var config = {
                	port: 8080,
                	language: "de",
                	timeFormat: 24,
                	units: "metric",
                			     // false, default for all  NON-armv6l devices
                			module: "alert",
                			module: "updatenotification",
                			position: "top_bar"
                			module: "clock",
                			position: "top_left"
                			header: "Kalender",
                						symbol: "calendar-check",
                						url: "XXXXXXX"					}
                			module: "compliments",
                			position: "lower_third"
                			module: "currentweather",
                				locationID: "28XXXX", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
                				appid: "XXXXXX"
                			module: "weatherforecast",
                			header: "Weather Forecast",
                				locationID: "XXXXXX", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
                				appid: "XXXXXX"
                			module: "newsfeed",
                			position: "bottom_bar",
                				feeds: [
                						title: "Tagesschau",
                						url: "http://www.tagesschau.de/xml/rss2"
                				showSourceTitle: true,
                				showPublishDate: true,
                				broadcastNewsFeeds: true,
                				broadcastNewsUpdates: true
                			module: 'MMM-Mail',
                            		position: 'bottom_left',
                            		header: 'Email',
                            		config:{
                                		user: 'XXXXXX',
                                		pass: 'XXXXXX',
                                		host: 'XXXXXX',
                                		port: 993,
                                		numberOfEmails: 5,
                                		fade: true,
                				subjectlength: 50
                				stopID: "XXXXXX",
                				lines: ['all'],
                				reload: 60000,
                				realDepTime: true,
                				fade: true,
                				fadePoint: 0.25,
                				maxDepartures: 4
                i edit the config via nano…
