    read csv-data and put it in an array
    313 Posts 3 Posters 540.0k Views 4 Watching
    • PerlchampP Offline
      Perlchamp
      this code => blackScreen:
          getDom: function() {
      	var wrapper = this.createEl("div", null, null, null, null);
      	// tell MM to call and get our content
      	Log.log(JSON.stringify(this.active_birthdays));
      	if ((moment() > this.midnight) || (!this.loaded)) {
      	    var month = moment().month();
      	    var year = moment().year();
      	    var monthName = moment().format("MMMM");
      	    var monthLength = moment().daysInMonth();
      	    var now = moment();
      	    if(Object.keys(this.active_birthdays).length > 0) {
      		// create your table here
      		var table = this.createEl("table", "birthday-table", "TABLE", wrapper, null);
      		// create tableheader here, array of column names
      		var table_header = this.createTableHeader(table, "THEAD", [" "," "]);
      		//var table_header = this.createTableHeader(table, null, [" "," "," "]);
      		// create TBODY section with day names
      		var tBody = this.createEl('tBody', "birthday-tbody", "TBODY", table, null);
      		var birthdays_seen = {};
      		var spacer = " ";
      		for(var birthday of Object.keys(this.active_birthdays)) {
      		    for(var person of this.active_birthdays[birthday]) {
      			// create looped row section
      			var bodyTR = this.createEl("tr", "birthday-tr-body", "TR-BODY", tBody, null);
      			let now = moment();
      			let entrie = moment(birthday,"DD.MM");
      			if(this.config.dimmEntries) {
      			// delete leading 0 and month
      			var bd = "";
      			if(birthdays_seen[birthday] == undefined) {
      			    bd = (birthday.startsWith("0")? birthday.substring(1): birthday).split(".")[0];
      			    var imageTD = this.createEl("td", null, "TD-IMAGE".concat(entrie.isBefore(now)?"_DIMMED":'', bodyTR, bd);
      			    //var imageTD = this.createEl("td", null, "TD-IMAGE", bodyTR, bd);
      			    var nameTD = this.createEl("td", null, "TD-BODY".concat(entrie.isBefore(now)?"_DIMMED":'', bodyTR, person.name);
      			    //var nameTD = this.createEl("td", null, "TD-BODY", bodyTR, person.name);
      			    this.createEl("span", null, "TD-AGE", nameTD, " ");
      			    // needs class for width
      			    var spanTDo = this.createEl("span", null, "TD-AGE".concat(entrie.isBefore(now)?"_DIMMED":'', nameTD, person.age);
      			    //var spanTDo = this.createEl("span", null, "TD-AGE", nameTD, person.age);
      			else{
      			    // add a break
      			    this.createEl("br", null , null , spanTDo, null);
      			    // add a span with name
      			    var nameTD = this.createEl("span", null, "TD-BODY".concat(entrie.isBefore(now)?"_DIMMED":'',spanTDo, person.name);
      			    //var nameTD = this.createEl("span", null, "TD-BODY", spanTDo, person.name);
      			    // add a span with age
      			    var spanTD = this.createEl("span", null, "TD-AGE".concat(entrie.isBefore(now)?"_DIMMED":'', spanTDo, person.age);
      			    //var spanTD = this.createEl("span", null, "TD-AGE", spanTDo, person.age);
      			birthdays_seen[birthday] = true;
      		// Create TFOOT section -- currently used for debugging only
      		if (this.config.debugging) {
      		    var table_footer = this.createTableFooter(tBody, null, [" "," "]);
      		    //footerTD.innerHTML = "Birthdaylist is currently in DEBUG mode!<br />Please see console log.";
      		else {
      	    // pass the created content back to MM to add to DOM.
      	    return wrapper;
      	// Dom is loaded
      	this.loaded = true;
      this code works but no css:
      	var wrapper = this.createEl("div",null,null,null,null);
      	    var now = moment();
      		// create table
      		var table = this.createEl("table", "birthday-table", "TABLE" , wrapper,null)
      		var table_header = this.createTableHeader(table, null, [" "," "]);
      		var tBody = this.createEl('tBody', "birthday-tbody", "TBODY" , table, null);
      		var birthdays_seen= {}
      		var spacer = " ";
      			var bodyTR = this.createEl('tr', "birthday-tr-body", "TR-BODY" , tBody, null);
      			let now = moment().format('DD.MM').valueOf();
      			let entrie=now;
      			    entrie = moment(birthday,'DD.MM').valueOf();
      			var bd = "";
      			    bd = (birthday.startsWith("0")? birthday.substring(1): birthday).split('.')[0];
      			    var imageTD = this.createEl('td', null, "TD-IMAGE" + (entrie < now)?"_DIMMED":'' , bodyTR, bd);
      			    var nameTD = this.createEl('td', null, "TD-BODY" + (entrie < now)?"_DIMMED":'' , bodyTR, person.name);
      			    this.createEl("span", null, null, nameTD, " ");
      			    var spanTDo = this.createEl("span", null, "TD-AGE" + (entrie < now)?"_DIMMED":'', nameTD, person.age);
      			else{
      			    // add a break
      			    this.createEl('br', null , null , spanTDo,null);
      			    var nameTD = this.createEl('span', null, "TD-BODY" + (entrie < now)?"_DIMMED":'' ,spanTDo, person.name);
      			    var spanTD = this.createEl("span", null, "TD-AGE" + (entrie < now)?"_DIMMED":'', spanTDo, person.age);
      			var spacerTR = this.createEl('tr', null, null , tBody, null);
      			var spacerTD = this.createEl('td', null, "SPACER" , spacerTR, " ");
      			spacerTD.colSpan = "2";
      		else {
      	    return wrapper;
      	// Dom is loaded
      	this.loaded = true;
        sdetweil @Perlchamp
        @Perlchamp you need to learn the debugger, code fixed
        	getDom: function(){
        		var wrapper = this.createEl("div",null,null,null);
        		if(Object.keys(this.active_birthdays).length>0){
        			var table = this.createEl("table", "birthday-table", null, wrapper );
        			// table header here, array of column names
        			var table_header=this.createTableHeader(table,null, ["date","Name","age"])
        			var tBody = this.createEl('tbody', "birthday-t-body", "tbody", table, null);
        					var bodyTR = this.createEl('tr', null, "TR-BODY" ,tBody, null);
        					let now = moment()
        					let entrie=now
        					var bd = "";
        			    	if(birthdays_seen[birthday]==undefined){
        						bd =(birthday.startsWith("0")? birthday.substring(1): birthday).split('.')[0];
        						var imageTD = this.createEl('td', null, "TD-IMAGE".concat(entrie.isBefore(now)?"_DIMMED":'') , bodyTR, bd);
        						var nameTD = this.createEl('td', null, "TD-BODY".concat(entrie.isBefore(now)?"_DIMMED":'') , bodyTR, person.name);
        									 this.createEl("span", null, null, nameTD, " ");						// needs class for width
        						var spanTDo = this.createEl("span", null, "TD-AGE".concat(entrie.isBefore(now)?"_DIMMED":''), nameTD, person.age);
        					else{
        						// add a break
        						var nameTD = this.createEl('span', null, "TD-BODY".concat(entrie.isBefore(now)?"_DIMMED":'') ,spanTDo, person.name);
        						var spanTD = this.createEl("span", null, "TD-AGE".concat(entrie.isBefore(now)?"_DIMMED":''), spanTDo, person.age);
        		return wrapper;
        see the last line of the console
        black screen means syntax error in some modulename.js, click on the line number and it will take you to that line in the code … note the concat(… is missing its right paren ‘)’
          Perlchamp
          thank you very much. yes i need more expirience of debugging. it’s my second day i use it, sorry sam. AND MANY THANKS.
            sdetweil @Perlchamp
            @Perlchamp Make an error, take out a comma, or ’
            reload the page, f5
            put part of ht module name in the filter field of the console
            find the error message
            click the filename/line to the right
              Perlchamp
              ok, will collect some experience …
                Perlchamp
                ok, the blacksreen is gone, works, but no css
                  sdetweil @Perlchamp
                  @Perlchamp that comes up for me
                  Copied directly. Will send my module file.
                    Perlchamp
                    ok, thanks
                      sdetweil @Perlchamp
                      @Perlchamp see the expanded html on left
                      file sent
                        Perlchamp
                        it WORKS ! now i hope to find the error :-)
                          sdetweil @Perlchamp
                          @Perlchamp i did not use the classes , no… didn’t care about the layout etc…
                          I want to make sure the NAMES of the classes are right…
                          sending file again, sorting the dates
                            Perlchamp
                            work’s, too :-) , sam
                              dorinilut
                              @Perlchamp , would it be possible to share the module you came up with? I am looking for the exact same thing and I was thinking I would be getting a copy.
                              many many thanks!
                              • 12
                              • 13
                              • 14
                              • 15
                              • 16
                              • 16 / 16
