    read csv-data and put it in an array
    313 Posts 3 Posters 579.0k Views 4 Watching
    • PerlchampP
      Perlchamp
      ok, thanks again :-)
        sdetweil @Perlchamp
        @Perlchamp u can redirect the output of npm start to a file, npm start >somefile
        u can minimize the window with alt-spacebar, n
        u can open the developers window ( for the modulename,js debugging) npm start dev
        or if mirror already running use f12 or ctrl-shift-i on the keyboard
        I debug from my PC, ssh connected to pi, or I run MM on my PC… and debug there
        • PerlchampP
          Perlchamp
          what do you use for debugging on pc ?
          do you have x64 or arm-based pc ?
            sdetweil @Perlchamp
            @Perlchamp x64, run linux or windows (today on linux), doesn’t matter… same debug process… look at console or browser window
            if I need to debug modulename.js on pi, I open browser from PC to the mirror URL and do it there
            • PerlchampP
              Perlchamp
              AND:
              thanks a lot for YOUR time. i hope it will not been wasted … i will working hard to get some results …
              • PerlchampP
                Perlchamp
                @sdetweil said in read csv-data and put it in an array:
                how ?
                  sdetweil @Perlchamp
                  @Perlchamp on MagicMirror, in config, set address:“0.0.0.0”,
                  And ipWhitelist:[],
                  Then u can connect to the mm url from anywhere in your house/office.
                  http://ipaddress:port
                  Then f12 or ctrl-shift-i on the browser keyboard to open the developers window.
                  • PerlchampP
                    Perlchamp
                    ok thank.
                    if i want to test
                        readCSV: fs.readFile('birthdaylist.csv', 'utf8', function (err, data) {
                    	var dataArray = data.split(/\r?\n/);
                    	Log.log(dataArray);
                    or
                    readList: function() {
                    	var JFile=require('jfile');
                    	var myF=new JFile("MMM-birthday.txt");
                    	myF.lines // ["first line","second line"]
                    i have to do this in node_helper right? and first i have to require them and of course to install them … something i forgot ?
                      sdetweil @Perlchamp
                      @Perlchamp Log.log is ONLY in the browser, but fs. Is not usable in browser
                      U can test it w node to make sure it works. Then for mm it has to be in node_helper
                      Install library, so that you CAN require
                      • PerlchampP
                        Perlchamp
                        hallo sam :-)
                        i have now this in my node_helper.js:
                        var NodeHelper = require("node_helper");
                        // add require of other javascripot components here
                        // var xxx = require('yyy'); here
                        const csv = require("csvtojson");
                        const csvFilePath = this.path + 'birthdaylist.csv';
                        	init(){
                        		console.log("init module helper perlchamp");
                        	start() {
                        		console.log("Starting module helper: ${this.name}");
                        		console.log("dieser Pfad: ${this.path}");
                        		csv()
                        		.fromFile(csvFilePath)
                        		.then((jsonObj)=>{
                        			console.log(jsonObj);
                        	stop(){
                        		console.log(`Stopping module helper: ${this.name}`);
                        	// handle messages from our module// each notification indicates a different messages
                        	// payload is a data structure that is different per message.. up to you to design this
                        	socketNotificationReceived(notification, payload) {
                        		console.log(this.name + " received a socket notification: " + notification + " - Payload: " + payload);
                        		// if config message from module
                        		if (notification === "CONFIG") {
                        			// save payload config info
                        			this.config=payload
                        			// wait 15 seconds, send a message back to module
                        			setTimeout(()=> { this.sendSocketNotification("message_from_helper"," this is a test_message")}, 15000)
                        		else if(notification === "????2") {
                        terminal says:
                        Unhandled rejection Error: File does not exist. Check to make sure the file path to your csv is correct.
                            at /home/dirk/MagicMirror/node_modules/csvtojson/v2/Converter.js:81:37
                            at suppressedCallback (fs.js:209:5)
                            at FSReqCallback.oncomplete (fs.js:153:23)
                        it’s from your SampleModule …
                        1. how can i see the console.log statements in the browser, starting MM ?
                        2. did i enter the code in the right place?
                        3. if I enter the following into the terminal window:
                          node console.log (‘path: $ {this.path}’)
                          i got an error message:
                          bash: Syntaxerror unexpected word `(’
                          what am I doing wrong ?
                        many thanks in advance
                          sdetweil @Perlchamp
                          @Perlchamp said in read csv-data and put it in an array:
                          • how can i see the console.log statements in the browser, starting MM ?
                            cannot see node_helper messages in browser, must look in the terminal window where u did npm start
                            you can redirect those messages to a file
                            npm start >somefile
                            and then look at somefile live with editor
                          • did i enter the code in the right place?
                            const csvFilePath = this.path + ‘birthdaylist.csv’;
                            u have this.path outside the NodeHelper.create, at that time ‘this’ does not exist
                            ‘this’ means ‘instance of’, and u are outside the thing that creates the instance
                          • if I enter the following into the terminal window:
                          because u are not running in magic mirror , ‘this’ does not exist
                          • i got an error message:
                          • bash: Syntaxerror unexpected word `(’
                            what am I doing wrong…
                            bash would not see any ( unless u put it on the line with node
                          node (something)
                          that is a command to bash (the terminal window program, he has his own rules about parens, and other special characters (* means ALL filenames in this folder for example!)
                          I never ever use $ in node_helper (or anywhere else)
                          I would do this
                          console.log (‘path: '+ this.path)
                          • PerlchampP
                            Perlchamp
                            thank you. ok, i will test …
                            only for your information:
                            start() {
                            		console.log(`Starting module helper: ${this.name}`);
                            	stop(){
                            this is from your SampleModule. i’m not here to reprimand you. it should only be information. so please do not misunderstand.
                              sdetweil @Perlchamp
                              @Perlchamp thanks… will fix… never copy from another without review!!
                              • PerlchampP
                                Perlchamp
                                always my pleasure
                                  @Perlchamp fixed
                                    sdetweil
                                    if u redirect the output of npm start to a file, this is what you will see in the file
                                    > magicmirror@2.11.0 start /home/sam/MagicMirror
                                    [2020-04-30 11:15:53.521] [LOG]    Starting MagicMirror: v2.11.0
                                    [2020-04-30 11:15:53.524] [LOG]    Loading config ...
                                    [2020-04-30 11:15:53.526] [LOG]    Loading module helpers ...
                                    [2020-04-30 11:15:53.528] [LOG]    Initializing new module helper ...
                                    [2020-04-30 11:15:53.528] [LOG]    Module helper loaded: MMM-Logging
                                    [2020-04-30 11:15:53.529] [LOG]    No helper found for module: alert.
                                    [2020-04-30 11:15:53.529] [LOG]    No helper found for module: clock.
                                    [2020-04-30 11:15:53.663] [LOG]    Initializing new module helper ...
                                    [2020-04-30 11:15:53.663] [LOG]    Module helper loaded: MyCovid19
                                    [2020-04-30 11:15:53.784] [LOG]    Initializing new module helper ...
                                    [2020-04-30 11:15:53.785] [LOG]    Module helper loaded: MMM-AlexaControl
                                    [2020-04-30 11:15:53.786] [LOG]    handler helper in init
                                    [2020-04-30 11:15:53.786] [LOG]    Module helper loaded: MMM-SleepWake
                                    [2020-04-30 11:15:53.786] [LOG]    All module helpers loaded.
                                    [2020-04-30 11:15:53.820] [LOG]    Starting server on port 8090 ...
                                    [2020-04-30 11:15:53.821] [INFO]   You're using a full whitelist configuration to allow for all IPs
                                    [2020-04-30 11:15:53.823] [LOG]    Server started ...
                                    [2020-04-30 11:15:53.823] [LOG]    Connecting socket for: MMM-Logging
                                    [2020-04-30 11:15:53.824] [LOG]    Module helper started for MMM-Logging
                                    [2020-04-30 11:15:53.824] [LOG]    Connecting socket for: MyCovid19
                                    [2020-04-30 11:15:53.824] [LOG]    Starting node_helper for module: MyCovid19
                                    [2020-04-30 11:15:53.824] [LOG]    path=/home/sam/MagicMirror/modules/MyCovid19
                                    [2020-04-30 11:15:53.824] [LOG]    Connecting socket for: MMM-AlexaControl
                                    [2020-04-30 11:15:53.824] [LOG]    MMM-AlexaControl helper, started...
                                    [2020-04-30 11:15:53.824] [LOG]    Connecting socket for: MMM-SleepWake
                                    [2020-04-30 11:15:53.825] [LOG]    handler helper in start
                                    [2020-04-30 11:15:53.825] [LOG]    Sockets connected & modules started ...
                                    [2020-04-30 11:15:53.906] [LOG]    Launching application.
                                    [2020-04-30 11:15:53.928] [LOG]    setup for latent showing  // < --- from my module node_helper
                                    [2020-04-30 11:15:54.487] [LOG]    requested file exists=modules/MyCovid19/states-rawdata-04-30-2020 sending back to module_13_MyCovid19_5731  // < --- from my module node_helper
                                    [2020-04-30 11:15:54.490] [LOG]    requested file exists=modules/MyCovid19/countries-rawdata-04-30-2020 sending back to module_16_MyCovid19_7951  // < --- from my module node_helper
                                    [2020-04-30 11:15:54.492] [LOG]    requested file exists=modules/MyCovid19/countries-rawdata-04-30-2020 sending back to module_14_MyCovid19_1721  // < --- from my module node_helper
                                    [2020-04-30 11:15:54.493] [LOG]    requested file exists=modules/MyCovid19/countries-rawdata-04-30-2020 sending back to module_15_MyCovid19_91  // < --- from my module node_helper
                                    [2020-04-30 11:15:54.498] [LOG]    requested file exists=modules/MyCovid19/countries-rawdata-04-30-2020 sending back to module_17_MyCovid19_2191  // < --- from my module node_helper
                                    etc
                                    • PerlchampP
                                      Perlchamp
                                      ok, it’s slowly dawning on me, see little light at the end of the tunnel
                                        sdetweil @Perlchamp
                                        @Perlchamp if u install the logging module I suggested, then it captures all the messages from the modulename.js in the browser and prints them to the terminal window log, which would be saved to the file as well.
                                          @sdetweil a node_helper has two built in functions (I have never useed init() or stop() for anything, but they are available)
                                          start: when the helper is loaded
                                          socketNotificationReceived, when the modulename.js sends a message to the helper
                                          the helper has one useful function
                                          sendSocketNotification , to send a message back to the modulename.js
                                          everything else is all up to you
                                          note that the modulename.js gets the config.js config:{} info for this module, NOT the node_helper… so if the node_helper needs to know (filenames, timings, ???) , the modulename.js has to send a message with the this.config info down to the helper, and the helper has to save it to use later
                                          • PerlchampP
                                            Perlchamp
                                            so i also can do (?):
                                            npm start dev
                                            in the window on the right klicking on “console”. there i see a lot of massages coming from console/moduls
                                            and then i can use your module to lock out other modules (?) …
                                            • 15
                                            • 16
                                            • 3 / 16
